I am in the midst of developing the process that brings our demand
and inventory into PEP with ODBC, nests parts of like material and
due date on the available inventory, and using Service Connect,
creates a new job just to cut the nest. The beauty is how well the
costs (labor & matl.) for the individual parts get split back to the
original jobs.
I've done the process manually, but I'm currently working on some
standards between sales & purchasing so PEP can properly identify
what gets nested together and on what stock.
Steve P.
--- In vantage@yahoogroups.com, "l_crossman" <lyndon.crossman@...>
original jobs.
Steve P.
wrote:
>with
> We are currently in implementation stage of Vista 8.03. We nest
> Merry Mech SMP and FinnPowers NCXExpress. Nests run on turretpunches
> and plasma.Vista.
> We are trying to figure out how to record nest information in
> We are a manufacture of wood stoves so our nests don't change much.system.
> We currently keep track of nests to run in a spreadsheet for
> particular models. The parts made are recorded in an old DOS MRP
>has a
> We purchased the Advanced manufacturing module for vista but it
> bug (Can't select concurrent or sequential mode drop down). And itis
> time consuming setting up parts.in
> I would be intersted in discussing nesting and how to make it work
> Vista/Vantage.currently
> Thanks,
> Lyndon
> --- In vantage@yahoogroups.com, "ermc_v" <rjohnson@> wrote:
> > We use Pro-Nest software for nesting flame table steel. We
> > work of a customized cut list report, but essentially sort openuntil
> > cutting operations by job #, then by material. The only issue is
> > once these operations are nested, they are still on the report
> > the MES station reports them as being complete. It is kind ofhard
> > to keep track of what has been nested and what hasn't. So Iagree
> > much work could be done here to improve the process.wrote:
> > Rich J
> > > --- In vantage@yahoogroups.com, "Don Bricker" <DBricker@>
> > > >different
> > > > Steve, this is something that we will be doing at many
> > > stagesare
> > > > of the process (Quoting, Initial Production Planning, Shop
> > Floor,
> > > etc).
> > > > I would love to talk to you some time to see where you guys
> > at,[mailto:vantage@yahoogroups.com]
> > > > since we haven't done this part quite yet.
> > > > Don
> > > > DBricker@
> > > > ________________________________
> > > > From: vantage@yahoogroups.com
> > Onparty
> > > Behalf
> > > > Of Steven Pybus
> > > > Sent: Tuesday, January 09, 2007 7:39 PM
> > > > To: vantage@yahoogroups.com
> > > > Subject: [Vantage] Vantage 8.0 users who 'nest' w/ third
> > > > software...and
> > > > Do you use PEP <http://www.peptechnology.com/
> > > > <http://www.peptechnology.com/> > and Vantage 8? Let me
> > > > hear from you...
> > > > My company uses Vantage 8.0 and the APS (Advanced Planning
> > > > Scheduling) module to schedule our shop. We also use aWe
> > laser/plasma
> > > > nesting software called P.E.P (PEP) by Measurement Master.
> > needto
> > > to
> > > > get these two companies to the table to get their software
> > talkmore
> > > to
> > > > each other. The nesting software can identify when two or
> > > jobs canfor
> > > > be cut on the same sheet of material. The Vantage solution
> > > this isthis
> > > > a Batch which is very cumbersome. We have got to get this
> > process
> > > more
> > > > automated.
> > > > It would be a huge advantage to have other users pushing for
> > > > capability. If you are using Vantage 8.0 and cut parts witha
> > > laser,that
> > > > plasma, waterjet, CNC router, turret punch, etc... anything
> > > > requires you to 'nest' these parts on a sheet of material(steel,
> > > > aluminum, plastic, wood, etc.), I would appreciate hearingfrom
> > > you.the
> > > > Especially if you use PEP. Email me even if you use one of
> > > other
> > > > nesting products (SigmaNest, Striker, MTC, NestLib, BySoft,
> > > ToPs100,
> > > > etc.) I would be willing to create a table in the database
> > section
> > > of
> > > > this user group to let others know who is using what.
> > > > Many thanks,
> > > > Steve P.
> > > > [Non-text portions of this message have been removed]
