Value cannot be null. (Parameter 'fromItem') - Customer Shipment Shipped from BPM
When trying to check the Shipped checkbox in Customer Shipment Entry from BPM, below error is coming only for the BPM not on the Customization or Kinetic Layer
Server Side Exception
BPM runtime caught an unexpected exception of 'ArgumentNullException' type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Correlation ID:  70d55e2d-18aa-4185-b93b-526a8a38d989
Description:  BPM runtime caught an unexpected exception of 'ArgumentNullException' type.
Program:  Epicor.ServiceModel.dll
Method:  GetRowCopier
Line Number:  365
Column Number:  17
Original Exception Type:  ArgumentNullException
Server Trace Stack:     at Epicor.Data.BufferCopy.GetRowCopier(Object fromItem, Object toItem, Boolean fullRowCopy) in C:\_releases\ICE\ICE4.2.200.11\Source\Shared\Framework\Epicor.ServiceModel\Data\BufferCopy.cs:line 365
   at Epicor.Data.BufferCopy.Copy[TTypeTo](Object fromItem, TTypeTo& toItem) in C:\_releases\ICE\ICE4.2.200.11\Source\Shared\Framework\Epicor.ServiceModel\Data\BufferCopy.cs:line 189
   at Erp.Services.BO.CustShipSvc.UpdateMaster(CustShipTableset& ds, Boolean doValidateCreditHold, Boolean doCheckShipDtl, Boolean doLotValidation, Boolean doCheckOrderComplete, Boolean doPostUpdate, Boolean doCheckCompliance, Boolean ipShippedFlagChanged, Int32 ipPackNum, Int32 ipBTCustNum, String& opReleaseMessage, String& opCompleteMessage, String& opShippingMessage, String& opLotMessage, String& opInventoryMessage, String& opLockQtyMessage, String& opAllocationMessage, String& opPartListNeedsAttr, String& opLotListNeedsAttr, String& shipCreditMsg, Boolean& cError, Boolean& compError, String& msg, String& opPostUpdMessage, Boolean& updateComplete, Boolean& checkComplianceError, Boolean& changeStatusError, Boolean& checkShipDtlAgain) in C:\_releases\ERP\ERP11.2.200.11\Source\Server\Services\BO\CustShip\CustShip.cs:line 28974
   at Epicor.Customization.Bpm.BO.UpdateMasterImpl.ExecuteBase(UpdateMasterParameters parameters)
   at Epicor.Customization.Bpm.MethodCustomizationBase2`2.RunDirectives(TParam parameters) in C:\_releases\ICE\ICE4.2.200.11\Source\Server\Internal\Lib\Epicor.Customization.Bpm\MethodCustomizationBase2.cs:line 177
   at Epicor.Customization.Bpm.CustomizationBase2`2.Execute(TParam parameters) in C:\_releases\ICE\ICE4.2.200.11\Source\Server\Internal\Lib\Epicor.Customization.Bpm\CustomizationBase2.cs:line 98
   at Epicor.Customization.Bpm.BO.CustShipSvcCustomization.UpdateMaster(CustShipTableset& ds, Boolean doValidateCreditHold, Boolean doCheckShipDtl, Boolean doLotValidation, Boolean doCheckOrderComplete, Boolean doPostUpdate, Boolean doCheckCompliance, Boolean ipShippedFlagChanged, Int32 ipPackNum, Int32 ipBTCustNum, String& opReleaseMessage, String& opCompleteMessage, String& opShippingMessage, String& opLotMessage, String& opInventoryMessage, String& opLockQtyMessage, String& opAllocationMessage, String& opPartListNeedsAttr, String& opLotListNeedsAttr, String& shipCreditMsg, Boolean& cError, Boolean& compError, String& msg, String& opPostUpdMessage, Boolean& updateComplete, Boolean& checkComplianceError, Boolean& changeStatusError, Boolean& checkShipDtlAgain)
   at Erp.Services.BO.CustShipSvcFacade.UpdateMaster(CustShipTableset& ds, Boolean doValidateCreditHold, Boolean doCheckShipDtl, Boolean doLotValidation, Boolean doCheckOrderComplete, Boolean doPostUpdate, Boolean doCheckCompliance, Boolean ipShippedFlagChanged, Int32 ipPackNum, Int32 ipBTCustNum, String& opReleaseMessage, String& opCompleteMessage, String& opShippingMessage, String& opLotMessage, String& opInventoryMessage, String& opLockQtyMessage, String& opAllocationMessage, String& opPartListNeedsAttr, String& opLotListNeedsAttr, String& shipCreditMsg, Boolean& cError, Boolean& compError, String& msg, String& opPostUpdMessage, Boolean& updateComplete, Boolean& checkComplianceError, Boolean& changeStatusError, Boolean& checkShipDtlAgain) in C:\_releases\ERP\ERP11.2.200.11\Source\Server\Services\BO\CustShip\CustShipSvcFacade.cs:line 5384
