Vantage 8.03.409C: System.Threading and BO
I am not understanding how to utilize this bit of code. I used your suggestion of the free internet C#toVB converter tools and got back this, obviously replacing the YOURFORM with UD01Form:
YOURFORM.Invoke(DirectCast(Function() Do
' CD 7/11/2012
' Changed rows to 5 for testing.
' TODO: Set rows=grdJobs.Rows.Count after testing is done.
pbProgress.Maximum = rows
pbProgress.Minimum = 0
pbProgress.Value = 0
pbProgress.[Step] = 1
End Function, ThreadStart))
So am I suppose to take my function that I want the Thread.Start to be associated with and place it in the location that covers "Function()" through to "End Function"? It is not working for me. I am getting a number of errors.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Wednesday, August 15, 2012 11:12 AM
Subject: Re: [Vantage] Vantage 8.03.409C: System.Threading and BO
You can update the UI you just have to do it Thread Safe
YOURFORM.Invoke((ThreadStart)delegate()
// CD 7/11/2012
// Changed rows to 5 for testing.
// TODO: Set rows=grdJobs.Rows.Count after testing is done.
pbProgress.Maximum=rows;
pbProgress.Minimum=0;
pbProgress.Value=0;
pbProgress.Step=1;
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
Has anyone used threading with Business Objects? I am trying to use it to spawn a thread for a method that takes 5 minutes. I am utilizing the DynamicQueryAdapter in my method.
the strange thing is that I can call the BOConnect(), GetByID(), AddWhereItem() and Update methods, but when I try to call the Execute method it crashes.
Does anyone have any thoughts and/or ideas on this?
Dan
I've done it several times, how are you doing it? You can't update UI items
from a thread, so if its updating UI that's where your crash is happening
your best bet is to instanciate a new BO do your stuff and then refresh the
UI once its donre.l
*Jose C Gomez*
*Software Engineer*
E: jose@...
> method it crashes.
> Dan
What I am doing is calling a BAQ and then adding two where clauses for the PartNum and RevisionNum. I then execute the BAQ. This is all done with local parameters inside of the method that I delegate for the thread. Should I set the DynamicQueryAdapter object as global so that it is owned by the Form?
Sent: Tuesday, August 14, 2012 2:39 PM
I've done it several times, how are you doing it? You can't update UI items from a thread, so if its updating UI that's where your crash is happening your best bet is to instanciate a new BO do your stuff and then refresh the UI once its donre.l
*Jose C Gomez*
*Software Engineer*
E: jose@...
> method it crashes.
> Dan
You shouldn't need to. What is the error you're receiving? If you stick
your code up here it will likely help a lot.
> by the Form?
> Of Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > method it crashes.
> > Dan
Here is the code, thanks ahead of time if you guys can help me out on this.
Dan
'// Custom VB.NET code for UD01Form
'// Created: 6/5/2008 1:06:23 PM
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
IMPORTS System.IO
Imports Epicor.Mfg.BO
Imports Infragistics.Win
Imports Infragistics.Shared
Imports Infragistics.Win.UltraWinGrid
Imports System.Reflection
Imports Infragistics.Win.UltraWinToolBars
Imports System.Threading
Module Script
'// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
'// Begin Wizard Added Module Level Variables **
'// End Wizard Added Module Level Variables **
'// Add Custom Module Level Variables Here **
Private WithEvents timephasAdapter As TimePhasAdapter
Private WithEvents edvTimePhas As EpiDataView
Private dsAvailability AS System.Data.DataSet
Private dsTimePhase AS System.Data.DataSet
Private nAvailabilityDataColumns AS Integer = 0
Private nTimePhaseDataColumns AS Integer = 0
Private Const sAvailabilityBAQID AS String = "AMC-AVAILABILITY02"
Private bDeveloperLoggedIn AS Boolean = False
Private bGridSizeSet AS Boolean = False
Private Const nGridID_ComponentAvailability AS Integer = 1
Private Const nGridID_TimePhase AS Integer = 2
Private bFormLoaded AS Boolean = False
Private baseToolbarsManager As Infragistics.Win.UltraWinToolbars.UltraToolbarsManager
Private sCurrentPartNum AS String = String.Empty
Private dteShortageDate AS Date
Private nAvailableQty AS Decimal = 0
Private bCancelRetrieve AS Boolean = False
Private thrdSpawnNewThread AS Thread
'Private dynQryAD As DynamicQueryAdapter = New DynamicQueryAdapter(UD01Form)
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
'// Begin Wizard Added Variable Intialization
'// End Wizard Added Variable Intialization
'// Begin Custom Method Calls
If Thread.CurrentThread.Name = Nothing Then
thrdSpawnNewThread.CurrentThread.Name = "RetrieveAvailabilityData"
End If
'dynQryAD = New DynamicQueryAdapter(UD01Form)
'dynQryAD.BOconnect()
dsAvailability = New System.Data.DataSet("Results")
dsTimePhase = New System.Data.DataSet("Results")
timephasAdapter = New timephasAdapter(oTrans)
timephasAdapter.BOConnect()
edvTimePhas = new EpiDataView()
edvTimePhas.dataView = New DataView(timephasAdapter.TimePhasData.TimePhas)
If Not (oTrans.EpiDataViews.ContainsKey("TimePhasView")) Then
oTrans.Add("TimePhasView",edvTimePhas)
End If
dim obj as Object = GetType(Epicor.Mfg.UI.App.UD01Entry.UD01Form).InvokeMember("baseToolbarsManager", BindingFlags.Instance Or BindingFlags.GetField Or BindingFlags.NonPublic, Nothing, UD01Form, Nothing)
BaseToolbarsManager = ctype(obj,Infragistics.Win.UltraWinToolbars.UltraToolbarsManager)
AddHandler baseToolbarsManager.ToolClick, AddressOf baseToolbarsManager_ToolClick
'// End Custom Method Calls
End Sub
Private Sub baseToolbarsManager_ToolClick(ByVal sender As Object, ByVal args As Infragistics.Win.UltraWinToolbars.ToolClickEventArgs)
Select case args.tool.key
Case "ClearTool"
ClearData(False)
'MyMessageBox("ClearTool.Click", True, MsgBoxStyle.OKOnly, "baseToolbarsManager.ToolClick")
End Select
End Sub
