Vantage 6.1 email alert
Since the Vendor is assigned at the header, no it wouldn't make for a
great trigger because it will send the e-mail as soon as you create your
header.... no line details..... I think you would want to trigger on
the PODetail.POLine (or maybe even at the PORel), then get the POHead
table and check the vendor number to see if an e-mail needs to be sent.
{ud/GlbAlert.i &TableName = "PODetail"}
FIND FIRST POHeader WHERE POHeader.Company = PODetail.Company and
POHeader.PONUM = PODetail.PONUM NO-LOCK NO-ERROR.
IF AVAILABLE(POHeader) AND POHeader.VendorNum = ### THEN DO:
Enter your e-mail alert code here.......
END.
ELSE DO:
RETURN 'CANCEL SEND'.
END.
Michael Podlin
Network Administrator
V-S Industries, Inc.
900 S. Chaddick Dr.
Wheeling, IL 60090
847-520-1800 x207
Fax 847-520-0269
Michael.Podlin@...
Please consider the environment.
Do you really need to print this email?
Of PLAMAN, DICK
Sent: Friday, February 03, 2012 9:52 AM
Subject: [Vantage] Vantage 6.1 email alert
does anyone have vb code where an email gets fired when a certain vendor
gets
a PO entered? I tried using the vendor number. it fires an email, but
does not
work well for a trigger.
tia.
does anyone have vb code where an email gets fired when a certain vendor gets
a PO entered? I tried using the vendor number. it fires an email, but does not
tia.
Dick,
Here is one which you could change from a buyer to Vendor.
Patrick Winter
/* Program to send a global alert on PO Entry
by Patrick Winter
12/14/2006 */
{ud/GlbAlert.i &TableName = "POHeader"}
DEFINE VARIABLE NewEmailBody AS CHARACTER NO-UNDO.
FIND Vendor WHERE Vendor.Company = POHeader.Company
AND Vendor.VendorNum = POHeader.VendorNum NO-LOCK NO-ERROR.
FIND VendorPP WHERE VendorPP.Company = POHeader.Company
AND VendorPP.VendorNum = POHeader.VendorNum
AND VendorPP.PurPoint = POHeader.PurPoint NO-LOCK NO-ERROR.
IF OldPOHeader.Approve = FALSE AND POHeader.Approve = True
AND POHeader.Buyer = "PatW"
THEN DO:
ASSIGN Email-Subject = String(PoHeader.PONum,'9999999') + " " +
USERID.
ASSIGN Email-Text = 'Purchase order has been entered or just
approved for you. ~n~n'
+ " Vendor Name: " + STRING(Vendor.NAME) + '~n'
+ " Vendor ID: " + STRING(Vendor.VendorID) + '~n'
+ " City: " + STRING(Vendor.City) + '~n'
+ " State: " + STRING(Vendor.State) + '~n'
+ " Zip: " + STRING(Vendor.Zip) + '~n'
+ " Purchase Point: " + STRING(Vendor.PurPoint) + '~n'
+ " PP Vendor Name: " + STRING(VendorPP.NAME) + '~n'
+ " PP City: " + STRING(VendorPP.City) + '~n'
+ " PP State: " + STRING(VendorPP.State) + '~n'
+ " PP Zip: " + STRING(VendorPP.Zip) + '~n'
+ " Entry Person: " + STRING(POHeader.EntryPerson) + '~n'
+ " Order Date: " + STRING(POHeader.OrderDate) + '~n'
+ " Purchase Order: " + String(POHeader.PONum,'9999999') + '~n'
+ " Open Order: " + STRING(POHeader.OpenOrder) + '~n'
+ " Requisitiond by: " + STRING(POHeader.Character03) + '~n'
+ " Deliver to Dept: " + STRING(POHeader.Character04) + '~n'
+ " GP or Use: " + STRING(POHeader.Character05) + '~n'
+ " Comment Line 1: " + STRING(POHeader.Character06) + '~n'
+ " Comment Line 2: " + STRING(POHeader.Character07) + '~n'.
END.
ELSE DO:
RETURN ERROR.
END.
Of PLAMAN, DICK
gets
does not
tia.
