My understanding is that SBS will only support one PDC, and that any
other server would need to be demoted. At the Minneapolis 8.0 road show
I asked Epicor why SBS was not recommended. Nobody knew I am still
awaiting an answer. I suspect they have bigger issues to focus on with
8.0.
Dan Shallbetter
States Electric Mfg.
SBS 2003 & Vantage 5.0
Of Calvin Dekker
Sent: Friday, July 08, 2005 7:53 AM
Subject: RE: [Vantage] Re: Vantage 4.0 on NT4 running alongside Windows
Server 2003
Jonathan -
If you're changing domain names. Leave the NT4 as is.
Let SBS be the pdc of the new domain. You can run to
two domains with two pdc's - one for each. If you'll
be running DCHP on the new SBS server, just reserve an
IP address for your Vantage NT4 box.
We are running Vantage 3 (on NT4) and Vantage 8 (on 2k3),
each is its own pdc, with two domains. Runs fine.
HTH,
Calvin
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of jonnyfatman666
Sent: Friday, July 08, 2005 7:28 AM
Subject: [Vantage] Re: Vantage 4.0 on NT4 running alongside Windows
Server 2003
Thanks for your quick reply.
The reason we are splitting the servers is that firstly, Epicor don't
recommend running Vantage on SBS. Secondly, if anything needs doing
to the vantage server, ie a reboot or patch install, nobody can
access their files or email if the server goes offline.
Currently, the nt4 server is set up as a domain controller although
none of the XP machines authenticate to it and sit on a workgroup of
the same name as the domain.
We recently changed the name of the company and will also be changing
the domain name on the new setup.
There's a lot of impending change, so I want to make sure I'm
prepared for all eventualities!
Jonathan
8.0.
Dan Shallbetter
Of Calvin Dekker
Server 2003
Jonathan -
HTH,
Calvin
Of jonnyfatman666
Server 2003
Jonathan
--- In vantage@yahoogroups.com, "MATT FINN" <matt@s...> wrote:
> Jonathan, the short answer is no......assuming that your NT4 is a
domain
> controller. SBS will not co-exist with another DC and from my
research
> you cannot demote a DC to a member server.....you would have to
> re-install. I do have a question. Why do you feel you need a
second
> server to run Vantage? What will you have on your SBS box?
> Matt
Behalf
> Of jonnyfatman666
> Sent: Friday, July 08, 2005 3:26 AM
> Subject: [Vantage] Vantage 4.0 on NT4 running alongside Windows
Server
> 2003
> We are intending upgrading our single server (P3 450MHz 256MB RAM)
to
> newer models running SBS2003 on one and Windows 2003 basic on
another.
> The Windows 2003 one will eventually run Vantage 6.x or 8, but in
the
> mean time, will we be able to connect our old server to the network
so
> that everyone can still use Vantage 4?
> Cheers,
> Jonathan