Sub DestroyCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
'// Begin Wizard Added Object Disposal
'// End Wizard Added Object Disposal
'// Begin Custom Code Disposal
'// End Custom Code Disposal
releaseObject(edvTimePhas)
timephasAdapter.Dispose()
releaseObject(timephasAdapter)
dsTimePhase.Dispose()
releaseObject(dsTimePhase)
dsAvailability.Dispose()
releaseObject(dsAvailability)
'dynQryAD.Dispose()
'releaseObject(dynQryAD)
End Sub
Private Sub UD01Form_Load(ByVal sender As object, ByVal args As EventArgs) Handles UD01Form.Load
'// Add Event Handler Code
Dim userID As String = UD01Form.Session.UserID
bFormLoaded = False
bDeveloperLoggedIn = False
Select userID
Case "dgodfrey"
bDeveloperLoggedIn = True
Case Else
End Select
AddingDataColumns(dsAvailability, ugdBOMGrid, nGridID_ComponentAvailability)
'AddingDataColumns(dsTimePhase, ugdTimePhase, nGridID_TimePhase)
ugdBOMGrid.Width = 1070
ugdBOMGrid.Height = 165
ugdBOMGrid.Height = 250
grpFilters.Show()
chkExceptionsOnly.Show()
lblExceptionsOnly.Show()
chkExceptionsOnly.Checked = False
chkExcludeConsignments.Show()
chkExcludeConsignments.Checked = False
grpTimePhaseFilters.Show()
chkSuggestions.Show()
lblSuggestions.Show()
chkSuggestions.Checked = False
chkForecasting.Checked = False
IF(bDeveloperLoggedIn) Then
btnShowSize.Show()
ChkForecasting.Show()
lblForecasting.Show()
btnCancelRetrieve.Show()
Else
ChkForecasting.Hide()
lblForecasting.Hide()
btnShowSize.Hide()
btnCancelRetrieve.Hide()
End If
Dim myTreeViewPanel as Epicor.Mfg.UI.FrameWork.EpiTreeViewPanel = CType(csm.GetNativeControlReference("ff47e708-60d7-4586-9708-91a5d57fb7a6"), Epicor.Mfg.UI.FrameWork.EpiTreeViewPanel)
Dim myMainPanel as Epicor.Mfg.UI.App.UD01Entry.MainPanel = CType(csm.GetNativeControlReference("1dff11bc-3024-4d17-acfc-b7af287e274b"), Epicor.Mfg.UI.App.UD01Entry.MainPanel)
myTreeViewPanel.Dispose()
myMainPanel.Dispose()
bFormLoaded = True
otrans.pushstatustext("Ready!", False)
End Sub
'/**************** Start of Generic Function *************************/
Private Sub ClearData(ByVal bGridOnly AS Boolean)
IF(bGridOnly = False) Then
txtBOMPartNum.Text = String.Empty
txtPartDescription.Text = String.Empty
txtBOMRevisionNum.text = String.Empty
txtProductionQty.Text = String.Empty
End If
dsAvailability.Tables(0).Rows.Clear()
ugdBOMGrid.Text = "BOM Components"
ugdTimePhase.Text = "Time Phase Inquiry"
timephasAdapter.clearData()
edvTimePhas.EpiDataChanged()
End Sub
Private Sub ShowSize()
DIM msg AS String = String.Empty
msg = msg & "Form Size:" & chr(13) & chr(10)
msg = msg & "Bottom = " & ugdBOMGrid.FindForm().Bottom & ", Top = " & ugdBOMGrid.FindForm().Top & ", Width = " & ugdBOMGrid.FindForm().Width & ", Height = " & ugdBOMGrid.FindForm().Height & chr(13) & chr(10)
msg = msg & "ugdBOMGrid Size:" & chr(13) & chr(10)
msg = msg & "Bottom = " & ugdBOMGrid.Bottom & ", Top = " & ugdBOMGrid.Top & ", Width = " & ugdBOMGrid.Width & ", Height = " & ugdBOMGrid.Height & chr(13) & chr(10)
msg = msg & "ugdTimePhase Size:" & chr(13) & chr(10)
msg = msg & "Bottom = " & ugdTimePhase.Bottom & ", Top = " & ugdTimePhase.Top & ", Width = " & ugdTimePhase.Width & ", Height = " & ugdTimePhase.Height & chr(13) & chr(10)
MyMessageBox(msg, bDeveloperLoggedIn, MsgBoxStyle.OKOnly, "Grid Sizes")
End Sub
Private Sub ValidateGridSize()
Dim nWidth AS Integer = ugdBOMGrid.FindForm().Width
Dim nHeight AS Integer = ugdBOMGrid.FindForm().Height
DIM nCriteriaAreaPlusFooting AS Integer = 250
Dim nSpaceBtwnGrids AS Integer = 5
ugdBOMGrid.Width = (nWidth - 50)
ugdBOMGrid.Height = (nHeight - nCriteriaAreaPlusFooting) *.4
ugdTimePhase.Left = ugdBOMGrid.Left
ugdTimePhase.Top = ugdBOMGrid.Top + ugdBOMGrid.Height + nSpaceBtwnGrids
ugdTimePhase.Width = ugdBOMGrid.Width
ugdTimePhase.Height = (nHeight - nCriteriaAreaPlusFooting) *.6
btnShowSize.Left = ugdBOMGrid.Left
btnShowSize.Top = ugdTimePhase.Top + ugdTimePhase.Height + nSpaceBtwnGrids
ugdBOMGrid.Anchor = AnchorStyles.Bottom Or AnchorStyles.Right Or AnchorStyles.Left Or AnchorStyles.Top
'ugdTimePhase.Anchor = AnchorStyles.Bottom Or AnchorStyles.Right Or AnchorStyles.Left Or AnchorStyles.Top
bGridSizeSet = True
'ShowSize()
End Sub
Private Sub GridCustomization(ByRef Collection AS Infragistics.Win.UltraWinGrid.ColumnsCollection, ByVal GridIdentifier AS Integer)
Dim column AS Infragistics.Win.UltraWinGrid.UltraGridColumn
IF(GridIdentifier = nGridID_ComponentAvailability) Then
For each column in Collection
Select column.Header.Caption
Case "Rev", "Part Number", "RevDescription", "Rel Opr.", "TotalDemandQty"
column.Hidden = True
Case "Lvl"
column.Width = 30
column.CellAppearance.TextHAlign = HAlign.Right
Case "MtlSeq", "Lead"
column.Width = 50
Case "Material Part"
column.Width = 150
Case "PartDescription"
column.Width = 250
Case "Type"
column.Width = 50
Case "RequiredQty"
column.Width = 75
column.MaskInput = "-nnnn,nnn,nnn,nnn.nn"
Case "ClassID"
column.Width = 50
Case "TotalQtyOnHand", "AvailableQty"
column.Width = 125
Case Else
'column.Hidden = True
End Select
Next Column
Else'nGridID_TimePhase
Dim nOrdinal AS Integer = 0
Case "Due"
'column.Ordinal = 0
Case "Receipts"
'column.Ordinal = 1
Case "Job"
'column.Ordinal = 2
Case "Order"
'column.Ordinal = 3
Case "RequiredQty"
'column.Ordinal = 4
Case "PO"
'column.Ordinal = 5
Case "Lead"
'column.Ordinal = 6
Case "Balance"
'column.Ordinal = 7
Case "Exception"
'column.Ordinal = 8
Case "Order By"
'column.Ordinal = 9
Case "Source"
'column.Ordinal = 10
Case "JobStatus"
'column.Ordinal = 11
'nOrdinal = 11
Case Else
'nOrdinal = nOrdinal + 1
End Select
Next Column
End IF
End Sub 'GridCustomization(ByRef Collection AS Infragistics.Win.UltraWinGrid.ColumnsCollection, ByVal GridIdentifier AS Integer)
Private Sub TransferDataRow(ByRef myDataSet AS System.Data.DataSet,ByVal nFirstColumnIndex AS Integer, ByVal nColumnCnt AS Integer, ByVal SrcRow AS DataRow)
' Instantiate a new row using the NewRow method.
