Ron,
Creating the new report definition is not that hard, they give you
the ability to copy the old over and modify it. You can add fields,
and even use the related tables functionality to add fields from
other tables (example, a code is on the report, you want to display
the text description from the code master file). You've got to be
careful in the report definition maintenance program, as there's
bugs in it (click on table A and it doesn't show right; click on
table B, then back on table A, then it's correct).
The only issue I have is when you've got data that Vantage would
think is unrelated, and you may need to create subreports (example,
we grab data from the sales order for the job traveler). However,
this is more a result of the way we do business than anything I'd
expect the software to do.
Kevin Simon
Kevin Simon
--- In vantage@yahoogroups.com, "swinky68" <swinky68@...> wrote:
> There's one section missing from these instructions. In step 23,
> it's been my experience that the only fields you can add to the
> report are fields that are brought over with the original report
> definition. Otherwise, you have to create a new report definition
> with the additional fields, and that has to be done as a different
> definition unless you have a SDK license. Just more fun from
Epicor!
> Thanks,
> Ron Cole
> IT Manager, IED Inc.
> rcole@...
> --- In vantage@yahoogroups.com, Kelly Potratz <kpotratz_05@>
> wrote:
> > Here is the document I received from support for modifying
> existing Crystal Reports. One step is missing, and that is you
have
> to run the report you want to modify before you start any of the
> other steps.
> > Summary: CR Modifying an existing form in 8.0
> > Book: Support Solutions
> > Page: 4778MPS
> > Crystal 10 XML Modify
> > Page ID 4778
> > Problem:
> > How do I modify an existing form with Crystal 10 and
> Vantage/Vista 8.0 and add it to the Report Style Maintenance as
the
> default form?
> > Resolution:
> > Steps for Modifying an Existing Report in Version 8.x
> > ***Note*** As always, print or preview the standard Crystal
> Report first before following these steps.
> > 1. Open Crystal Reports 10 for Epicor MFG.
> > 2. Choose the radio button for Open an Existing Report.
> > 3. Double-click on More Files in the window.
> > 4. It should automatically open to your Epicor\Mfgsys80
> \Server\Reports folder.
> > 5. If not, Browse to that location.
> > 6. Double-click on the rpt file you wish to modify, for this
> example, we will use the PackSlip.rpt.
> > 7. It should open up in Crystal version 10.
> > 8. Go up to File -> Save As -> and give this report a new name
> because it will be your newly modified form.
> > 9. Save into this directory, or a subdirectory of this Reports
> folder.
> > 10. Go up to Database -> Set Datasource Location, that screen
> now appears.
> > 11. In the top section, Current Datasource, click on the +
sign
> to the left of Properties.
> > 12. Notice the File Path is incorrect, highlight the File Path
> Properties.
> > 13. In the bottom section, Replace With, click on + sign to
the
> left of Create New Connection.
> > 14. Click on the + sign to the left of ADO.NET (XML), the
> ADO.NET (XML) browse window appears.
> > 15. In the File Path, click on the button and browse to the
> Epicor\MfgsysData\Reports\(Your login ID) ie. Manager 16. Find the
> report that was just printed before you started this process. i.e.
> Packing Slip Print 01249.XML, and double-click on it.
> > 17. The File Path should now be populated with the correct
> location of the XML file.
> > 18. Click on Finish, then Close.
> > 19. Go back up to Database -> Verify Database, the original
> Connection screen pops up.
> > 20. Click on the button again.
> > 21. This time it will bring up the (Your login ID)Manager\
> folder, double-click the Packing Slip Print 01249.XML again.
> > 22. A message should appear, "Database is up to Date".
> > 23. You are now ready to add fields to the report through the
> Field Explorer.
> > 24. Don't forget to Save changes when finished with the
> modifications and additions.
> > Steps for Adding your Modified Form to the Report Style
> Maintenance
> > 1. Log into your database.
> > 2. Under System Management -> Company Maintenance -> Report
> Style.
> > 3. Click on Report ID button -> Then Search button.
> > 4. Double-click on Packing Slip or the Standard report you
just
> modified.
> > 5. Click on the Styles tab.
> > 6. Over to the left, you will see a Tree view of your Packing
> Slip Style(s).
> > 7. Click on the New button on the Tool bar at the top upper
> right corner.
> > 8. Use the drop down, and select New Report Style.
> > 9. In the Report Maintenance, fill in a Description, and it
will
> automatically fill the Tree view left side with that information.
> > 10. Fill in Report Location Reports\ModifiedPackSlip.rpt.
> > 11. Click on the Save button in the tool bar at the top.
> > 12. The bottom half of the Report Maintenance populates with
all
> companies and check boxes for valid or default, and check all that
> would apply.
> > 13. Save changes, exit out of Report Style Maintenance.
> > 14. Go into Shipping and Receiving, and once you hit the Print
> button, the modified Packing Slip that you set as default is
there.
> > 15. You are now printing your modified form.
