Using Vantage Webservices with VB6?
We are using Kewill Clippership for FedEx packages. Kewill uses VBA
and I've successfully tied in a webservice that talks with Vantage(we
purchased the wonderful Vantage SDK).
If I remember correctly, I had to install Microsoft Office 2003 Web
Service Toolkit.
Jeremy Jackson
--- In vantage@yahoogroups.com, "russnewcomer" <rnewcomer@...> wrote:
> > > some issues getting authenticated, wondering if anyone else had
done
> > > this and had some tips.
> > I have with VB.Net and was told repeatedly to skip the web
services
> and just
> > access the Business Object directly, which is what the web
services
> are doing
> > - so why not just go directly to the source?
> > As for authentication, what code are you using? Have you installed
> the Web
> > Services Security add-in for VB?
> > Mark W.
> All of the authentication for the web services seems to be done
using
> the Web Service Enhancements, which are a .NET tool that doesn't
> appear to be able to be used in VB6.
> So, I've been looking at grabbing a copy of VS.NET 2003 to call the
> web services, but I'm intrigued by your post, Mark. How can we
access
> the business objects directly? Is there a doc somewhere on how to
do
> that?
> Thanks
> RussN
Has anyone else tried to use the Vantage WebServices from VB6? I've
got an existing app that I am attempting to tie into, and I'm having
some issues getting authenticated, wondering if anyone else had done
RussN
I have with VB.Net and was told repeatedly to skip the web services and just
access the Business Object directly, which is what the web services are doing
As for authentication, what code are you using? Have you installed the Web
Mark W.
and just
are doing
the Web
> Mark W.
All of the authentication for the web services seems to be done using
web services, but I'm intrigued by your post, Mark. How can we access
the business objects directly? Is there a doc somewhere on how to do
that?
RussN