Dim newRow As DataRow = myDataSet.Tables("Results").NewRow()
Dim i AS Integer = 0
'Insert code to fill the row with values.
For i = nFirstColumnIndex To nColumnCnt
newRow.Item(i) = SrcRow.Item(i)
Next i
'Add the row to the DataRowCollection.
myDataSet.Tables("Results").Rows.Add(newRow)
myDataSet.Tables("Results").AcceptChanges()
End Sub 'TransferDataRow(ByRef myDataSet AS System.Data.DataSet,ByVal nFirstColumnIndex, ByVal nColumnCnt AS Integer, ByVal SrcRow AS DataRow)
Private Sub AddingDataColumns(ByRef myDataSet AS System.Data.DataSet, ByRef myGrid AS Epicor.Mfg.UI.FrameWork.EpiUltraGrid, ByVal GridIdentifier AS Integer)
IF(myDataSet.Tables.Count <= 0)Then
myDataSet.Tables.Add("Results")
End If
'// ** Place Event Handling Code Here **
otrans.pushstatustext("Retrieving Data ...", False)
'Dim sStatusString as String = String.Empty
Dim sStatusString AS String = String.EMpty
Dim nColumns AS Integer = 0
Dim dynQryAD As DynamicQueryAdapter = New DynamicQueryAdapter(UD01Form)
Dim sBaqID AS String = sAvailabilityBAQID
sBaqID = sAvailabilityBAQID
dynQryAD.GetByID(sBaqID)
For Each DR AS DataRow in dynQryAD.QueryDesignData.Tables("SelectedField").Rows
nColumns = nColumns + 1
sStatusString = "AddingDataColumns function: Adding " & nColumns & "/" & dynQryAD.QueryDesignData.Tables("SelectedField").Rows.Count & " ColumnName: " & DR.Item("FieldLabel") & " is " & DR.Item("DataType").ToString().ToUpper()
WriteToLogFile(sStatusString)
Select DR.Item("DataType").ToString().ToUpper()
Case "CHARACTER"
myDataSet.Tables("Results").Columns.Add(DR.Item("FieldLabel"), Type.GetType("System.String"))
Case "INTEGER"
myDataSet.Tables("Results").Columns.Add(DR.Item("FieldLabel"), Type.GetType("System.Int32"))
Case "DECIMAL"
myDataSet.Tables("Results").Columns.Add(DR.Item("FieldLabel"), Type.GetType("System.Decimal"))
Case "LOGICAL"
myDataSet.Tables("Results").Columns.Add(DR.Item("FieldLabel"), Type.GetType("System.Boolean"))
Case "DATE"
myDataSet.Tables("Results").Columns.Add(DR.Item("FieldLabel"), Type.GetType("System.DateTime"))
Case Else
End Select
myDataSet.Tables(0).AcceptChanges()
Next
nAvailabilityDataColumns = nColumns - 1
dynQryAD.Dispose()
End If
myGrid.DataSource = myDataSet
GridCustomization(myGrid.DisplayLayout.Bands(0).Columns, GridIdentifier)
End Sub 'AddingDataColumns()
Private Function ShowDebugInformation() AS String
Dim sRet AS String
'& Chr(13) & Chr(10)
sRet = "Debug Data:" & Chr(13) & Chr(10)
sRet = sRet & "- UserID = " & UD01Form.Session.UserID & Chr(13) & Chr(10)
sRet = sRet & "- UserName = " & UD01Form.Session.UserName & Chr(13) & Chr(10)
sRet = sRet & "- UserEmail = " & UD01Form.Session.UserEmail & Chr(13) & Chr(10)
sRet = sRet & "- ProductName = " & UD01Form.Session.ProductName & Chr(13) & Chr(10)
sRet = sRet & "- ProductCode = " & UD01Form.Session.ProductCode & Chr(13) & Chr(10)
WriteToLogFile(sRet)
Return sRet
End Function 'ShowDebugInformation() AS String
Private Function ShowDataSet(ByVal myDataSet AS System.Data.DataSet) AS String
Dim sRet AS String = String.Empty
sRet = "INSIDE ShowDataSet:" & chr(13) & chr(10)
sRet = String.Empty
For each Table as DataTable in myDataSet.Tables
sRet = sRet & "Table: " & Table.TableName & chr(13) & chr(10)
For Each DR AS DataRow in Table.Rows
For Each DC as DataColumn in Table.Columns
IF(DC.ColumnName = "RowIdent") Then
Exit For
End If
sRet = sRet & DC.ColumnName & ":" & DR(DC.ColumnName)& ", "
Next'For Each DC as DataColumn in Table.Columns
sRet = sRet & chr(13) & chr(10)
Next'For Each DR AS DataRow in Table.Rows
Next'For each Table
Return sRet
End Function 'ShowDataSet(ByVal myDataSet AS System.Data.DataSet) AS String
Private Function GetDataColumnInformation(ByVal myDataTable AS DataTable) AS String
sRet = "INSIDE GetDataColumnInformation:" & chr(13) & chr(10)
sRet = String.Empty
For Each DC as DataColumn in myDataTable.Columns
sRet = sRet & DC.ColumnName & ", "
Return sRet
End Function 'GetDataColumnInformation(ByVal myDataTable AS DataTable) AS String
''' <summary>
''' Copies the the specified number of rows from the top of the specified table.
