V8 Auto-populate customization
The native code is part of the form that you can't get to. If you
are using customization you can insert code on the field changed
event.
--- In vantage@yahoogroups.com, "swinky68" <rcole@...> wrote:
> Hi everybody,
> I'm trying to figure out the code that auto-populates one field
from
> another field's contents. For example, in Order Entry, when you
enter
> the Need By and Ship By dates, these go down to each line of the
> order. If you change them on the Summary tab, you'll get a box
asking
> if you want to propagate those changes to all of the Lines &
Releases.
> I need to do the same thing with a custom field that gets entered
and
> populated for each line of the order. Who can help me out?
> Thanks,
> Ron Cole
> IT Manager, IED Inc.
> rcole@...
Hi everybody,
I'm trying to figure out the code that auto-populates one field from
another field's contents. For example, in Order Entry, when you enter
order. If you change them on the Summary tab, you'll get a box asking
if you want to propagate those changes to all of the Lines & Releases.
I need to do the same thing with a custom field that gets entered and
Ron Cole
rcole@...
