Vantage 6 logic for revision control
Question when using vantage 6 how is revision control maintained? Example we have a current job running we have to add material to the job via an ECN. You can add the material on the job side and move on but, are others using the engineer work bench to accomplish this? What would the vantage logic be add an ecn via the EWB then do a get details for the jobs effected? Thanks for any help in advance.
Paul Smith
Inventory Management
233 Ballston Ave
Saratoga Springs NY, 12866
518-245-4358
The information contained in this message is intended solely for the individual it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the content of this information is strictly prohibited. If you received this message in error, please delete it from any computer and notify the sender. If you suspect that this message may have been altered, please notify the sender.