''' </summary>
''' <param name="table">
''' The table containing the original rows.
''' </param>
''' <param name="rowCount">
''' The number of rows to copy.
''' </param>
''' <param name="useView">
''' Indicates whether the row order should be based on the DefaultView or not.
''' </param>
''' <returns>
''' A DataTable containing the copied rows.
''' </returns>
Private Function GetTopRows(ByVal table As DataTable, _
ByVal rowCount As Integer, _
ByVal useDefaultView As Boolean) As DataTable
'You can't get more rows than exist.
If useDefaultView Then
rowCount = Math.Min(rowCount, table.DefaultView.Count)
Else
rowCount = Math.Min(rowCount, table.Rows.Count)
End If
'Copy the table schema.
Dim topTable As DataTable = table.Clone()
'Copy the specified number of rows.
For rowIndex As Integer = 0 To rowCount - 1 Step 1
'Take the top rows from the DeafultView.
topTable.ImportRow(table.DefaultView(rowIndex).Row)
Else
'Take the top rows from the original table.
topTable.ImportRow(table.Rows(rowIndex))
End If
Next rowIndex
Return topTable
End Function
Private Function WriteToLogFile(ByVal TextString AS String) as Boolean
Dim bResults AS Boolean = False
Dim sInputString AS String = TextString & Chr(13) & Chr(10)
Dim sPath AS String = "C:\BOM_CAR_log.txt"
IF(File.Exists(sPath) = False) Then
' Create a file to write to.
File.WriteAllText(sPath, sInputString)
bResults = True
Else
' This text is always added, making the file longer over time
' if it is not deleted.
File.AppendAllText(sPath, sInputString)
bResults = True
End If
return bResults
End Function 'WriteToLogFile(ByVal TextString AS String) as Boolean
Private Function MyMessageBox( ByVal Msg AS String, ByVal FYI AS Boolean,Optional ByVal Button As MsgBoxStyle = MsgBoxStyle.OKOnly, Optional ByVal Title As String = Nothing) As MsgBoxResult
Dim results As MsgBoxResult
If(FYI = True) Then
If Not String.IsNullOrEmpty(Title) Then
results = MsgBox(Msg, Button, Title)
Else
results = MsgBox(Msg, Button)
End If
End If
return results
End Function 'MyMessageBox( ByVal Msg AS String, ByVal FYI AS Boolean,Optional ByVal Button As MsgBoxStyle = MsgBoxStyle.OKOnly, Optional ByVal Title As String = Nothing) As MsgBoxResult
Private Function FindValueFromArray(ByVal Values As Object(), ByVal valueToSearch As Object) As Integer
Dim retVal As Integer = 0
Dim myArray As Array = DirectCast(Values, Array)
If Array.IndexOf(myArray, valueToSearch) <> -1 Then
retVal = Array.IndexOf(myArray, valueToSearch)
Else
retVal = -1
End If
Return retVal
End Function 'FindValueFromArray(ByVal Values As Object(), ByVal valueToSearch As Object) As Integer
Private Sub releaseObject(ByVal obj As Object)
Try
System.Runtime.InteropServices.Marshal.ReleaseComObject(obj)
obj = Nothing
Catch ex As Exception
obj = Nothing
Finally
GC.Collect()
End Try
End Sub 'releaseObject(ByVal obj As Object)
'/**************** End of Generic Function ***************************/
'/**************** Start of BOM_CAR Function *************************/
Private Sub btnCancelRetrieve_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnCancelRetrieve.Click
IF(btnRetrieve.Enabled = False) Then
bCancelRetrieve = True
'thrdSpawnNewThread.Abort
'ClearData(True)
End If
End Sub
Private Sub ugdBOMGrid_Resize(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles ugdBOMGrid.Resize
ValidateGridSize()
End Sub
Private Sub btnRetrieve_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnRetrieve.Click
thrdSpawnNewThread = new Thread(AddressOf RetrieveAvailabilityData)
thrdSpawnNewThread.Start
'RetrieveAvailabilityData()
IF(bGridSizeSet = False) Then
ValidateGridSize()
End If
btnRetrieve.Enabled = True
End Sub
Private Function GetShortageQtyANDDate(ByVal sPartNum AS String, ByVal nRequiredQty AS Decimal, ByRef sDate AS Date, ByRef Quantity AS Decimal) AS Boolean
Dim blTimePhas As Boolean = timephasAdapter.GoProcessTimePhase(sPartNum, "MfgSys", chkSuggestions.Checked, False)
'ShowDataSet(timephasAdapter.TimePhasData)
IF(blTimePhas = True) Then
For Each drRow as DataRow in timephasAdapter.TimePhasData.Tables("TimePhas").Rows
drRow.Item("BalanceQty") = drRow.Item("BalanceQty") - nRequiredQty
Quantity = drRow.Item("BalanceQty")
IF(Quantity <= 0) then
blTimePhas = True
IF(drRow.Item("DueDate").ToString() <> "") then
sDate = drRow.Item("DueDate").Date
End If
Exit For
Else
blTimePhas = False
End If
Next
timephasAdapter.TimePhasData.Tables("TimePhas").AcceptChanges()
End If
Return blTimePhas
End Function
Private Sub RetrieveTimePhaseInquiry()
IF(ugdBOMGrid.Text <> "") Then
otrans.pushstatustext("Retrieving TimePhase Data ...", True)
Dim blTimePhas As Boolean = GetShortageQtyANDDate(ugdBOMGrid.ActiveRow.GetCellText(ugdBOMGrid.ActiveRow.Band.Columns("Material Part")), ugdBOMGrid.ActiveRow.GetCellText(ugdBOMGrid.ActiveRow.Band.Columns("RequiredQty")), dteShortageDate, nAvailableQty)
ugdTimePhase.Text = "Time Phase Inquiry: Part: " & ugdBOMGrid.ActiveRow.GetCellText(ugdBOMGrid.ActiveRow.Band.Columns("Material Part")) & " Description: " & ugdBOMGrid.ActiveRow.GetCellText(ugdBOMGrid.ActiveRow.Band.Columns("PartDescription"))
End IF
End Sub
Private Sub RetrieveAvailabilityData()
Dim pcTable As String = "PartRev"
Dim pcField As String = "PartNum"
Dim pbIsConst As Boolean = TRUE
Dim pcCondition As String = "="
Dim pcToValue as String = txtBOMPartNum.Text
Dim pcToTable As String = String.Empty
Dim pcToField As String = String.Empty
Dim pcRightParentheses as String = String.Empty
Dim pcLeftParentheses as String = String.Empty
Dim pcAndOr as String = String.Empty
Dim pbNeg as Boolean = False
Try
WriteToLogFile("Retrieving Availability Data ...")
