V6.1: Reports from Shop Floor Module
Hi,
Warning, only try on a test account, etc. etc. etc.
If you add entries to the widgetsett table you can get an icon on the
screen altered, similar to the "personalize" and "customize" features
available through the menus.
Just haven't found all of the correct settings, or more probably the
plant floor just plain won't do it. It's awfully close though. It
displays the icon, and new properties, etc. just haven't gotten it fully
functional yet.
You seem to need to use one of the existing "Filler buttons", if you
look through the raw code these are hard coded, along with the
executable, security, etc, so it's entirely probable that it won't work
until we get to 8.x whereby this is supposed to be native.
Anyone else want to give it a throw and see if I'm just not smart enough
to get it over the line?
Take care,
Steve
Of Podlin, Michael
Sent: Monday, September 19, 2005 12:30 PM
Subject: RE: [Vantage] Re: v6.1: Reports from Shop Floor Module
I had a similar app, except it ran as a windowless app with 4-6 buttons
that placed itself on top of the Data Collections screen over the blank
area on top. To assign a command to a button you just had to define the
command line in an INI file. Worked well, but haven't used it in years.
Have to see if I still have it laying around somewhere.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of jeremyrleonard@...
Sent: Monday, September 19, 2005 9:48 AM
Subject: Re: [Vantage] Re: v6.1: Reports from Shop Floor Module
We wrote an Visual Basic 6 Menu form that had Large menu buttons on it.
You could Launch Data Collections from it or other reports/programs. It
is hidden when Data Collections was launched and then made visible when
Data Collections was closed. If there was no activity for 5 minutes
then it relaunched Data Collections.
It was a simple application to write and it worked great. Sorry, I dont
have it anymore or I would share.
Jeremy
Sent: Mon, 19 Sep 2005 14:18:28 -0000
Subject: [Vantage] Re: v6.1: Reports from Shop Floor Module
Our IT Guru is working on programming something of his own to try
and place an icon on the shop floor terminal's desktop that will run
the reports/forms that we need. I'm not sure how, since all I've
heard since I got here 2 years ago is that the ODBC drivers don't
work very well. I think I heard he's doing something with java. I'll
keep you posted. I was just wondering if anyone else had already
tackled this problem and could have saved us a bunch of time and
effort.
Jeff
--- In vantage@yahoogroups.com, "John Mansfield" <johnm@g...> wrote:
> Hi Jeff,
> We would like to do the same thing.
> We have not found a way to do it yet.
> Please let me know if you do.
> Thanks,
> John Mansfield
> General Sheet Metal
Behalf
> Of j_milbrath
> Sent: Friday, September 16, 2005 3:06 PM
> Subject: [Vantage] v6.1: Reports from Shop Floor Module
> Has anyone developed a way to print reports from a terminal/PC
running
> Vantage Shop Floor Module. We developed different versions of
> warehouse pallet tags using Report Builder, but did not envision
that
> we would be rolling out terminals in the shop any time soon. Now
that
> we are going there, we realize the shop floor module has no means
to
> add reports to its menus. How can we print our pallet tags on the
shop
> floor? Full Vantage licenses on the shop floor will not be an
> acceptable solution.
> TIA,
> Jeff Milbrath, CPA
> Controller
> Hartford Finishing, Inc.
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Has anyone developed a way to print reports from a terminal/PC running
warehouse pallet tags using Report Builder, but did not envision that
we would be rolling out terminals in the shop any time soon. Now that
we are going there, we realize the shop floor module has no means to
add reports to its menus. How can we print our pallet tags on the shop
TIA,
Jeff Milbrath, CPA
Controller
If you add a networked printer to the server, they should be able to print
to it. We have the same set up and any printer I have added to the server
can be selected by the terminals....
Hope that helps!
Julie
Mercury Minnesota Inc.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, September 16, 2005 3:05 PM
> TIA,
> Jeff Milbrath, CPA
> Controller
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
Hi Jeff,
John Mansfield
General Sheet Metal
Of j_milbrath
TIA,
Jeff Milbrath, CPA
Controller
Yahoo! Groups Links
Jeff,
I have done similar using a third party label program (Wasp Labeler in my
case) and the Business Activity Manager. I print the tags automatically
based on reporting from the floor. It's not the best alternative, but it
has worked for my application here.
Aaron Hoyt
Vantage Plastics
Of John Mansfield
Sent: Friday, September 16, 2005 5:54 PM
Subject: RE: [Vantage] v6.1: Reports from Shop Floor Module
Hi Jeff,
John Mansfield
General Sheet Metal
Of j_milbrath
TIA,
Jeff Milbrath, CPA
Controller
Yahoo! Groups Links
Yahoo! Groups Links
Thanks Julie, but the printer is not the problem. It's that Vantage
Shop Floor Version (less expensive license with "simpler" interface)
currently does not have the ability to run any reports, at least fom
what I have been told. Or, you cannot add any custom report builder
reports to the menu as you can with the full version of Vantage 6.1.
Jeff
--- In vantage@yahoogroups.com, "Julie Lehmann" <jlehmann@m...>
to print
the server
> Hope that helps!
> Julie
> From: "j_milbrath" <jeffrey.milbrath@h...>
running
that
that
means to
the shop
> > TIA,
> > Jeff Milbrath, CPA
> > Controller
You must
access. )
Builder and
> > Yahoo! Groups Links
effort.
Jeff
> Hi Jeff,
> Thanks,
> John Mansfield
> General Sheet Metal
Behalf
> Of j_milbrath
running
that
that
to
shop
> TIA,
> Jeff Milbrath, CPA
> Controller
must
access. )
Builder
> Yahoo! Groups Links
We wrote an Visual Basic 6 Menu form that had Large menu buttons on it. You could Launch Data Collections from it or other reports/programs. It is hidden when Data Collections was launched and then made visible when Data Collections was closed. If there was no activity for 5 minutes then it relaunched Data Collections.
It was a simple application to write and it worked great. Sorry, I dont have it anymore or I would share.
Jeremy
effort.
Jeff
> Hi Jeff,
> Thanks,
> John Mansfield
> General Sheet Metal
Behalf
> Of j_milbrath
running
that
that
to
shop
> TIA,
> Jeff Milbrath, CPA
> Controller
must
access. )
Builder
> Yahoo! Groups Links
Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
Yahoo! Groups Links
Ah, sorry, I know what you are saying now. I was thinking of just the
terminal set-up, not the shop floor version.
Could you use a general log-in for those that would need to print the tags?
One with limited rights so they would just login long enough to print and
then exit? I suppose it depends on your set-up and how much of a hassle
that would be with the users that do the printing...
Julie
Sent: Monday, September 19, 2005 9:03 AM
> Jeff
> to print
> the server
> > Hope that helps!
> > Julie
> running
> that
> that
> means to
> the shop
> > > TIA,
> > > Jeff Milbrath, CPA
> > > Controller
> You must
> access. )
> Builder and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
I had a similar app, except it ran as a windowless app with 4-6 buttons that placed itself on top of the Data Collections screen over the blank area on top. To assign a command to a button you just had to define the command line in an INI file. Worked well, but haven't used it in years. Have to see if I still have it laying around somewhere.
Jeremy
effort.
Jeff
> Hi Jeff,
> Thanks,
> John Mansfield
> General Sheet Metal
Behalf
> Of j_milbrath
running
that
that
to
shop
> TIA,
> Jeff Milbrath, CPA
> Controller
must
access. )
Builder
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
