V6.1: SQL Server and Record Locking
It works great.
Jeremy
Sent: Tue, 14 Mar 2006 11:42:10 -0500
Subject: Re: [Vantage] V6.1: SQL Server and Record Locking
I will try that. Thanks
Sent: Tue, 14 Mar 2006 09:03:49 +0200
Subject: RE: [Vantage] V6.1: SQL Server and Record Locking
If you are using SQL Commands write the statement with (nolock).
Stelios Zoumis
Senior ERP Consultant
Financial Products & Solutions Department
ATC S.A.
Tel: +30 210 6874300
Fax: +30 210 6874321
10, Rizariou str, 152 33
Halandri, Athens, GREECE
E-mail <<<mailto:s.zoumis@... <BLOCKED::mailto:s.zoumis@...> >>>
This e-mail correspondence is confidential and intended for the named
recipient(s) only. The information contained in this e-mail and any
attachments may be confidential and/or protected by copyright. If the
reader of this e-mail is not intended recipient or the person
responsible for delivering it to the intended recipient, any copying,
distribution, publication or other use of, or taking of any action in
reliance upon, this e-mail is strictly prohibited. Should you have
received this e-mail in error, you are requested to notify ATC S.A. and
to delete this message and any attachments imm
Of jeremyrleonard@...
Sent: Monday, March 13, 2006 8:04 PM
Subject: [Vantage] V6.1: SQL Server and Record Locking
Hello,
I'm working on the test conversion from a Progress to SQL Database and I
have run into a snag.
As an example, if I am in the Order Dtl screen entering a line, I have a
button you can click on that shows the stock status of the part you just
entered. My problem is, with the SQL database, the record is locked so
the stock status times out or is not availabe till I exit the Order Dtl
screen.
Anyone else run into this and maybe have a work around?
I have duplicated the results with ADO in Visual Basic in read only mode
and in SQL Query Analizer.
I would also have a problem if I was running a custom stock status
report for all parts and someone was in an Order Dtl line. The report
would hang until the record is released. I didn't have this issue with
the Progress database. Progress seems to do a better job of releaseing
the record. I normally wouldnt have this problem with SQL Server. I
think its the Dataserver product.
Any advice would be great.
Jeremy
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
Yahoo! Groups Links
Yahoo! Groups Links
Hello,
I'm working on the test conversion from a Progress to SQL Database and I have run into a snag.
As an example, if I am in the Order Dtl screen entering a line, I have a button you can click on that shows the stock status of the part you just entered. My problem is, with the SQL database, the record is locked so the stock status times out or is not availabe till I exit the Order Dtl screen.
I have duplicated the results with ADO in Visual Basic in read only mode and in SQL Query Analizer.
I would also have a problem if I was running a custom stock status report for all parts and someone was in an Order Dtl line. The report would hang until the record is released. I didn't have this issue with the Progress database. Progress seems to do a better job of releaseing the record. I normally wouldnt have this problem with SQL Server. I think its the Dataserver product.
Jeremy
Stelios Zoumis
ATC S.A.
Hello,
screen.
Jeremy
SPONSORED LINKS
YAHOO! GROUPS LINKS
Stelios Zoumis
ATC S.A.
Hello,
screen.
Jeremy
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Groups Links