otrans.pushstatustext("Retrieving Availability Data ...", True)
ugdBOMGrid.DataSource.Tables(0).Rows.Clear()
dynQryAD.GetByID(sAvailabilityBAQID)
dynQryAD.AddWhereItem(dynQryAD.QueryDesignData, sAvailabilityBAQID, pcTable, pcField, pcCondition, pbIsConst, pcToValue, pcToTable, pcToField, pcLeftParentheses, pcRightParentheses, pcAndOr, pbNeg)
dynQryAD.Update
pcField = "RevisionNum"
pcToValue = txtBOMRevisionNum.Text.ToString()
pcAndOr = "AND"
dynQryAD.Update
ugdBOMGrid.DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.True
WriteToLogFile("copy all data from QueryDesignData tables to DynamicQueryData tables (only for tables that exist in both datasets)")
'//copy all data from QueryDesignData tables to DynamicQueryData tables (only
'for tables that exist in both datasets
Dim targetRow as DataRow
For each Table as DataTable in dynQryAD.DynamicQueryData.Tables
If Table.Rows.Count = 0 Then
For Each sourceRow as DataRow in dynQryAD.QueryDesignData.Tables(Table.ToString()).Rows
targetRow = Table.NewRow()
targetRow.ItemArray = sourceRow.ItemArray
Table.Rows.Add(targetRow)
Next
End If
Next'For each Table as DataTable in dynQryAD.DynamicQueryData.Tables
WriteToLogFile("dynQryAD.Execute(dynQryAD.DynamicQueryData)")
WriteToLogFile("Processing " & dynQryAD.QueryResults.Tables("Results").Rows.Count & " Query records.")
otrans.pushstatustext("Processing " & dynQryAD.QueryResults.Tables("Results").Rows.Count & " Query records.", True)
Dim RecCnt AS Integer = 0
Dim AddToGrid AS Boolean = True
Dim bNegAvail AS boolean = False
WriteToLogFile("Pre-Filtered DataSet")
ShowDataSet(dynQryAD.QueryResults)
For Each ORow as DataRow in dynQryAD.QueryResults.Tables(0).Rows
'myDataSet has records
IF(bCancelRetrieve = True) Then
ClearData(True)
Exit For
End If
AddToGrid = True
ORow.Item("RequiredQty") = ORow.Item("RequiredQty") * txtProductionQty.Value
nAvailableQty = ORow.Item("PartPlant.Number01") - ORow.Item("RequiredQty")
dteShortageDate = Today()
IF(nAvailableQty > 0) then
bNegAvail = GetShortageQtyANDDate(ORow.Item("ECOMtl.MtlPartNum"), ORow.Item("RequiredQty"), dteShortageDate, nAvailableQty)
Else
bNegAvail = True
End If
ClearData(True)
Exit For
End If
ORow.Item("ShortageDate") = dteShortageDate.Date
ORow.Item("AvailableQty") = nAvailableQty
IF(chkExceptionsOnly.Checked = True) Then
AddToGrid = bNegAvail
End If
IF(chkExcludeConsignments.Checked) Then
Select ORow.Item("Part.ClassID")
Case "CARR"
AddToGrid = False
Case "CTTI"
AddToGrid = False
Case "CAVN"
AddToGrid = False
Case Else
AddToGrid = AddToGrid
End Select
End If
ClearData(True)
Exit For
End If
If(AddToGrid) then
RecCnt = RecCnt + 1
TransferDataRow(dsAvailability, 0, nAvailabilityDataColumns, ORow)
End If
Next'For Each ORow as DataRow in dynQryAD.QueryResults.Tables(0).Rows
bCancelRetrieve = False
Else
otrans.pushstatustext("Processed " & RecCnt & " Component records.", True)
WriteToLogFile("Processed " & RecCnt & " Component records.")
WriteToLogFile("Grid-Filtered DataSet")
ShowDataSet(dsAvailability)
dsAvailability.Tables("Results").Columns("Material Part").ExtendedProperties("Like") = "Part.PartNum"
dsAvailability.Tables("Results").AcceptChanges()
IF(RecCnt > 0) Then
ugdBOMGrid.Text = dsAvailability.Tables(0).Rows(0).Item("RevDescription")
txtPartdescription.Text = dsAvailability.Tables(0).Rows(0).Item("RevDescription")
ugdBOMGrid.DataSource = dsAvailability
GridCustomization(ugdBOMGrid.DisplayLayout.Bands(0).Columns, nGridID_ComponentAvailability)
Else
MyMessageBox("There was no exceptions found.", True, MsgBoxStyle.OKOnly, "Availability Report")
End If
ugdBOMGrid.DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.False
End If
Catch abortException As ThreadAbortException
MyMessageBox(abortException.Message & ": " & CType(abortException.ExceptionState, String), True, MsgBoxStyle.OKOnly, "Availability Report")
finally
dynQryAD.Dispose()
End Try
End Sub 'RetrieveSalesData()
Private Sub btnPartRevSearch_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnPartRevSearch.Click
Dim recordSelected As Boolean
Dim sPart AS String = txtBOMPartNum.Text
Dim wClause AS String = "PartNum >= '" + sPart + "'"
IF(sPart.length() <= 0) Then
wClause = String.Empty
End If
Dim dsSearch As DataSet = SearchFunctions.listLookup(UD01Form, "PartRevSearchAdapter", recordSelected, True, wClause, False)
If( recordSelected) Then
txtBOMPartNum.Text = dsSearch.Tables(0).Rows(0)("PartNum")
txtBOMRevisionNum.Text = dsSearch.Tables(0).Rows(0)("RevisionNum")
End If
End Sub
Private Sub btnShowSize_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnShowSize.Click
ShowSize()
End Sub
Private Sub ugdBOMGrid_AfterRowActivate(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles ugdBOMGrid.AfterRowActivate
End Sub
Private Sub chkSuggestions_AfterCheckStateChanged(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles chkSuggestions.AfterCheckStateChanged
IF(bFormLoaded) Then
End If
End Sub
Private Sub txtBOMPartNum_Leave(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles txtBOMPartNum.Leave
IF(txtBOMPartNum.Text <> sCurrentPartNum) Then
txtBOMRevisionNum.Text = GetLatestPartRev(txtBOMPartNum.Text)
sCurrentPartNum = txtBOMPartNum.Text
End If
End Sub
Private Function GetLatestPartRev (ByVal sPartNum As string) As string
Dim sPartRev As String = String.Empty
Dim recSelected As Boolean = False
Dim swhereClause AS String = "PartNum = '" & sPartNum & "'"
dsSearch = SearchFunctions.listLookup(oTrans, "PartRevSearchAdapter", recSelected, False, swhereClause, True)
If recSelected Then
sPartRev = dsSearch.Tables(0).Rows(dsSearch.Tables(0).Rows.Count() - 1).Item("RevisionNum")
Else
MyMessageBox("The PartNum you entered does not have a valid Revision Number.", True, MsgBoxStyle.OKOnly, "Invalid Part Number")
End If
Return sPartRev
End Function
End Module
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Sent: Wednesday, August 15, 2012 7:35 AM
You shouldn't need to. What is the error you're receiving? If you stick your code up here it will likely help a lot.
