Vantage 8.03.403D Payroll Employee Issue
Ok, got it. See Scott's email too. He's correct, the table is PREmpMas.
I wish I could help further. If the error still generates when the field
is populated...that's something different from my experience. I did get
this error when we wrote employee records into the database tables
because the db fields are set to accept Zero-Length but not Nulls. The
V8 GUI writes Zero-Length when you delete field data. Good luck. :o(
Ian Hogan
Information Systems Manager
Standard Filter Corporation
760-929-8559 or 800-634-5837 (voice) - 760-929-1901 (fax)
Of wl_bl
Sent: Thursday, January 03, 2008 11:05 AM
Subject: [Vantage] Re: Vantage 8.03.403D Payroll Employee Issue
Ian,
Thanks for responding but we get the same message even when we have a
bmp included. Also, we've looked in the data dictionary and there is
no field in the Payroll Employee Master File called ImageFile.
Wendy
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Ian
Hogan" <ianhogan@...> wrote:
> Hey Wendy, this error is referencing a field in Employee
Maintenance. Go
> to Payroll - Setup - Employee then on the dialog look on the upper
> right. Under the employee photo square you will see a field that
says
> file:. This is where you tell the program which .bmp file to use as
the
> employee's photo. It is required. The numbering scheme recommended
is to
> number the .bmp the same as the employee number, however there
doesn't
> actually have to be a .bmp in the server directory in order for it
to
> post changes and save. For example: if you have employee #613,
ideally
> (\\yourservername\mfgsysdata\empphoto\yourcompanyname\
> <file://\\yourservername\mfgsysdata\empphoto\yourcompanyname\> ) you
> would have a .bmp file named 613.bmp and this would display when you
> brought that employee's record up in the Employee Maintenance
dialog.
> The field on Employee Miantenance is required, but the file is not,
so
> you can enter in 613 in the field on the dialog and the record
should
> save even if there is no 613.bmp in the above directory. If this
causes
> you grief, then try and put a dummy .bmp in this directory and name
it
> none.bmp (it could be a paint doc that says "No Photo Available" or
> something), then try and enter "none" in the dialog field and save.
> Hope this helps. ;o)
> Ian Hogan
Behalf
> Of wl_bl
> Sent: Thursday, January 03, 2008 9:12 AM
> Subject: [Vantage] Vantage 8.03.403D Payroll Employee Issue
> We are trying to add our 1st employee and are getting the following
> message: "ImageFile cannot be null". The details of the message are:
> Exception caught in: Epicor.Mfg.BO.PREmployee
> Error Detail
> Message: ImageFile cannot be null.
> Type: Error
> Program: core/BizRuleEngine.p
> Method: ValidateField
> Table: PREmpMas
> Row:
> Field: ImageFile
> Stack Trace
> at Epicor.Mfg.Proxy.PREmployeeImpl.Update(PREmployeeDataSet ds)
> at Epicor.Mfg.UI.Adapters.PREmployeeAdapter.Update()
> at Epicor.Mfg.UI.App.PREmployeeEntry.Transaction.Update()
> Does anyone out there know the cause of this error and what we can
do
> to solve it? Epicor support is having high call volume so I figured
> I would check here while waiting.
> Thanks,
> Wendy Hodgson
> System Administrator
> Nor-Ral Plastics
Error Detail
Type: Error
Table: PREmpMas
Row:
Field: ImageFile
Stack Trace
Does anyone out there know the cause of this error and what we can do
Wendy Hodgson
Nor-Ral Plastics
Hey Wendy, this error is referencing a field in Employee Maintenance. Go
right. Under the employee photo square you will see a field that says
file:. This is where you tell the program which .bmp file to use as the
employee's photo. It is required. The numbering scheme recommended is to
number the .bmp the same as the employee number, however there doesn't
actually have to be a .bmp in the server directory in order for it to
post changes and save. For example: if you have employee #613, ideally
brought that employee's record up in the Employee Maintenance dialog.
The field on Employee Miantenance is required, but the file is not, so
you can enter in 613 in the field on the dialog and the record should
save even if there is no 613.bmp in the above directory. If this causes
you grief, then try and put a dummy .bmp in this directory and name it
Ian Hogan
Of wl_bl
Error Detail
Type: Error
Table: PREmpMas
Row:
Field: ImageFile
Stack Trace
Wendy Hodgson
Nor-Ral Plastics
Ian,
Wendy
Maintenance. Go
says
the
is to
doesn't
to
ideally
dialog.
so
should
causes
it
> Ian Hogan
Behalf
> Of wl_bl
> Error Detail
> Type: Error
> Table: PREmpMas
> Row:
> Field: ImageFile
> Stack Trace
do
> Thanks,
> Wendy Hodgson
> Nor-Ral Plastics
There is a field in PREmpMas called PhotoFile, I believe this is what the
error message is referring to.
We recently setup Payroll Employees (8.803.305k) and use no Photo for
employees and had no issue. Make sure the text box next to File under the
Employee image is blank and does not contain spaces for any reason.
Scott
wl_bl
Sent: Thursday, January 03, 2008 1:05 PM
Ian,
Wendy
Maintenance. Go
says
the
is to
doesn't
to
ideally
dialog.
so
should
causes
it
> Ian Hogan
Behalf
> Of wl_bl
> Error Detail
> Type: Error
> Table: PREmpMas
> Row:
> Field: ImageFile
> Stack Trace
do
> Thanks,
> Wendy Hodgson
> Nor-Ral Plastics
Yahoo! Groups Links
