Vantage 5.1 db limit
Give it a five minutes or so before you clear that lock file. Sometimes
progress does a bit of cleanup after you turn it off.
On Wed, Sep 14, 2011 at 5:17 PM, Zac Jason Woodward <zac@...> wrote:
> Your DB must be offline when you run the command. Otherwise you will get
> some error about being in multi user mode.
> If the PET shows that your DB is off, but you still cannot get past the
> multi user, go to your DB folder and look for a file that ends in .lk and
> delete it. After that you should be able to do it.
> "Zac" Jason Woodward
> Network Administrator
> Intermountain Electronics, Inc.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Creating customer confidence through extraordinary service and experienced
> industry experts.
> Of James Todd
> Sent: Wednesday, September 14, 2011 1:59 PM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] Vantage 5.1 db limit
> Yes, you have to enable large file support if you want to grow past 2GB.
> It's a simple command you do in Proenv.
> PROUTIL mfgsys -C EnableLargeFiles
> -James
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> jyargeau2001
> Sent: Wednesday, September 14, 2011 12:52 PM
> Subject: [Vantage] Vantage 5.1 db limit
> We are on Vantage 5.1. We have no intention of upgrading. Our db size is
> 1.97 gb. I remember somthing a long time ago that your db could not be over
> 2gb. Does anyone remember if there is a db size limit for this version and
> if so how do we do a data split? Support indicated there was no limit on
> size but I am not quite sure of this. Thanks for any help.
> Technical information contained in this e-mail may be controlled by the
> United States Government, Department of State, International Traffic and
> Arms Regulations (ITAR) (22 CFR 120-130) which requires an export license
> prior to sharing with foreign persons. Lacking such license, ITAR technical
> data is limited to U.S. persons only. It is the responsibility of the
> organization and the individual in control of this data to abide by U.S.
> Export Laws. If you are not a U.S. person take no further action with this
> e-mail and contact sender immediately.
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
We are on Vantage 5.1. We have no intention of upgrading. Our db size is 1.97 gb. I remember somthing a long time ago that your db could not be over 2gb. Does anyone remember if there is a db size limit for this version and if so how do we do a data split? Support indicated there was no limit on size but I am not quite sure of this. Thanks for any help.
Not sure in V5 but in V8 if your DB got too big you had to make some changes
in progress. I'd contact Epicor.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
Epic portal should provide you how to configure the db. You need to split it at 2 GB, after that there is no limit theoretically. I know Progress was being used on some very large projects back at that time so I suspect it is completely scalable. We just upgraded from 5.1 to 9.05 this past January. (we are all still alive, despite numerous death threats)
Keith Mailloux
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jyargeau2001
Sent: Wednesday, September 14, 2011 3:52 PM
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Yes, you have to enable large file support if you want to grow past 2GB. It's a simple command you do in Proenv.
-James
Technical information contained in this e-mail may be controlled by the United States Government, Department of State, International Traffic and Arms Regulations (ITAR) (22 CFR 120-130) which requires an export license prior to sharing with foreign persons. Lacking such license, ITAR technical data is limited to U.S. persons only. It is the responsibility of the organization and the individual in control of this data to abide by U.S. Export Laws. If you are not a U.S. person take no further action with this e-mail and contact sender immediately.
Your DB must be offline when you run the command. Otherwise you will get some error about being in multi user mode.
If the PET shows that your DB is off, but you still cannot get past the multi user, go to your DB folder and look for a file that ends in .lk and delete it. After that you should be able to do it.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced industry experts.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of James Todd
-James
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of jyargeau2001
