leAnn,
Make sure that the relevant record IDs match in both companies. I had this when I used two different identifiers for 'Company Truck' when I set up multi-company.
Then, after you've reviewed the details [or at least brought up the detail tab], you can check the box for 'Accept'. At least, that's how I recall doing it. I'm in the middle of something else at the moment and don't have Vantage up to double check.
I hope this helps.
Lynn Thomas
Senior Engineer
SAIC
317-357-4041 X255
I hope this helps.
Lynn Thomas
Senior Engineer
SAIC
317-357-4041 X255
