Using MS Access Update Query to Fix ShipHead V6.1
Thanks, that fixed it
jeremyrleonard@...
Sent: Wednesday, 14 December 2005 11:48 PM
Subject: Re: [Vantage] Using MS Access Update Query to Fix ShipHead V6.1
You need to change your ODBC setup from "READ UNCOMMITED" to "READ
COMMITED". Its on the Advanced tab of the ODBC Driver. Then relink your
tables in Access.
Jeremy
Sent: Wed, 14 Dec 2005 16:25:03 +1100
Subject: [Vantage] Using MS Access Update Query to Fix ShipHead V6.1
We have a number of Customer Shipments showing as shipped but not invoiced
even though they have been invoiced. Invoice Tracker shows the invoice type
as "SHP". A check on the table values shows that the ShipHead.Invoiced value
is set to No and the ShipDtl.Invoiced value is set to Yes. This explains why
no invoice comes up when we 'Get Shipments' from invoice entry and also
explains why the Packing Slip still shows in the Customer Shipments Shipped
screen. I have no idea how they came about but wanted to try an MS Access
Update Query to set the ShipHead.Invoiced value to Yes (in my test system)
to see if this fixes the problem before the auditors start to get jumpy. I
can use ODBC to link to the table but when I run the update query I get an
error
"ODBC-update on a linked table 'PUB_ShipHead' failed. Statement not allowed
in readonly isolation level".
I am running the update query from a Terminal Server session and I have
Administration rights on all servers. I have read on the group that this is
possible to do, so clearly I am missing something. Any clues?
Thanks in advance
John Walter | National IS Advisor | Hufcor Pty Ltd
5-7 Trade Park Drive, Tullamarine, Victoria. 3250
Phone +613 9330 3733 | Fax +613 9338 9015
www.hufcor.com.au
Yahoo! Groups Links
Yahoo! Groups Links
error
Thanks in advance
www.hufcor.com.au
You need to change your ODBC setup from "READ UNCOMMITED" to "READ COMMITED". Its on the Advanced tab of the ODBC Driver. Then relink your tables in Access.
Jeremy
error
Thanks in advance
www.hufcor.com.au
Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
Yahoo! Groups Links
Support has a fix utility that you can use to change these. You could
contact them to get it.