> owned by the Form?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Dan
WOW ok that's a lot of code, but anything in RetrieveAvailabilityData
which touches the UI has got to go
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Dan
> Imports System
> Imports System.Data
> IMPORTS System.IO
> Module Script
> End If
> End If
> dim obj as Object =
> End Sub
> Case "ClearTool"
> ClearData(False)
> End Select
> End Sub
> 'dynQryAD.Dispose()
> End Sub
> bFormLoaded = False
> Select userID
> Case "dgodfrey"
> Case Else
> End Select
> grpFilters.Show()
> btnShowSize.Show()
> Else
> btnShowSize.Hide()
> End If
> bFormLoaded = True
> End Sub
> End If
> End Sub
> chr(13) & chr(10)
> End Sub
> bGridSizeSet = True
> 'ShowSize()
> End Sub
> Integer)
> Case "Lvl"
> column.Width = 30
> column.Width = 50
> column.Width = 150
> column.Width = 250
> Case "Type"
> column.Width = 50
> Case "RequiredQty"
> column.Width = 75
> Case "ClassID"
> column.Width = 50
> column.Width = 125
> Case Else
> End Select
> Next Column
> Case "Due"
> 'column.Ordinal = 0
> Case "Receipts"
> 'column.Ordinal = 1
> Case "Job"
> 'column.Ordinal = 2
> Case "Order"
> 'column.Ordinal = 3
> Case "RequiredQty"
> 'column.Ordinal = 4
> Case "PO"
> 'column.Ordinal = 5
> Case "Lead"
> 'column.Ordinal = 6
> Case "Balance"
> 'column.Ordinal = 7
> Case "Exception"
> 'column.Ordinal = 8
> Case "Order By"
> 'column.Ordinal = 9
> Case "Source"
> Case "JobStatus"
> 'nOrdinal = 11
> Case Else
> End Select
> Next Column
> End IF
> Integer)
> DataRow)
> Next i
> AS Integer)
> End If
> Case "CHARACTER"
> Case "INTEGER"
> Case "DECIMAL"
> Case "LOGICAL"
> Case "DATE"
> Case Else
> End Select
> Next
> dynQryAD.Dispose()
> End If
> Dim sRet AS String
> Chr(10)
> Chr(10)
> & Chr(10)
> & Chr(10)
> Return sRet
> String
> sRet = String.Empty
> Exit For
> End If
> Next'For each Table
> Return sRet
> AS String
> sRet = String.Empty
> Return sRet
> String
> ''' <summary>
> table.
> ''' </summary>
> ''' </param>
> ''' </param>
> not.
> ''' </param>
> ''' <returns>
> ''' </returns>
> Else
> End If
> Else
> End If
> Next rowIndex
> Return topTable
> End Function
> bResults = True
> Else
> bResults = True
> End If
> return bResults
> If(FYI = True) Then
> Else
> End If
> End If
> return results
> Else
> retVal = -1
> End If
> Return retVal
> Try
> obj = Nothing
> obj = Nothing
> Finally
> GC.Collect()
> End Try
> 'ClearData(True)
> End If
> End Sub
> ValidateGridSize()
> End Sub
> ValidateGridSize()
> End If
> End Sub
> Boolean
> blTimePhas = True
> End If
> Exit For
> Else
> blTimePhas = False
> End If
> Next
> End If
> Return blTimePhas
> End Function
> Part")),
> End IF
> End Sub
> Try
> dynQryAD.Update
> pcAndOr = "AND"
> dynQryAD.Update
> (only
> Next
> End If
> True)
> ClearData(True)
> Exit For
> End If
> AddToGrid = True
> Else
> bNegAvail = True
> End If
> ClearData(True)
> Exit For
> End If
> End If
> Case "CARR"
> AddToGrid = False
> Case "CTTI"
> AddToGrid = False
> Case "CAVN"
> AddToGrid = False
> Case Else
> End Select
> End If
> ClearData(True)
> Exit For
> End If
> If(AddToGrid) then
> RecCnt = RecCnt + 1
> End If
> Else
> IF(RecCnt > 0) Then
> Else
> End If
> End If
> finally
> dynQryAD.Dispose()
> End Try
> End If
> End If
> End Sub
> ShowSize()
> End Sub
> End Sub
> End If
> End Sub
> End If
> End Sub
> If recSelected Then
> Else
> End If
> Return sPartRev
> End Function
> End Module
> Of John Driggers
> thread.
> > owned by the Form?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Dan
Ok, I will work on that, thanks.
