V6.0 configurator - toggle box in input screen
In regards to the Progress language, screen-value is a character
string that you can set for display. For example, to set a toggle-
box to show a check mark, the Progress 4GL code would be...
toggle-box-name:screen-value = "yes".
To change the actual value...
toggle-box-name = yes.
You can set the screen value of a widget if you wish, then use the
ASSIGN command to set the actual value from the screen value.
HTH,
Lonnie
--- In vantage@yahoogroups.com, "lindalowney" <llowney@d...> wrote:
> Hello Group,
> I am having a problem turning off a toggle box using the "On Leave"
> formula of another field.
> If field "A" changes then I want to turn off the toggle box in
> field "B."
> I've tried setting it to No and to False, but when I test inputs I
> receive the message "Attribute SCREEN-VALUE for the TOGGLE-BOX has
an
> invalid value of False. (4058)"
> Does anyone know why?
> Regards,
> Linda Lowney
> Decoustics Limited
Hello Group,
field "B."
receive the message "Attribute SCREEN-VALUE for the TOGGLE-BOX has an
Regards,
Linda Lowney
Decoustics Limited
