Vantage 6.1 - Sort Order
I haven't read this entire thread so I don't know if someone already
mentioned this but all my Win2K computer did not adjust for the new DST
even after running TZEDIT.
It turns out I missed a step where I had to double click on the clock in
the task tray and change the time zone to some other than the one I
modified, click apply, and then reselect my correct time zone.
Once I did this the clock automatically move the +1 hour.
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
Of Todd Caughey
Sent: Monday, March 12, 2007 10:38 AM
Subject: RE: [Vantage] Ver 6.1 - Daylight savings time
Another note for those driving their shop bells from the Vantage server.
Our Win2K Vantage server, and thus all the Data Collection PC times in
Vantage, were off by an hour. Rather than labor editing everyone on 1st
shift I will let the Vantage server stay an hour off until shift change
at 3:00-3:15pm. But for the shop bells I have manually adjusted the
scheduler by an hour so they sound at the right times and will set them
back when I adjust the Vantage server time. Just another thing to
consider.
-Todd C.
Nancy- Not trying to be too elementary, but did you check the checkbox that
says "Automatically adjust clock for Daylight Savings Time changes"? I
found a couple that I had unchecked. -Gary
Dunn, Nancy
Sent: Monday, March 12, 2007 10:24 AM
It's nice to hear I'm not the only one with problems.
But it just keeps getting weirder. I use the TZEDIT program and the
XPsp2 patch for all the PC's and servers.
Some PC's rolled the time right some didn't and they can be identical
PC's (bought at same time).
I have at least one PC showing the Vantage time correctly and the
majority showing it an hour off.
Kind of craze.
Nancy
<mailto:jmoore%40dri.gd-ots.com> ots.com]
Sent: Monday, March 12, 2007 9:52 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
We are using 6.1 and did not have any problems.
Server is 2003.
All DC's and computers show the correct time.
Our Outlook calendar appointments are off, but I decided to just leave
them alone. The fixes cause about as many problems as the cure.
DC pc's are a mix of 2000 Pro and XP Pro.
I also used the TZEdit program for my 2000 boxes.
Microsoft mentioned that if you did not go in and select another time
zone, apply it, then reapply the correct time zone after setting your
DST dates, the tzedits would not take effect. I imagine that is why it
did not work. I also changed the DST dates for all 4 timezones, Eastern,
Central, Mountain and Pacific.
Jim
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of Todd Caughey
Sent: Monday, March 12, 2007 8:27 AM
Another bit of info. I distributed the TZEdit program that was posted
here to all our Win2K users and had everyone run it and adjust their
daylight effective times. But they did not seem to take effect.
Interestingly if you go to mannualy change the time but first turn off
automatic adjustment, apply that, turn it back on and apply that the
time is then changed by one hour. So I suspect something in the TZedit
routine did not force a registry setting to make the changes effective
for yesterday.
-Todd C.
I found that the DST adjustment, whether patch or using TZedit, ended up
requiring a restart of all of our servers - it caused our backup program
service to hang which required the restart. Then the time adjustment went
without incident - Vantage included (fingers crossed it stays that way).
With what I'm hearing from the group here, could be DST change (patch or
manual) required a server restart to avoid program conflicts and Microsoft
forgot to give the whole world that insignificant detail.
Palm DST updates have quite a fiasco of their own, seems like. FYI - since
Palm's DST patches are doing a real good job of failing, you can go in
manually and reset the Palm DST settings this way, if your hardware isn't
too old: Prefs, date and time, worldclock, location, edit list, select
timezone, edit, make your changes.
Gary Polvinale
Denton ATD
Gitzlaff, Christopher
Sent: Monday, March 12, 2007 9:26 AM
To: vantage
We are on Vantage 6.1 and did not have any problems with the change. I
applied the DST patches on March 1 and restarted our Vantage server and
data collection stations last Thursday (March 8). Everything adjusted
fine yesterday - didn't have to touch anything.
Perhaps the restart was the solution. Many services that use DST only
read the value from the operating system when they are started (they
never check it again even if a patch has been applied).
