if the Vantage server name was changed you will need to unregister
("unregocx")
the OCX files on each client.
Sometimes you can get away with running this utility (found in your
vantage directory).
you run it from a DOS prompt....(ie: v:\mfgsys61>unregocx c (no
quotes) unregocx v
(assuming your client is mapped to the letter "v".
I have had cases where I needed to remove the entries from each client
registry.
I searched for the old vantage server name and deleted those entries.
(be careful if you need to do this).
best luck.
Of Judy Havlik
Sent: Wednesday, January 31, 2007 8:35 AM
Subject: [Vantage] Vantage 6.10.541 - Menu Structure Maintenance
Over the weekend our management upgraded to 541 and changed our Vantage
Server.
Since then, then trying to access the Menu Structure Maintenance we get
the following error message:
"Specified ActiveX control is not registered or the .0cx file was moved
from where it was registered.
Error occurred in procedure control_load su/sum20.w (6087)"
Does anyone have any information they can provide on how to correct
this error?
Sincerely,
Judy Havlik
judy.havlik@... <mailto:judy.havlik%40plitek.com>
("unregocx")
vantage directory).
quotes) unregocx v
registry.
best luck.
Of Judy Havlik
Server.
this error?
Sincerely,
Judy Havlik
