Vantage 8.0 Service Connect
Edward,
I have created a folder named Service Connect in the Files section of
this group. Inside there is a Work in Progress document for setting
up Service Connect
I hope this helps you.
Rob Willhite
rwillhite@...
--- In vantage@yahoogroups.com, "edwardlynn_10" <fstockmaster@...>
wrote:
> We are attempting to get Service Connect (SC) setup and running for
> another major project where we need data input into Vantage through
an
> automated process, which we are developing for Vantage 8.0.
> Does anyone have any notes or documentation other than what Epicor
> provided? There seems to be a lot of holes going unanswered when
> attempting use the printed materials available on implementation of
> SC. The more we try to use the information provided, the more
> questions we have.
> At present we have Web Services installed with Vantage Services
setup
> on the Vantage 8.0 server. We have a separate server with SC and
the
> SQL DB installed. We have been unsuccessful in getting Vantage
> Services to display in web format from the web server. Then we
have a
> ton of questions as to when things happen from creating XML
documents
> and exactly how to configure SC.
> Any help the group could give us, would be greatly appreciated. I
will
> look forward to any and all responses.
another major project where we need data input into Vantage through an
questions we have.
At present we have Web Services installed with Vantage Services setup
on the Vantage 8.0 server. We have a separate server with SC and the
Services to display in web format from the web server. Then we have a
ton of questions as to when things happen from creating XML documents
Any help the group could give us, would be greatly appreciated. I will
Hi Edward,
On the machine that has the web services installed, open up Internet
Information Services Manager from the administrative tools menu.
Expand the server name. Expand web sites. Expand default web site. You
should see a yellow gear looking thing with the name of the folder for
the web services (VantageServices ?)
Click on that and the list of services should be shown in the right hand
panel.
to test the web server while still on that machine click start - run and
type http://localhost/vantageservices/abccodeservice.asmx and hit the
enter key
If that works then so far so good.
Of edwardlynn_10
Sent: Friday, August 25, 2006 3:42 PM
Subject: [Vantage] Vantage 8.0 Service Connect
questions we have.
Apparently there is a lot more to the machine and network settings than outlined in the Installation Guide.
Not sure if going to training would even help.
As products go - its great when working but its hell on earth to figure out without comprehensive install instructions.
questions we have.
Stay in the know. Pulse on the new Yahoo.com. Check it out.
