V6.1 - Email Notifications
Thanks!!! That worked!
_____
Of Aaron Hoyt
Sent: Tuesday, July 12, 2005 11:31 AM
Subject: RE: [Vantage] V6.1 - Email Notifications
Triggering the following (replacing {email address} with your chosen
address) using only the part.inactive field.
If this is not exactly what you need it should be close enough to get
you
there.
Good luck,
Aaron Hoyt
Vantage Plastics
/* Include file for access to global alerts */
{ud/GlbAlert.i &tablename = "Part" }
/* Define Variables */
DEFINE VARIABLE NewEmailBofy AS CHARACTER NO-UNDO.
/* If the Part was not previously inactive cancel, otherwise send email
IF OldPart.Inactive <> True
THEN DO:
Return "Cancel Send":U.
END.
ELSE DO:
ASSIGN Email-To = "{email address}"
Email-Subject = "Part Reactivated"
Email-Text = "Part "
+ string(Part.PartNumber)
+ " has been changed from Inactive to Active.".
END.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Michelle de la Vega
Sent: Tuesday, July 12, 2005 10:42 AM
Subject: [Vantage] V6.1 - Email Notifications
I am trying to write a .p file that only sends an email when the
part.inactive field changes from True to False.
How can I write this?
Any suggestions would be greatly appreciated.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
513-831-3211 ext 400
513-831-1209 fax
www.ColdJet.com
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Michelle,
Below is the script I use, however you will get new parts added also.
Modify to suit your own preferences.
Patrick Winter
Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal 8.5.3.975
/* Program to send a global alert on Reopening a Part
or Inactivating a Part
by Patrick Winter 10/15/2004 */
{ud/GlbAlert.i &TableName = "Part"}
DEFINE VARIABLE NewEmailBody AS CHARACTER NO-UNDO.
IF Part.Inactive = FALSE
THEN DO:
ASSIGN Email-Subject = Part.PartNum + " reopened or new part by " +
USERID.
ASSIGN Email-Text = "Part was reopened.".
END.
ELSE DO:
ASSIGN Email-Subject = Part.PartNum + " inactivated by " + USERID.
ASSIGN Email-Text = "Part was inactivated. sSc MPN: " +
Part.Searchword.
END.
Michelle de la Vega
Sent: Tuesday, July 12, 2005 9:42 AM
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Yahoo! Groups Links
If this is not exactly what you need it should be close enough to get you
there.
Good luck,
Aaron Hoyt
Vantage Plastics
/* If the Part was not previously inactive cancel, otherwise send email */
THEN DO:
END.
ELSE DO:
END.
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Yahoo! Groups Links
