One new PITA...
When you are in Job Entry or Job Tracker and you want to print
a traveller for a sub assembly... You can't just select it and
print it like v4 did. You have to press the print button then press
the "assembly" button... then unselect everything... then select
the assembly you want... close that screen... then press print.