   at Epicor.Customization.Bpm.BO.GetaNewUD03PostProcessingDirective_CreatePart_EE5EE14C7F2C4D829D97EEB6D8D1C6CC.<>c__DisplayClass7_0.<A001_CustomCodeAction>b__0(CustShipSvcContract CustShipBO)
   at Epicor.Customization.Bpm.DirectiveBase`2.CallService[TService](Action`1 action) in C:\_releases\ICE\ICE4.2.200.11\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.Plugins.cs:line 360
   at Epicor.Customization.Bpm.BO.GetaNewUD03PostProcessingDirective_CreatePart_EE5EE14C7F2C4D829D97EEB6D8D1C6CC.A001_CustomCodeAction()
   at Epicor.Customization.Bpm.BO.GetaNewUD03PostProcessingDirective_CreatePart_EE5EE14C7F2C4D829D97EEB6D8D1C6CC.ExecuteCore(Int32 step)
   at Epicor.Customization.Bpm.DirectiveBase`2.Execute() in C:\_releases\ICE\ICE4.2.200.11\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.cs:line 330
   at Epicor.Customization.Bpm.DirectiveBase`2.Execute(TParam parameters) in C:\_releases\ICE\ICE4.2.200.11\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.cs:line 222
Client Stack Trace
   at Ice.Cloud.ProxyBase`1.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
   at Ice.Cloud.ProxyBase`1.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
   at Ice.Cloud.ProxyBase`1.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
   at Ice.Proxy.BO.UD03Impl.GetaNewUD03(UD03DataSet ds)
   at Ice.Adapters.UD03Adapter.GetaNewUD03()
   at Ice.UI.App.UD03Entry.Transaction.AdapterGetNew()
   at Ice.UI.Shared.UDSupport.UDSingleViewTransaction.GetNew()
Inner Exception
Appears to be: null value during a copy operation probably of a BPM parameter ‘fromItem’ during access of UD03 and possibly within a customization. Most of the debugging information is in the trace to get you started, but just a guess with this bit of information.
Error is only coming from the Function and the BPM
Same code is working in Customization and in Kinetic Layer
Clint already told you lol.
Let’s see the code.
Looks like your input object is null on a BufferCopy.
Below is the code
int ReqiPackNum = 137295;
string strMsg = "CustomerShipmentShipped " + ReqiPackNum + " " + DateTime.Now + Environment.NewLine;
int iCustNum = 0 ;
string stropWarnMessage = "" ;
string stropAskMessage = "" ;
string stropStopMessage = "" ;
int lineNum = 0 ;
bool  belongToAnotherPC = false ;
string strpcOutsideMessage = "";
string stropReleaseMessage = "";
string stropCompleteMessage = "" ;
string stropShippingMessage = "";
string stropLotMessage = "";
string stropInventoryMessage = "";
string stropLockQtyMessage = "";
string stropAllocationMessage = "";
string stropPartListNeedsAttr = "";
string stropLotListNeedsAttr = "";
string strshipCreditMsg = "";
bool blncError = false;
bool blncompError = false ;
string strmsg = "";
string stropPostUpdMessage = "";
bool blnupdateComplete = true ;
bool blncheckComplianceError = false ;
bool blnchangeStatusError = false ;
bool blncheckShipDtlAgain = false ;
this.CallService<Erp.Contracts.CustShipSvcContract>(CustShipBO => {
    Erp.Tablesets.CustShipTableset CustShipTS = CustShipBO.GetByID(ReqiPackNum);
    var vtsShipHead = CustShipTS.ShipHead.FirstOrDefault(xRow => xRow.Company == Session.CompanyID && xRow.PackNum == ReqiPackNum);
    if(vtsShipHead != null)
      strMsg += " CustNum: " + vtsShipHead.CustNum + ", ReadyToInvoice: " + vtsShipHead.ReadyToInvoice + Environment.NewLine;
