Please elaborate on what hardware / software requirements will be needed for
SQL. Also will it run under Microsoft's Small Business Server 4.5?
H. Dale Puls
Pacesetter Electronics
mholton@...]
Sent: Monday, October 02, 2000 1:22 PM
To: '
vantage@egroups.com'
Subject: RE: [Vantage] Vantage 5.0 Hardware
No we have not, but from what I hear, it will not change from what was
required for 4.0, unless you are planning on going to the SQL Version.
Michael Holton
e p i c o r S o f t w a r e
Customer Account Manager
Manufacturing Systems
(800)638-3208 Ext. 5242
www.epicor.com
ssanders@...]
Sent: Monday, October 02, 2000 1:02 PM
To:
vantage@egroups.com
Michael,
Thanks for the information!
Has Epicor put together a minimum/recommended hardware configuration for the
client yet?
Steve Sanders
Delta Centrifugal Corp.
mholton@...]
Sent: Monday, October 02, 2000 9:23 AM
To: '
Cario uses Progress v9.1b
Michael Holton
www.epicor.com
Has anyone heard what the hardware recommendations are for the next
version
of Vantage are going to be? We've got people on the list concerned about
running 4.0 on their current hardware and 5.0 should be on its way; it
might
be a good idea to keep that in mind.
I'd also be interested to know if the next version of Vantage is written
in
Progress v9.1 (which supports Windows 2000 Server).
Any beta-testers willing to share their thoughts??
Steve Sanders
please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
