Vantage 8.03.405a PO Lines Paste Insert
Here is what worked for me - in case sometime in the future someone
else has the same question:
Column A: 0
Column B: PUR-STK
Column C: the part number
Column D: the rev
Column E: the description
Column F: our qty
Column G: supplier qty
Column H: unit price
Steps taken, Create new PO, enter supplier and buyer data. Click on
lines tab, then lines list tab. Copied Columns A-H from Excel and
right clicked on list grid and did Paste Insert. 164 lines in under 3
minutes.
bw
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> I want to copy Excel data and paste into POEntry to create lines,
in
> case I confused anyone about what I want to accomplish.
> --- In vantage@yahoogroups.com, "Linda Lowney" <llowney@> wrote:
> > Just open any purchase order and go to the line list tab. Right
> click
> > in the header area and select copy all, then past this into
Excel.
> The
> > field headings won't copy, but you can key them into Excel
> manually.
> > Linda
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of bw2868bond
> > Sent: Tuesday, December 16, 2008 8:01 AM
> > Subject: [Vantage] Vantage 8.03.405a PO Lines Paste Insert
> > Can anyone tell me the required columns of data for a Excel
> spreadsheet
> > to be used to paset insert a hundred or so PO Lines?
> > Thanks
> > And Happy Holidays to all :o)
Can anyone tell me the required columns of data for a Excel spreadsheet
Just open any purchase order and go to the line list tab. Right click
in the header area and select copy all, then past this into Excel. The
field headings won't copy, but you can key them into Excel manually.
Linda
Of bw2868bond
I want to copy Excel data and paste into POEntry to create lines, in
click
The
manually.
> Linda
Behalf
> Of bw2868bond
spreadsheet
> Thanks
