Yes, the data source for your SSRS reports just needs to point to your
replicated SQL database.
--- In vantage@yahoogroups.com, "nustepvantage" <dpfiester@...> wrote:
> If you are running Progress and replicating to SQL in Epicor 9.05 can
SSRS reports with data from the replicated SQL database be attached to
the Epicor 9.05 menu and run from there? Or do you need to be running on
SQL instead of Progress?
> Thanks,
> David
