V8 - Show Pegging Info on Traveller
We are running Vantage 6.10, but without MRP. What we did was add a subreport in the report header linking the jobasmbl.jobnum to the subreport's jobprod.jobnum. This table contains the TargetJobNum, TargetAssemblySeq and TargetMtlSeq which you are looking for.
Dean Mortera
Network Administrator
Air Industries Machining Corp.
A Wholly-Owned Subsidiary of Gales Industries
Tel:Â 631-328-7027
Fax: 631-968-5377
I am just about to embark on the process of trying to add the multi-
level pegging info onto the traveller. Basic idea being that even
though we are using MRP to consolidate demand we want to tell the
person at the last operation which jobs require the product.
Anyone done this already?
Gavin
By Pegging Info do you mean where to the detail parts go in the Next
Higher Assembly? Our terminologies might be different.
Dean Mortera
Tel: 631-328-7027
Fax: 631-968-5377
Yes. We are using MRP to consolidate but then Vantage lists the
demand as being stock (we are using days of supply = 14) while it is
actually from other jobs.
I want to list the higher level jobs on the lower level traveller.
--- In vantage@yahoogroups.com, "Dean Mortera" <dean.mortera@...>
> Dean Mortera
> Tel: 631-328-7027
> Fax: 631-968-5377
