V5.2 Control Accounts
Thanks, that was the problem, an inactive account.
Bill
--- In vantage@yahoogroups.com, "John Walter" <john.w@...> wrote:
> This sounds like one of the accounts set up in the control accounts
setup
> had been deleted. We had this issue when we were on 5.2, Vantage
allows you
> to delete an such an account provided there have been no
transactions
> against it.
> I had captured screen shots of the initial setup so locating the
offending
> account number was easy, then just recreate the account and access
the
> Control Account setup and change it. If you do not have screen
shots you
> could try an export or use odbc to look into the XaSyst table
> John Walter | National IS Advisor | Hufcor Pty Ltd
> -----Original Message-----
Behalf Of
> wgoodlive
> Sent: Friday, 17 November 2006 8:04 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] V5.2 Control Accounts
> For some reason we cannot open Control Accounts in the Module
Config in
> one Company. Other Companies are working fine. I have searched
and so
> far I have not located a reason why we can no longer open the
Control
> Accounts. Anyone have any help.
> Thanks, Bill
> IT Dir.
> Maximum Spindle
For some reason we cannot open Control Accounts in the Module Config in
one Company. Other Companies are working fine. I have searched and so
far I have not located a reason why we can no longer open the Control
Thanks, Bill
IT Dir.
Maximum Spindle
One of the GL accts specified in the Control menu could have been
inactivated or deleted. I had to restore an old backup ( to test) and find
which one of the "accounts that we don't use" was deleted. Then it can be
recreate and the menu will open.
David Gartner
EPG Companies Inc.
Vantage 5.20
_____
wgoodlive
Sent: Thursday, November 16, 2006 3:04 PM
Thanks, Bill
IT Dir.
Maximum Spindle
This sounds like one of the accounts set up in the control accounts setup
had been deleted. We had this issue when we were on 5.2, Vantage allows you
to delete an such an account provided there have been no transactions
against it.
I had captured screen shots of the initial setup so locating the offending
account number was easy, then just recreate the account and access the
Control Account setup and change it. If you do not have screen shots you
wgoodlive
Thanks, Bill
IT Dir.
Maximum Spindle
Yahoo! Groups Links
