Vantage 6.1 - importing p/n's & descriptions from excel
If you are familiar with Access you can create an automation script to
enter the part numbers. Below is a script I used to update the part
class. Maybe it will help you get started.
Butch
Public Function ChangePartClass()
Dim db As Database
Dim rs As Recordset
Set db = CurrentDb()
Set rs = db.OpenRecordset("qryStandardCostAutomation")
'Ensure Part File Maintenance is open to display all parts
'Ensure the cursor is in the Part Number search field and it is
blank
AppActivate "Part File Maintenance", False
Wait 2 'Manually click your mouse in the Part Number search field
on the form to ensure it has the focus
While Not rs.EOF
SendKeys "{Delete}", True 'Delete anything highlighted in the
part number field
Wait 0.25 'Insert some waits because system is
too fast for the database
SendKeys rs!PartNum, True 'Insert the part number
Wait 0.25
SendKeys "{Enter}", True 'Execute the search
Wait 0.25
SendKeys "{Tab}", True 'Move the focus to the search
results
Wait 0.25
Wait 0.25
SendKeys "{Enter}", True 'Launch the Part Master form
Wait 0.25
SendKeys "{Tab}", True 'Move to the Part Class field
Wait 0.25
Wait 0.25
Wait 0.25
Wait 0.25
SendKeys "{Delete}", True 'Delete what's there
Wait 0.25
SendKeys rs!Description, True 'Insert the new part class
description
Wait 0.25
SendKeys "{F2}", True 'Save and close the form
Wait 1
rs.MoveNext
Wend
End Function
Sub Wait(PauseTime)
'slows down the sendkeys because it is too fast for Vantage
Dim Start
Start = Timer ' Set start time.
Do While Timer < Start + PauseTime
DoEvents ' Yield to other processes.
Loop
End Sub
Of rgraf56
Sent: Wednesday, June 24, 2009 6:35 AM
Subject: [Vantage] VANTAGE 6.1 - IMPORTING P/N'S & DESCRIPTIONS FROM
EXCEL
Does Vantage 6.1 have the capability to import part numbers and
descriptions directly from Excel? I have a spreadsheet that is several
thousand part numbers long. I started entering them manually but after
the first few hundred I'm ready to start looking for a job at the local
fast food joint to get out of having to do the rest. Thanks for hte
feedback.
Rick
Does Vantage 6.1 have the capability to import part numbers and descriptions directly from Excel? I have a spreadsheet that is several thousand part numbers long. I started entering them manually but after the first few hundred I'm ready to start looking for a job at the local fast food joint to get out of having to do the rest. Thanks for hte feedback.
Rick
No import capability, unless you ask Epicor to write a tool for you.
However, there have been many users in this group that use automation
tools to read the excel file and copy / paste into Epicor.
Programs like Ground Control and others...
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of rgraf56
Sent: Wednesday, June 24, 2009 8:35 AM
EXCEL
feedback.
Rick
There is no "free" import capability but there is an Import/Data Conversion Tool available which runs from an Access db which you populate from your Excel spreadsheet.
At first, it's not the easiest thing in the world to use but once you get used to it you can import any file/table and also use it for mass updates etc.
Regards
Richard
Richard Bailey
IT Systems
DUDLEY I n d u s t r i e s L i m i t e d, Preston Road, Lytham, Lancashire, FY8 5AT, UK
*+44 (0)1253 738311
* rbailey@...<mailto:grbailey@...> ? www.dudleyindustries.co.uk
Europe's Leading Manufacturer of Quality Washroom Dispensing Systems
A Rentokil Initial Company
P Please consider the environment before printing this email.
This e-mail together with any attachments is intended only for the recipient(s) named above. It may contain confidential and/or privileged information and express views or opinions that are those of the sender and not necessarily of Dudley Industries Limited. The disclosure, reproduction, distribution or other dissemination or use of this communication is strictly prohibited by anyone other than the intended recipient(s). If you are not a named recipient, please contact the sender and delete this e-mail from your system.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Manasa Reddy
Sent: 24 June 2009 14:39
Subject: RE: [Vantage] VANTAGE 6.1 - IMPORTING P/N'S & DESCRIPTIONS FROM EXCEL
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com>
P: 630-806-2000
F: 630-806-2001
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of rgraf56
EXCEL
feedback.
Rick
Thanks for the info. It sounds promising. Where can I get more details?
Rick
updates etc.
> Regards
> Richard
> Richard Bailey
> IT Systems
> *+44 (0)1253 738311
> * rbailey@...<mailto:grbailey@... ? www.dudleyindustries.co.uk
FROM EXCEL
> M. Manasa Reddy
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of rgraf56
> EXCEL
local
> feedback.
> Rick
You'd need to contact your friendly neighbourhood Epicor salesperson.
Not sure of the pricing.
Regards
Richard
Richard Bailey
IT Systems
*+44 (0)1253 738311
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of rgraf56
Sent: 24 June 2009 16:28
Subject: [Vantage] Re: VANTAGE 6.1 - IMPORTING P/N'S & DESCRIPTIONS FROM EXCEL
Rick
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Richard Bailey <rbailey@...> wrote:
updates etc.
> Regards
> Richard
> Richard Bailey
> IT Systems
> *+44 (0)1253 738311
FROM EXCEL
> M. Manasa Reddy
> P: 630-806-2000
> F: 630-806-2001
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
Behalf
> Of rgraf56
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> EXCEL
local
> feedback.
> Rick
Not sure about 6.1, but in 8.03.4xx you can import a BOM into a method that
does not have any operations attached to it yet. I believe in any method
(quote, engineering, job).
This will bring in part numbers, descriptions, and type of part (P or M)
along with Qty.
After the import, you still have to go back to enter in the part class,
product group etc.
The format for the csv file is partnumber, description, type, qty
You can delete the method also after you have imported the part numbers.
This approach is under actions, get details, import.
Good luck.
Bruce
bruce@...
www.ERPgeek.com
rgraf56
Subject: [Vantage] VANTAGE 6.1 - IMPORTING P/N'S & DESCRIPTIONS FROM EXCEL
Rick