One disclaimer: Our Vantage server runs Linux and our data collection
PC's run Windows XP. I would think that the server OS would be
irrelevant, but you never know...
Chris Gitzlaff
Major Industries
<mailto:pjw%40specialtyscrew.com> com]
Sent: Monday, March 12, 2007 7:58 AM
I shutdown Vantage and the progress service which fixed the problem.
The big question is will we have to do this again in 2 weeks and also
twice in the fall.
Patrick Winter
Vantage 6.1
____________-_________-_________-__
Behalf
Of Julie Lehmann
Sent: Monday, March 12, 2007 7:47 AM
To: vantage@...
Subject: Re: [Vantage] Ver 6.1 - Daylight savings time
Same thing here - but I rebooted the server and that fixed it.
Julie
Mercury Minnesota Inc.
----- Original Message -----
To: vantage@... <mailto:vantage%-40yahoogroups.-com>
Sent: Monday, March 12, 2007 7:42 AM
We are experiencing the same problem so please post when you find out
the answer.
Colette Bishop
IT Manager
J. T. Cullen Company Inc.
901 31st Avenue
P.O. Box 311
Fulton, IL 6125
Phone: 815-589-2412 Ext. 314
Fax: 815-589-4018
Email: <mailto:cbishop@-jtcullec> cbishop@jtcullenco.-com
<mailto:cbishop%-40jtcullenco.-com>
<mailto:cbishop@jtcullenco.-com <mailto:cbishop%-40jtcullenco.-com> >
From: vantage@... <mailto:vantage%-40yahoogroups.-com>
[mailto:vantage@... <mailto:vantage%-40yahoogroups.-com> ]
On
Behalf
Of Dunn, Nancy
Sent: Monday, March 12, 2007 7:31 AM
Subject: [Vantage] Ver 6.1 - Daylight savings time
When I came into work this morning all my servers and PC's had correctly
adjusted for daylight savings time (they were patched last couple of
weeks).
But the Data Collection - Vantage is showing the time 1 hour behind. So
check your time in Vantage.
If any one has any ideas how to get the time sychn. I would love to hear
it. Support is working on it.
Nancy
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
The problem with The TzEdit utility is that it edits the default time
zone data in the registry. After adjusting the data you need to get
windows to re-write the current configuration data. The best way to do
this is to switch to another time zone, click apply, then switch back to
the original time zone. This will get windows to re-write the changes
to the current control set. Re-booting will not change the time zone
data. Maybe Vantage only reads from the current time zone data and only
when it's re-started. Anyway, I'll be re-booting our Vantage server at
shift change.
Bob Bruton.
This is what I found out also.
The PC's that didn't correctly if I used the TzEdit on them and switched
between time zones they changed. Or the ones that had the TzEdit ran
before- all I had to do was open the time zone switch to something like
Central then back to Eastern and the time changed.
Now for the server...Tech Support is recommending to restart the server.
Which I will do at end of shift.
Nancy
Sent: Monday, March 12, 2007 2:37 PM
the original time zone. This will get windows to re-write the changes to
the current control set. Re-booting will not change the time zone data.
Maybe Vantage only reads from the current time zone data and only when
it's re-started. Anyway, I'll be re-booting our Vantage server at shift
change.
Bob Bruton.
Oh, another thing, when I ran the patch on the Server 2003 servers it
change my Execbac backup times to an hour later.
Nancy
Sent: Monday, March 12, 2007 2:34 PM
Subject: RE: [Vantage] Ver 6.1 - Daylight savings time - Servers and
Palm
went without incident - Vantage included (fingers crossed it stays that
way).
Microsoft forgot to give the whole world that insignificant detail.
since Palm's DST patches are doing a real good job of failing, you can
go in manually and reset the Palm DST settings this way, if your
hardware isn't too old: Prefs, date and time, worldclock, location, edit
list, select timezone, edit, make your changes.
Gary Polvinale
Denton ATD
Behalf Of Gitzlaff, Christopher
To: vantage
Chris Gitzlaff
Major Industries
twice in the fall.