      iCustNum = vtsShipHead.CustNum;
      vtsShipHead.ReadyToInvoice = true;
      vtsShipHead.RowMod  = "U" ;
    CustShipBO.CheckPCBinOutLocation(ref CustShipTS, out lineNum, out belongToAnotherPC, out strpcOutsideMessage);
    vtsShipHead = CustShipTS.ShipHead.FirstOrDefault(xRow => xRow.Company == Session.CompanyID && xRow.RowMod == "U");
      strMsg += " ShipStatus: " + vtsShipHead.ShipStatus + ", ReadyToInvoiceChanged: " + vtsShipHead.ReadyToInvoiceChanged + ", Credit: " + vtsShipHead.CreditCardMessage + Environment.NewLine;
      vtsShipHead.ShipStatus = "SHIPPED";
      vtsShipHead.ReadyToInvoiceChanged  = true;
      vtsShipHead.SlipStatus = "SHIPPED";
      vtsShipHead.SendShipment = true;
      vtsShipHead.RowMod = "U";
    strMsg += " Bef UpdateMaster " + Environment.NewLine;
    CustShipBO.UpdateMaster(ref CustShipTS, false, true, false, true, true, false, true, ReqiPackNum, iCustNum, out stropReleaseMessage, out stropCompleteMessage, out stropShippingMessage, out stropLotMessage, out stropInventoryMessage, out stropLockQtyMessage, out stropAllocationMessage, out stropPartListNeedsAttr, out stropLotListNeedsAttr, out strshipCreditMsg, out blncError, out blncompError, out strmsg, out stropPostUpdMessage, out blnupdateComplete, out blncheckComplianceError, out blnchangeStatusError, out blncheckShipDtlAgain);
    strMsg += " Aft UpdateMaster " + Environment.NewLine;
I see no reference to Buffer Copy. You sure this is the offending code?
Also, are you sure that CustShipBO.CheckPCBinOutLocation doesnt clear your RowMod?
CustShipBO.CheckPCBinOutLocation doesn’t clear the RowMod
Tried using BufferCopy. Still getting the same error
int ReqiPackNum = 137299;
try
  int iCustNum = 0 ;
  int lineNum = 0 ;
  string strmsg = "";
      Erp.Tablesets.CustShipTableset CustShipOriginalTS = CustShipBO.GetByID(ReqiPackNum);
      Erp.Tablesets.CustShipTableset CustShipTS = new Erp.Tablesets.CustShipTableset();
      var newRow = CustShipTS.ShipHead.NewRow();
      BufferCopy.Copy(CustShipOriginalTS.ShipHead[0], newRow);
      CustShipTS.ShipHead.Add(newRow);
  InfoMessage.Publish(Environment.NewLine + strMsg);
catch(Exception ex)
  InfoMessage.Publish(Environment.NewLine + strMsg + Environment.NewLine + "Error at: " + ex.Message);
Does anyone have a fix for this?
Did you validate you had data being returned from the GetByID?
Check if the data exists before trying to copy it.
var originalShipHeadRow = CustShipOriginalTS.ShipHead.FirstOrDefault();
if (originalShipHeadRow != null)
    BufferCopy.Copy(originalShipHeadRow, newRow);
else
    // Throw error.......
Pretty much was my thinking…
Yes, data is returning from the GetByID.
Error is coming when the UpdateMaster is called
@aarong Tried your code. Still getting the same error.
https://www.epiusers.help/t/value-cannot-be-null-fromitem-in-buffercopy-getrowcopier/95077
They are saying error is coming because of the credit card issue
Can someone explain this
You show different pieces of code and not possibly the corresponding error to said code. This makes it difficult to assist in your issue, but I would start by examining that you have actual data present to work with here:
    // vvv this line looked to be the other error you posted and could have had null data again in your CustShipTS
or
I stand by my question did you validate you have appropriate DATA in those Tablesets?
As @aarong suggested, I tried using the BufferCopy to fix the error.
Both of my codes are identical except for the fact that one includes Buffer Copy and the other does not.
Tablesets contain the appropriate data. The UpdateMaster is where the error is consistently appearing.
