Vantage .400 - CR paramerter prompt or?
Same here, previewing does NOT fix the problem. Only installing the
full client allows it to prompt fully.
--- In vantage@yahoogroups.com, "hoomail4me" <hoomail4me@...> wrote:
> Thanks for the feedback Dave,
> If nothing else at least I know that we are not the only one having
> this problem. Epicor always makes it seem that we are unique with
our
> Vantage issues.
> Did you talk to Epicor on this?
> Note, "previewing" does not fix our problem, will still get an error
> when it gets to the CR prompt. I will install the CR development
> software to test as a work around. It may work as I personally
don't
> have the problem on my development computer.
> Bill
> --- In vantage@yahoogroups.com, "Dave Olender" <dolender@> wrote:
> > Mr. Bill: What we found is that if you Preview the report first
then
> > the Crystal prompts display normally. If you just try to print
> > direct then you get the error.
> > I have seen other threads here that suggest installing the
Crystal
> > developement software on the client and then downloading and
> > installing the latest Crystal runtime fixes (works around) the
> > problem. However, for now I have asked our people to just print
> > preview the report first and then print from the preview window.
> > It may be a band aide, but I don't see a fix comming anytime soon
> > from Epicor.
> > Good Luck,
> > Dave Olender
> > --- In vantage@yahoogroups.com, "hoomail4me" <hoomail4me@> wrote:
> > > On .305K I had a custom job traveler that would print
> > by "operation".
> > > Through a Crystal Reports parameter prompt it would present the
> > > operation numbers of the job and the user could select the
desired
> > > operation to print.
> > > This fails on .404a with a ActiveX control error - something to
do
> > > with "...is not a single-threaded apartment".
> > > Is anyone else prompting with a Crystal Report parameter prompt
at
> > > report runtime on .400?
> > > Is there another way to prompt at runtim for input with
a "Report
> > > Definition" based "Report Sytle" report?
> > > Thanks,
> > > Bill
On .305K I had a custom job traveler that would print by "operation".
operation numbers of the job and the user could select the desired
operation to print.
This fails on .404a with a ActiveX control error - something to do
Is anyone else prompting with a Crystal Report parameter prompt at
Is there another way to prompt at runtim for input with a "Report
Bill
Mr. Bill: What we found is that if you Preview the report first then
I have seen other threads here that suggest installing the Crystal
from Epicor.
Good Luck,
Dave Olender
by "operation".
> operation to print.
> Thanks,
> Bill
this problem. Epicor always makes it seem that we are unique with our
Vantage issues.
software to test as a work around. It may work as I personally don't
Bill
> from Epicor.
> Good Luck,
> Dave Olender
> by "operation".
> > operation to print.
> > Thanks,
> > Bill
