Using ProdCal.Hour[] in BAQ - 8.03.405
Is there a way to use ProdCal.Hour in a calculated field in a BAQ? ProdCal.Hour001 gives a syntax error. ProdCal.Hour[1] passes the syntax text, but gives an error when testing:
Error Detail
4GL STOP condition: The Server application has returned an error. (7243) (7241)
Stack Trace
at Epicor.Mfg.UI.App.BusinessActivityQuery.BAQTransaction.Execute()
at Epicor.Mfg.UI.App.BusinessActivityQuery.BAQ.btnTest_Click(Object sender, EventArgs e)
