V701 or any Version - Issues with Engineering Workbench Tree Exp
We have found the same thing on .701 the work around i have found is to use express part checkout for opening bill's. it has added a few clicks to get into the bill but it dose not hang up when you try to expand the tree
Jim Proteau
--- In vantage@yahoogroups.com, "Winter, Patrick" <pjw@...> wrote:
> Just a couple of side notes, WINDOWS KEY plus * will expand the full
> tree, WINDOWS KEY plus MINUS KEY will collapse the tree. Also I have
> found in one instance creating a new ECO group for a user help
> performance but I have not confirmed this as an issue/bug etc...
> Patrick Winter
> Of jkig77
> Sent: Saturday, February 23, 2013 09:55
> To: vantage@yahoogroups.com
> Subject: [Vantage] v701 or any Version - Issues with Engineering
> Workbench Tree Expanding
> Hello All - looking for any insight as were still haveing issues with
> large boms expanding/collapsing (4-6mins) in the tree viewer with
> engineering workbench. Epicor Tech support cant figure this out and it
> started when we first started to implement this software in v607. Now
> were is v701 and were a month from GoLive and the issue still exists.
> Any tribal knowledge out there that can help us pin point down this
> issue?
> We have BOM's that range from 1-10,000 lines and up to 20 levels deep.
> Thanks in advance,
> Josh Gardner
> AIT/UCT 480-940-0036 x299
> jgardner@... <mailto:jgardner%40uct.com>
Hello All - looking for any insight as were still haveing issues with large boms expanding/collapsing (4-6mins) in the tree viewer with engineering workbench. Epicor Tech support cant figure this out and it started when we first started to implement this software in v607. Now were is v701 and were a month from GoLive and the issue still exists.
Any tribal knowledge out there that can help us pin point down this issue?
Thanks in advance,
Josh Gardner
jgardner@...
>>Now were is v701
>>having issues with large boms expanding/collapsing (4-6mins)
As far as I know, expanding and collapsing the treeview has been slow in versions V8 thru E905.
Are you saying it only slowed down when you upgraded?
I work with slightly smaller BOMs than you describe.
10 levels deep with 2,000 to 3,000 items.
They will include a mix of subassemblies, raw materials and parts with methods.
I avoid using the "Expand Tree" and Collapse Tree" menu items when I have a part with a large BOM loaded.
I don't think this is specific to the engineering workbench, but with treeviews in general. I've heard of response issues in the customer treeview when there are lots of ShipTo's.
> Thanks in advance,
> Josh Gardner
> jgardner@...
10k items seems crazy I say count your blessings that it only takes a few
minutes
> >>Now were is v701
> methods.
> issue?
> > Thanks in advance,
> > Josh Gardner
> > jgardner@...
It is an issue in 701 and not just with large boms.
The performance can be alleviated with new, clean ECO group.
An SCR 84131 tried to address the speed in 701 but it looks like they have actually made it worse in some instances.
Also at 701 there is a bug with the Part business object.
If you have any PartBinInfo records in the system, all of them will be returned when you pull up just one part. This should be fixed in 702.
You can fix it with a BPM though if you need to.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jkig77
Sent: 23 February 2013 15:55
Subject: [Vantage] v701 or any Version - Issues with Engineering Workbench Tree Expanding
Thanks in advance,
Josh Gardner
jgardner@...<mailto:jgardner%40uct.com>
Patrick Winter
Of jkig77
issue?
Thanks in advance,
Josh Gardner
