The dbf files will normally go to the Vantage work directory in V4. Try
looking in C:\Vntgwork or what ever you named you
Vantage working directory.
Dave Cole
Sent: Tuesday, August 01, 2000 9:59 AM
To: vantage@egroups.com
Subject: Re: [vantage][4.0] Packing slip
Oleg,
Are you sure your dbf files are in the c:\temp\directory?? You may need to
set the location to another directory. Mine are stored in c:\vntgwork
Directory. (To change them - Go to Database - Set Location)
I hope this helps.
Dina
Chris Reed wrote:
<http://click.egroups.com/1/7748/13/_/411782/_/965141915/>
<http://adimg.egroups.com/img/7748/13/_/411782/_/965141915/blackgreenflash_n
ew2.gif>
_____
<http://www.egroups.com/files/vantage/>
Dave Cole
Oleg,
I hope this helps.
Dina
Chris Reed wrote:
> Hi Olegneed
> I assume the error occurs when trying to preview in Crystal, if so you
> to run the report (preview) in Vantage to create the .dbf locally.right
> HTH
> Chris Reed
> PWSL
> From: Oleg Tumarkin <otumarkin@...>
> To: <vantage@egroups.com>
> Sent: Monday, July 31, 2000 5:06 PM
> Subject: RE: [vantage][4.0] Packing slip
> > I've followed the instructions abot setting Crystal to point to the
> > database. And got an error message "File could not be found: 'shiphead',_____
> at
> > file location: "c:\temp\shiphead.dbf""
> > Any suggestions?
ew2.gif>
_____