Sent: Wednesday, August 15, 2012 8:36 AM
WOW ok that's a lot of code, but anything in RetrieveAvailabilityData which touches the UI has got to go
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Dan
> Imports System
> Imports System.Data
> IMPORTS System.IO
> Imports Infragistics.Win.UltraWinToolBars Imports System.Threading
> Module Script
> Module Level Variables' Comments! ** '// Begin Wizard Added Module
> Level Variables **
> '// Add Custom Module Level Variables Here ** Private WithEvents
> timephasAdapter As TimePhasAdapter Private WithEvents edvTimePhas As
> EpiDataView Private dsAvailability AS System.Data.DataSet Private
> dsTimePhase AS System.Data.DataSet Private nAvailabilityDataColumns AS
> Integer = 0 Private nTimePhaseDataColumns AS Integer = 0 Private Const
> Private bDeveloperLoggedIn AS Boolean = False Private bGridSizeSet AS
> Boolean = False Private Const nGridID_ComponentAvailability AS Integer
> = 1 Private Const nGridID_TimePhase AS Integer = 2 Private bFormLoaded
> AS Boolean = False Private baseToolbarsManager As
> Private sCurrentPartNum AS String = String.Empty Private
> dteShortageDate AS Date Private nAvailableQty AS Decimal = 0 Private
> bCancelRetrieve AS Boolean = False Private thrdSpawnNewThread AS
> Thread 'Private dynQryAD As DynamicQueryAdapter = New
> Variable Intialization' lines ** '// Begin Wizard Added Variable
> Intialization
> '// End Wizard Added Variable Intialization '// Begin Custom Method
> Calls If Thread.CurrentThread.Name = Nothing Then
> End If
> dsAvailability = New System.Data.DataSet("Results") dsTimePhase = New
> System.Data.DataSet("Results") timephasAdapter = New
> End If
> dim obj as Object =
> End Sub
> Case "ClearTool"
> ClearData(False)
> End Select
> End Sub
> Object Disposal' lines ** '// Begin Wizard Added Object Disposal
> 'dynQryAD.Dispose()
> End Sub
> EventArgs) Handles UD01Form.Load '// '// Add Event Handler Code '//
> Dim userID As String = UD01Form.Session.UserID bFormLoaded = False
> bDeveloperLoggedIn = False Select userID Case "dgodfrey"
> Case Else
> End Select
> grpFilters.Show()
> btnShowSize.Show()
> Else
> btnShowSize.Hide()
> End If
> 7a6"),
> 74b"),
> bFormLoaded = True
> otrans.pushstatustext("Ready!", False) End Sub
> / Private Sub ClearData(ByVal bGridOnly AS Boolean) IF(bGridOnly =
> False) Then txtBOMPartNum.Text = String.Empty txtPartDescription.Text
> = String.Empty txtBOMRevisionNum.text = String.Empty
> txtProductionQty.Text = String.Empty End If
> End Sub
> msg = msg & "Form Size:" & chr(13) & chr(10) msg = msg & "Bottom = " &
> ugdBOMGrid.FindForm().Height & chr(13) & chr(10) msg = msg &
> "ugdBOMGrid Size:" & chr(13) & chr(10) msg = msg & "Bottom = " &
> chr(13) & chr(10)
> msg = msg & "ugdTimePhase Size:" & chr(13) & chr(10) msg = msg &
> chr(13) & chr(10) MyMessageBox(msg, bDeveloperLoggedIn,
> End Sub
> Dim nWidth AS Integer = ugdBOMGrid.FindForm().Width Dim nHeight AS
> Integer = ugdBOMGrid.FindForm().Height DIM nCriteriaAreaPlusFooting AS
> Integer = 250 Dim nSpaceBtwnGrids AS Integer = 5
> nSpaceBtwnGrids ugdTimePhase.Width = ugdBOMGrid.Width
> nSpaceBtwnGrids ugdBOMGrid.Anchor = AnchorStyles.Bottom Or
> AnchorStyles.Left Or AnchorStyles.Top bGridSizeSet = True
> 'ShowSize()
> End Sub
> AS
> Integer)
> IF(GridIdentifier = nGridID_ComponentAvailability) Then For each
> column in Collection Select column.Header.Caption Case "Rev", "Part
> Case "Lvl"
> column.Width = 30
> column.CellAppearance.TextHAlign = HAlign.Right Case "MtlSeq", "Lead"
> column.Width = 50
> column.CellAppearance.TextHAlign = HAlign.Right Case "Material Part"
> column.Width = 150
> column.Width = 250
> Case "Type"
> column.Width = 50
> Case "RequiredQty"
> column.Width = 75
> column.CellAppearance.TextHAlign = HAlign.Right Case "ClassID"
> column.Width = 50
> column.Width = 125
> column.CellAppearance.TextHAlign = HAlign.Right Case Else
> End Select
> Next Column
> Case "Due"
> 'column.Ordinal = 0
> Case "Receipts"
> 'column.Ordinal = 1
> Case "Job"
> 'column.Ordinal = 2
> Case "Order"
> 'column.Ordinal = 3
> Case "RequiredQty"
> 'column.Ordinal = 4
> Case "PO"
> 'column.Ordinal = 5
> Case "Lead"
> 'column.Ordinal = 6
> Case "Balance"
> 'column.Ordinal = 7
> Case "Exception"
> 'column.Ordinal = 8
> Case "Order By"
> 'column.Ordinal = 9
> Case "Source"
> Case "JobStatus"
> 'nOrdinal = 11
> Case Else
> End Select
> Next Column
> End IF
> AS
> Integer)
> DataRow)
> Next i
> DataRow)
> End If
> otrans.pushstatustext("Retrieving Data ...", False) 'Dim sStatusString
> IF(GridIdentifier = nGridID_ComponentAvailability) Then Dim
> sStatusString AS String = String.EMpty Dim nColumns AS Integer = 0 Dim
> Dim sBaqID AS String = sAvailabilityBAQID sBaqID = sAvailabilityBAQID
> Case "CHARACTER"
> Case "INTEGER"
> Case "DECIMAL"
> Case "LOGICAL"
> Case "DATE"
> Case Else
> End Select
> Next
> dynQryAD.Dispose()
> End If
> GridIdentifier)
> Private Function ShowDebugInformation() AS String Dim sRet AS String
> '& Chr(13) & Chr(10) sRet = "Debug Data:" & Chr(13) & Chr(10) sRet =
> Chr(10)
> Chr(10)
> Chr(13) & Chr(10) sRet = sRet & "- ProductCode = " &
> Return sRet
> AS String Dim sRet AS String = String.Empty sRet = "INSIDE
> sRet = String.Empty
> For each Table as DataTable in myDataSet.Tables sRet = sRet & "Table:
> " & Table.TableName & chr(13) & chr(10) For Each DR AS DataRow in
> Table.Rows For Each DC as DataColumn in Table.Columns IF(DC.ColumnName
> = "RowIdent") Then Exit For End If sRet = sRet & DC.ColumnName & ":" &
> Next'For Each DC as DataColumn in Table.Columns sRet = sRet & chr(13)
> & chr(10) Next'For Each DR AS DataRow in Table.Rows Next'For each
> Table
> Return sRet
> String
> DataTable) AS String Dim sRet AS String = String.Empty
> sRet = String.Empty
> For Each DC as DataColumn in myDataTable.Columns sRet = sRet &
> & chr(10)
> Return sRet
> AS String
> ''' <summary>
> specified table.
> ''' </summary>
> ''' </param>
> ''' </param>
> or not.
