There is nothing that ties the two together. You can export your quotes to excel and then use those to import in the Forecast entry module under actions/import forecast. Be careful with using the forecast though. If you have not used it before you should review how the setup works because it will start driving MRP demand immediatly once you load. Make sure you review your days before/days after flag as well on your company maintenance
Norman Hutchins <nhutchins@...> wrote: Is there a way to use open active quotes as a "forecast" in vantage? Maybe
use the confidence factor.
Norman Hutchins
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Norman Hutchins
