V5.1 Message buffer size
You might want to check you Startup.pf in the Progress directory.
I had this problem in 5.2, support had me add the following line; -Mm 4096
to the startup.pf.
-cpinternal ISO8859-1
-cpstream ISO8859-1
-cpcoll Basic
-cpcase Basic
-d mdy
-numsep 44
-numdec 46
-Mm 4096 (added line for your error)
-L 3000 -n 56 (added this line for another error)
Hope this helps.
nancy
Sent: Tuesday, January 07, 2003 12:23 PM
Subject: [Vantage] V5.1 Message buffer size
We have just put up V5.1 and the 30 users seem to be running fine. I
set the Message buffer size in Progress Explorer and the Vantage.pf (-
Mm)file to 4096. When I try to run Custom Reports from the Vantage
client it gives me the error:
"Database error, server has -Mm 4096 and client has 1024. Must be
the same"
I can run all of the reports with Report Builder with no problem.
What parameter did I miss?
Thanks!!
Bill Jack - IT Admin
Cretors & Co
the same"
Thanks!!
Cretors & Co
Bill,
I ran into the same thing. You also need to modify the X:\Epic51
\Progress\Startup.pf file to add the -Mm 4096 parameter to the end of
the file. I missed it when I read through the install instructions
(pg27).
Good luck.
John Elder
Penn State Tool & Die
--- In vantage@yahoogroups.com, "cretorsit <bjack@c...>" <bjack@c...>
I
be
> the same"
> Thanks!!
> Cretors & Co
