I am not sure if “dynamic lists” are available in App studio or is limited to the product configurator designer but I need to be able to set up a dynamic list using values and displays. Similar to this older post. Currently if I need a static list I set those up under “List Items”. There are text boxes for values and displays. This works well. If I want to use a dynamic list ,and retrieve data from a lookup table or use a UD Method, it returns a tilde(~) separated list. With this as my only option my list can only be somewhat non descriptive. Whereas I would like to use an array of values like this [{"display":"An easy to understand description", "value":"SOME_VALUE"}]
. I looked in the “MetaUI” folder on the server for clues. Below is a random example. Not sure if the “$ref” involves inheritance with the combo listed. There appears to be a textField
and a valueField
available. Is there a way to do this either supported or a work around?
"id": "cboOprInspPlanRev",
"parentId": "div-col-a329a",
"sourceTypeId": "erp-combo-box",
"model": {
"guid": "ebb1598f-b813-4966-944a-5cd449caf366",
"labelText": "Revision",
"hidden": false,
"isKeyField": false,
"epBinding": "JobOperInsp.InspPlanRevNum",
"disabled": false,
"readonly": false,
"retrieveOnActivate": false,
"appDesignerComboType": "../../shared/combo/InspPlanRevSearch.InspPlanRevCombo/default/combo.jsonc#/combo",
"appDesignerComboOverride": true,
"filtersParams": [
"InspPlanNumColumn=?[InspPlanPartNum]"
"$ref": "../../shared/combo/InspPlanRevSearch.InspPlanRevCombo/default/combo.jsonc#/combo"
$ref"
"$schema": "https://schemas.developer.epicor.com/schemas/v1/combo.json",
"contentVersion": "1.0",
"imports": [],
"combo": {
"comboId": "InspPlanRevSearch.InspPlanRevCombo",
"svc": "Erp.BO.InspPlanRevSearchsvc",
"svcPath": "",
"textField": "InspPlanRevNum",
"valueField": "InspPlanRevNum",
"sort": "InspPlanRevNum",
"retrieveColumns": [
"InspPlanRevNum"
"tableName": "InspPlanRevList",
"filters": [
"InspPlanNum = '?{InspPlanNumColumn,''}'"
"required": false,
"isEpiReadOnly": false,
"appendList": false,
"isDelimited": true,
"parameterName": "InspPlanRevList"
"patch": []