Patrick Winter
Vantage 6.1
Behalf Of Julie Lehmann
To: vantage@...
Julie
the answer.
Colette Bishop
IT Manager
901 31st Avenue
P.O. Box 311
Fulton, IL 6125
Fax: 815-589-4018
On Behalf Of Dunn, Nancy
weeks).
Nancy
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Mine shows to be an hour earlier too, but...
According to Veritas:
I am using 10d.
Document ID: 280521
http://support.veritas.com/docs/280521
<http://support.veritas.com/docs/280521> E-Mail this document to a
colleague
<javascript:openSubWin('http://seer.support.veritas.com/email_forms/tnot
e_sndml.asp?docID=http://seer.support.veritas.com/docs/280521',%20475,%2
0500)>
When checking pending or scheduled jobs in the Backup Exec for Windows
Servers user interface, it seems to reflect the incorrect time.
Details:
When checking pending or scheduled jobs in the Backup Exec user
interface, the incorrect time may be reflected because the Backup Exec
database stores time as Coordinated Universal Time (UTC) which is the
same as Greenwich Meridian Time (GMT). Therefore jobs which run after
Daylight Savings Time (DST) may reflect the "incorrect" time and vice
versa.
Note: In such a scenario there is no need to change the time for the
scheduled job, they should run on the desired scheduled in spite of the
display time.
This issue has been resolved in Backup Exec 11d for Windows Servers.
Related Documents:
Jim
Of Dunn, Nancy
Sent: Monday, March 12, 2007 2:51 PM
Palm
Nancy
<mailto:garyphold%40dentonatd.com> ]
Palm
way).
Gary Polvinale
Denton ATD
To: vantage
Chris Gitzlaff
Major Industries
twice in the fall.
Patrick Winter
Vantage 6.1
To: vantage@...
Julie
the answer.
Colette Bishop
IT Manager
901 31st Avenue
P.O. Box 311
Fulton, IL 6125
Fax: 815-589-4018
weeks).
Nancy
I found that if I just opened the job - view properties and resubmit it
the time went to the original scheduled time.
Nancy
From: Moore, Jim (Anniston) [mailto:jmoore@...-ots.com]
Sent: Monday, March 12, 2007 4:47 PM
Palm
I am using 10d.
Document ID: 280521
<http://support.veritas.com/docs/280521> > E-Mail this document to a
colleague
<http://seer.support.veritas.com/email_forms/tnot>
<http://seer.support.veritas.com/docs/280521> ',%20475,%2 0500)>
Details:
versa.
display time.
Related Documents:
Jim
Palm
Nancy
Palm
way).
Gary Polvinale
Denton ATD
To: vantage
Chris Gitzlaff
Major Industries
twice in the fall.
Patrick Winter
Vantage 6.1
To: vantage@...
Julie
the answer.
Colette Bishop
IT Manager
901 31st Avenue
P.O. Box 311
Fulton, IL 6125
Fax: 815-589-4018
weeks).
Nancy
I did what you suggested and mine also changed back to the original
time.
Jim
Of Dunn, Nancy
Sent: Monday, March 12, 2007 3:56 PM
Palm
Nancy
<mailto:jmoore%40dri.gd-ots.com> ]
Palm
I am using 10d.
Document ID: 280521
colleague
Details:
versa.
display time.
Related Documents:
Jim
Palm
Nancy
Yup. If you do some registry poking, you'll find the specs for all the different zones, which is what TZEdit works on, in:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones
But the zone you've selected is in:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TimeZoneInformation
(at least on Win2000.) So the "change it & change it back" copies the new info from the 1st reg' entry to the 2nd.
There's also this utility: http://www.intelliadmin.com/blog/2007/01/unofficial-windows-2000-daylight.html that someone on the list mentioned a while back that worked ok an all my windoze PCs.
I heard there were issues with some versions of Java, which Progress uses. Anyone know if Epicor or PSC addressed that?
-Wayne
