Vantage 6.0 and Windows Vista
This worked perfectly. Thank you for forwarding the information.
Ken
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Fri, October 30, 2009 3:28:29 PM
Subject: RE: [Vantage] Vantage 6.0 and Windows Vista
From a previous post (you will need to make the necessary changes for your version of Vantage and your environment) :
This ended up working great, I now have Vantage 6.1 working perfectly in Windows 7 RC1 x64. In case anyone was wondering the correct line to add to the services file for 6.1 is:
mfgsys61 6100/tcp
After the steps listed below and the addition of this line all I had to do was associate .mfg files with V:\mfgsys61\ db\Mfg.exe
Hope this helps someone else out there.
Jim & everyone else thank you again.
-Z
FYI - we have been running Vantage on 64 bit clients since Windows XP x64 and Vantage 5.0, other than the manual install we have had no issues. This includes Vista Business, Enterprise, Windows 7 beta and RC.
Below is an old posting for 5.0 just need to change everything for 6.1.
Did you edit the services file? No shortcuts - copy from another machine or create a shortcut to the .mfg files you need.
Here is what we do:
Vantage Drive = V
Run V:\Progress\ netsetup\ setup.exe
Run V:\Vantage\OCX\ InstOcx.exe
Edit C:\Windows\System32 \Drivers\ etc\services (for example: Epic50 2500/tcp) You can find the service in the vantage.vtg (for 6.1 vantage.mfg) file, connections= -S "xxxxx", 2500 is the default port for 5.0, tcp is the protocol.
The services file needs Local Admin rights or Explicit user Rights (Domain Admin will not work - although Domain Admin can change the rights).
For Vantage Help:
For Vantage help on Windows Vista we did not have to turn off any security settings. But we did have to add some registry settings. You can copy and paste the following text into a text file and name it something like vant32hlp.reg. Then you can either double click on it to install or add it to a script.
Vista 32 bit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_ MACHINE\SOFTWARE \Microsoft\ HTMLHelp\ 1.x\ItssRestrict ions]
"UrlAllowList" ="N:\\vantage\ \HELP\\vnhelp_ enu.chm;file://;<file:///\\;>"
Vista 64 bit:
[HKEY_LOCAL_ MACHINE\SOFTWARE \Wow6432Node\ Microsoft\ HTMLHelp\ 1.x\ItssRestrict ions]
For ODBC:
For the older versions of Vantage we had to use the 32bit ODBC Data Source administrator located in: C:\Windows\SysWow64 \odbcad32. exe. This is not the same one in "Administrative Tools".
Hth,
Jim
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Ken Cary
Sent: Friday, October 30, 2009 1:25 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Vantage 6.0 and Windows Vista
Have any of you ever had any experience/luck getting Vantage 6.0 (Progress DB) to run on Windows Vista.
Ken
Ken
From a previous post (you will need to make the necessary changes for your version of Vantage and your environment):
mfgsys61 6100/tcp
After the steps listed below and the addition of this line all I had to do was associate .mfg files with V:\mfgsys61\db\Mfg.exe
-Z
Here is what we do:
Vantage Drive = V
Run V:\Progress\netsetup\setup.exe
Run V:\Vantage\OCX\InstOcx.exe
Edit C:\Windows\System32\Drivers\etc\services (for example: Epic50 2500/tcp) You can find the service in the vantage.vtg (for 6.1 vantage.mfg) file, connections= -S "xxxxx", 2500 is the default port for 5.0, tcp is the protocol.
For Vantage Help:
Vista 32 bit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\ItssRestrictions]
"UrlAllowList"="N:\\vantage\\HELP\\vnhelp_enu.chm;file://;<file:///\\;>"
Vista 64 bit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\HTMLHelp\1.x\ItssRestrictions]
For ODBC:
For the older versions of Vantage we had to use the 32bit ODBC Data Source administrator located in: C:\Windows\SysWow64\odbcad32.exe. This is not the same one in "Administrative Tools".
Hth,
Jim
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ken Cary
Ken
