I have this exact issue at hand. My group wants the "Count Variance Report" in a more user friendly excel format for our year end. Did ever you come up with a soultion? Does it need to be recreated using a BAQ as suggested below? Anything would help. BAQs would be a little new to me, at least when it comes to our production environment. Thanks!
--- In vantage@yahoogroups.com, Waffqle <waffqle@...> wrote:
> Yeah. When push comes to shove, I usually just recreate it via BAQ and work
> with that in Crystal.
> On Thu, Dec 1, 2011 at 5:08 PM, Karen Schoenung <
> kschoenung@...> wrote:
> > Yes, most of those reports are Progress? Reports...You can find the TXT
> > file in your user reports directory and maybe work with it in Excel, but
> > some are too much hassle...
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of vacortes21
> > Sent: Thursday, December 01, 2011 3:47 PM
> > Subject: [Vantage] Re: Vantage (8.03.409C) Print Variance Report Format
> > I dont see a Crystal Report logo on this report. what I find strange is
> > that when i run this report it creates a .TXT file and not an .xml file
> > like I am used to seeing with crystal reports. I think you might be right
> > about this report not being done via Crystal and is not user maintainable.
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Waffqle
> > <waffqle@<mailto:waffqle@>> wrote:
> > > I believe the Variance Report is: CntVar. I don't see other report. Some
> > > older reports are not done via Crystal and are not user maintainable
> > > without the SDK.
> > > When you run the report, look at the top right corner of the window. If
> > it
> > > is a Crystal report it will have a little 'Crystal Reports' logo.
> > > On Thu, Dec 1, 2011 at 11:58 AM, vacortes21 <vcortes@<mailto:vcortes@
> > ...>>wrote:
> > > > Hi, I was asked to change the format of the "Print Variance Report" and
> > > > "Print Recount Report" under "Count Group Entry"! unfortunatly I can'y
> > > > figure out the Report Data Defenition or evenfind any .rpt files
> > related to
> > > > these reports.
> > > > Has anyone worked on these reports? Can you point me in the right
> > > > direction?
> > > > thanks,
> > > > have a great day
> > > *Waffqle Driggers*
> > > *High End Dev, System Design, Profit Drinking
> > > *:: 904.962.2887*
> > > *:: waffqle@*<mailto:waffqle@*>
> > > *:: NO FAXES*
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
