"If the number of open quotes changes when I refresh the data in sheet
3, the formulas in each cell on sheet 1 permanently change to
=sheet3!#REF! because there is no longer any data in the corresponding
cell in sheet 3."
A "#REF!" error occurs when an entire row or column is deleted, not just the
contents. Make sure your macro is clearing cell contents instead of
deleting columns/rows. To make sheet 1 cleaner, you can change to formula
to "=if(sheet3!a1 ="","",sheet3!a1). This way, if the cells in sheet 3 are
empty, nothing will be displayed on sheet 1.
HTH
Danice
cell in sheet 3."
HTH
Danice
