Vantage 8.00.811B to 8.03.405A Upgrade-Reports
I experienced the same thing.
A huge plus in 8.03 is the ability to add data from tables from
outside the canned report - the reports supplied have changed greatly
from 8.00.811 to 8.03.405, the modified reports were brought over in
the db conversion but in no way are they close to being useable. Some
reports that used to have a single style now have 1 or more
additional stlyes, so any custom styles you created as style 2 got
over written as well.
I took our modified crystal forms and opened them and linked to the
canned report xml data. the data wizard allows you to re map changed
field names and will show you the missing fields that are in the
report but not the xml data - from there you can go back and
duplicate the stock report definition and then add in your missing
fields. The sales and ar forms we customized needed to have new
tables in the xml data linked to prevent data duplication in the
report.
Unfortunately this is one of the things that was not tested when we
were piloting the upgrade and caused me grief during the first week
after the upgrade.
bw
--- In vantage@yahoogroups.com, "Jason Abramczyk" <jasona@...> wrote:
> We have setup a test enviroment using a virtual server and have
> upgraded from 8.00.811B to 8.03.405A. The testing was going fine
> until i tried running some of the customized reports like AR
invoice.
> The AR invoice previews and prints when using the standard report
but
> when i try and run the customized report i get the following error.
> Type:3
> Program:ar/arinvform.p
> Method:getRptTableIncludedFields
> Table:RptTable
> Field:RptTableID
> Rowid:
> Message:Could not find RptTable for the specified table name.
> I then opened the report using Crystal and tried to create a new
> connection to the xml file and got the following message.
> Logon failed.
> Details: system.xml:Unexpected end of file has occured. The
following
> elements are not closed: xs.element, xs.schema, Report data set.
line
> 1354 position 1.
> The other issue i am having is the customer statements. When i try
to
> print this in either standard or customized i get an error in the
> system manager stating that it can't find the file. I then go to
the
> folder that the xml files are generated to and there are no
customer
> statement xml files.
> Has anyone had this some problem with an upgrade?
> Thanks,
> Jason.
until i tried running some of the customized reports like AR invoice.
The AR invoice previews and prints when using the standard report but
Type:3
Table:RptTable
Field:RptTableID
Rowid:
Logon failed.
Details: system.xml:Unexpected end of file has occured. The following
elements are not closed: xs.element, xs.schema, Report data set. line
1354 position 1.
The other issue i am having is the customer statements. When i try to
system manager stating that it can't find the file. I then go to the
folder that the xml files are generated to and there are no customer
Jason.
Yes, on both of those documents. In each instance I had to recreate the
Report Data Definition from scratch.
Mark W.
