V8.x Bar Codes Blank Title 56416
I have been through the manual, 400 pages, and there is a chapter on
programming along with dozens of pages of barcodes to scan but there is
no barcode for a TAB.
As for the Enter as Tab, I was discussing a way to make hot keys
standard for all users without logging on to every user and setting them
manually. Their reply was only the settings on the Global Options/Hot
Keys tab will apply to all users.
I will try the Enter as Tab route, perhaps they are wrong.
Todd
Of Jeremy Jackson
Sent: Thursday, April 19, 2007 4:17 PM
Subject: [Vantage] Re: v8.x Bar Codes
You should be able to program the scanner to add a tab at the end of
the barcode scan. You do this by "programming" the scanner from
barcodes that came with the manual for the scanner
We use PSC PowerScanner wands and they came with a program manual
that contains the barcodes to program..
I dont think setting the Handle (Enter) as Tab to true affects all
users...I think it is a personalization thing...I will check it out
though...
Jeremy Jackson
WaterFurnace International
"Paul V. Blais" <pblais@...> wrote:
> First
> For a bar code scan I have
> $M for return
> $I for tab
> Second
> Enter as tab is per individual user but in "all screens" not, "all
> users."
Behalf
> Of Todd Hofert
> Sent: Thursday, April 19, 2007 2:29 PM
> Subject: [Vantage] v8.x Bar Codes
> I apologize for asking about this again. I know it has been covered
and
> I have been searching through my list archive feverishly for the
last
> half hour but cannot find it. I want to require our vendors to
barcode
> our PO, PO Line, the pack slip number and quantity data on their
> label/pack slip so we can use a scanner to perform PO receipts.
> Initially I thought I could simply program a post amble 'ENTER'
into the
> scanner so the cursor would advance to the next field and the next
> barcode could be scanned. Then it occurred to me that V8 will only
take
> a TAB to advance to the next field. OK, first thought is go to
Options
> and set the checkbox to use ENTER as TAB. Problem here is Epicor
stuck
> this feature on the Global Hot Keys tab so checking it affects ALL
> users. I can't do that. Next obvious avenue is to program a TAB as
the
> post amble character. Can't find a way to do that.
> Is anyone doing this successfully, scanning barcodes and advancing
to
> next field without user having to press the keyboard TAB key? If so,
> how?
> If it is necessary to bury the TAB in the barcode, what is the
syntax to
> accomplish that?
> Thank You
> Todd Hofert
> This e-mail and any attachments may contain confidential and
privileged
> information. If you are not the intended recipient, please notify
the
> sender immediately by return e-mail, delete this e-mail and destroy
any
> copies. Any dissemination or use of this information by a person
other
> than the intended recipient is unauthorized and may be illegal.
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
I apologize for asking about this again. I know it has been covered and
I have been searching through my list archive feverishly for the last
half hour but cannot find it. I want to require our vendors to barcode
Initially I thought I could simply program a post amble 'ENTER' into the
barcode could be scanned. Then it occurred to me that V8 will only take
a TAB to advance to the next field. OK, first thought is go to Options
and set the checkbox to use ENTER as TAB. Problem here is Epicor stuck
users. I can't do that. Next obvious avenue is to program a TAB as the
Is anyone doing this successfully, scanning barcodes and advancing to
how?
If it is necessary to bury the TAB in the barcode, what is the syntax to
accomplish that?
Thank You
Todd Hofert
First
$M for return
$I for tab
Second
users."
Of Todd Hofert
how?
accomplish that?
Thank You
Todd Hofert
though...
Jeremy Jackson
--- In vantage@yahoogroups.com, "Paul V. Blais" <pblais@...> wrote:
> First
> $M for return
> $I for tab
> Second
> users."
Behalf
> Of Todd Hofert
and
last
barcode
into the
take
Options
stuck
the
to
> how?
syntax to
> accomplish that?
> Thank You
> Todd Hofert
privileged
the
any
other
I set my Handel Enter as Tab to true and went and checked on another
system and the enter key would not send me to the next text box - so
this feature is local to the machine.
Jeremy
--- In vantage@yahoogroups.com, "Jeremy Jackson" <jeremy_jackson@...>
of
> though...
> Jeremy Jackson
> --- In vantage@yahoogroups.com, "Paul V. Blais" <pblais@> wrote:
> > First
> > $M for return
> > $I for tab
> > Second
> > users."
> Behalf
> > Of Todd Hofert
covered
> and
> last
> barcode
> into the
only
> take
> Options
> stuck
as
> the
advancing
> to
so,
> > how?
> syntax to
> > accomplish that?
> > Thank You
> > Todd Hofert
> privileged
> the
destroy
> any
> other
