Vantage 8.03.305K - MRP Error Log
--- In vantage@yahoogroups.com, "Lauren Hellings" <LaurenH@...> wrote:
> Where can I find the MRP Log File and is this something I need
to "turn
> on" to generate?
> Thank You,
> Lauren L. Hellings
> Systems Administrator
> Ericson Manufacturing Co.
You have to specify a log file when the job is submitted, otherwise,
one is not generated. The usual path
is "drive:\epicor\mfgsysdata\userfolder\logname.txt".
Where can I find the MRP Log File and is this something I need to "turn
on" to generate?
Thank You,
Lauren L. Hellings
On the Process MRP screen, there is a "LOG:" field that you to fill in
to create the log file. You don't need to specify a path or file
extension as the file by default is saved to the
MFGSYSDATA\Reports\username folder and the system adds ".txt" to your
entry.
Bill
> on" to generate?
> Thank You,
> Lauren L. Hellings
You specify the path/name of the MRP logfile right in the MRP process submittal form.
Make sure the path is a path the system agent is set up to (and has rights to) access.
Typically, these logs dump into default vantage server subdirectories which means potential users likely won't have access.
Rob Brown
on" to generate?
Thank You,
Lauren L. Hellings
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
