Using solution manager to migrate BAQ Report from test to prod
We had a couple of problems - on the imports only some of the pieces came through. Then I would try the import again and get an error. SCR90134 to be able to import BAQ reports more than 1x should be included in 9.05.700. SCR96821 to fix the initial import isn't targeted until 9.05.701.
Extended properties is scheduled for 702 (SCR95586).
If SCRs are targeted for future releases and I really need them, I open up a call with Epicor support through the web and have them attach my call to the SCR. Just because they are scheduled doesn't necessarily mean they get in. I'm going to hold on to my belief that the more calls they see tied to an SCR the better the chances are the fixes make it in.
When using solution manager to migrate a BAQ Report from test to production, everything(BAQ, report style, etc) seems to get moved except for the BAQ report. Anyone else experience this or have a solution? We are on 9.05.607A.
There was an SM discussion here a few months ago.
From it I got the impression that SM was a little quirky on all versions.
My only personal experience is with 9.04.5xx
In that version customizations and BAQs always succeeded.
Report Data Definitions always failed.
BAQ Reports were inconsistent.
We are on 607b and it is pretty much as described below.
Also, Extended Properties are not recognized. Known issue.
Too bad because because it is a good idea. Not executed well.