> ''' </param>
> ''' <returns>
> ''' </returns>
> Private Function GetTopRows(ByVal table As DataTable, _ ByVal rowCount
> As Integer, _ ByVal useDefaultView As Boolean) As DataTable 'You can't
> rowCount = Math.Min(rowCount, table.DefaultView.Count) Else rowCount =
> Math.Min(rowCount, table.Rows.Count) End If 'Copy the table schema.
> Dim topTable As DataTable = table.Clone() 'Copy the specified number
> of rows.
> For rowIndex As Integer = 0 To rowCount - 1 Step 1 If useDefaultView
> Then 'Take the top rows from the DeafultView.
> Else
> End If
> Next rowIndex
> Return topTable
> End Function
> Dim sInputString AS String = TextString & Chr(13) & Chr(10) Dim sPath
> File.WriteAllText(sPath, sInputString) bResults = True Else ' This
> text is always added, making the file longer over time ' if it is not
> deleted.
> File.AppendAllText(sPath, sInputString) bResults = True End If return
> bResults End Function 'WriteToLogFile(ByVal TextString AS String) as
> Boolean
> Optional ByVal Title As String = Nothing) As MsgBoxResult Dim results
> As MsgBoxResult If(FYI = True) Then If Not String.IsNullOrEmpty(Title)
> Then results = MsgBox(Msg, Button, Title) Else results = MsgBox(Msg,
> Button) End If End If return results End Function 'MyMessageBox( ByVal
> valueToSearch As Object) As Integer Dim retVal As Integer = 0 Dim
> myArray As Array = DirectCast(Values, Array) If Array.IndexOf(myArray,
> valueToSearch) <> -1 Then retVal = Array.IndexOf(myArray,
> valueToSearch) Else retVal = -1 End If Return retVal End Function
> Object) As Integer
> Private Sub releaseObject(ByVal obj As Object) Try
> obj = Nothing
> obj = Nothing
> Finally
> GC.Collect()
> End Try
> As
> System.EventArgs) Handles btnCancelRetrieve.Click '// ** Place Event
> Handling Code Here ** IF(btnRetrieve.Enabled = False) Then
> bCancelRetrieve = True 'thrdSpawnNewThread.Abort
> 'ClearData(True)
> End If
> End Sub
> System.EventArgs) Handles ugdBOMGrid.Resize '// ** Place Event
> ValidateGridSize()
> End Sub
> System.EventArgs) Handles btnRetrieve.Click btnRetrieve.Enabled =
> False thrdSpawnNewThread = new Thread(AddressOf
> RetrieveAvailabilityData) thrdSpawnNewThread.Start
> ValidateGridSize()
> End If
> End Sub
> Decimal) AS Boolean
> Quantity = drRow.Item("BalanceQty") IF(Quantity <= 0) then blTimePhas
> = True
> IF(drRow.Item("DueDate").ToString() <> "") then sDate =
> drRow.Item("DueDate").Date End If Exit For Else blTimePhas = False End
> If
> Next
> End If
> Return blTimePhas
> End Function
> Part")),
> quiredQty")),
> terial
> rtDescription"))
> otrans.pushstatustext("Ready!", False) End IF End Sub
> Private Sub RetrieveAvailabilityData() '// ** Place Event Handling
> Code Here ** Dim dynQryAD As DynamicQueryAdapter = New
> DynamicQueryAdapter(UD01Form) Dim pcTable As String = "PartRev"
> Dim pcToValue as String = txtBOMPartNum.Text Dim pcToTable As String =
> String.Empty Dim pcToField As String = String.Empty Dim
> pcRightParentheses as String = String.Empty Dim pcLeftParentheses as
> String = String.Empty Dim pcAndOr as String = String.Empty Dim pbNeg
> as Boolean = False Try WriteToLogFile("Retrieving Availability Data
> ...") otrans.pushstatustext("Retrieving Availability Data ...", True)
> dynQryAD.Update pcField = "RevisionNum"
> pcToValue = txtBOMRevisionNum.Text.ToString() pcAndOr = "AND"
> dynQryAD.Update
> datasets)") '//copy all data from QueryDesignData tables to
> DynamicQueryData tables (only 'for tables that exist in both datasets
> For each Table as DataTable in dynQryAD.DynamicQueryData.Tables If
> Table.Rows.Count = 0 Then For Each sourceRow as DataRow in
> Next
> End If
> records.") otrans.pushstatustext("Processing " &
> records.",
> True)
> ClearData(True)
> Exit For
> End If
> AddToGrid = True
> txtProductionQty.Value nAvailableQty = ORow.Item("PartPlant.Number01")
> - ORow.Item("RequiredQty") dteShortageDate = Today() IF(nAvailableQty
> > 0) then bNegAvail =
> ORow.Item("RequiredQty"), dteShortageDate, nAvailableQty) Else
> bNegAvail = True End If
> ClearData(True)
> Exit For
> End If
> IF(chkExceptionsOnly.Checked = True) Then AddToGrid = bNegAvail End If
> IF(chkExcludeConsignments.Checked) Then Select
> ORow.Item("Part.ClassID") Case "CARR"
> AddToGrid = False
> Case "CTTI"
> AddToGrid = False
> Case "CAVN"
> AddToGrid = False
> Case Else
> End Select
> End If
> ClearData(True)
> Exit For
> End If
> If(AddToGrid) then
> RecCnt = RecCnt + 1
> TransferDataRow(dsAvailability, 0, nAvailabilityDataColumns, ORow) End
> If Next'For Each ORow as DataRow in
> Else
> True) WriteToLogFile("Processed " & RecCnt & " Component records.")
> IF(RecCnt > 0) Then
> ugdBOMGrid.Text =
> Else
> End If
> End If
> MsgBoxStyle.OKOnly, "Availability Report") finally
> dynQryAD.Dispose()
> End Try
> As
> System.EventArgs) Handles btnPartRevSearch.Click '// ** Place Event
> Handling Code Here ** Dim recordSelected As Boolean Dim sPart AS
> String = txtBOMPartNum.Text Dim wClause AS String = "PartNum >= '" +
> sPart + "'"
> End If
> End If
> End Sub
> System.EventArgs) Handles btnShowSize.Click '// ** Place Event
> ShowSize()
> End Sub
> Args As System.EventArgs) Handles ugdBOMGrid.AfterRowActivate '// **
> End Sub
> End If
> End Sub
> System.EventArgs) Handles txtBOMPartNum.Leave '// ** Place Event
> Handling Code Here ** IF(txtBOMPartNum.Text <> sCurrentPartNum) Then
> End If
> End Sub
> recSelected, False, swhereClause, True) If recSelected Then sPartRev =
> Else
> Number.", True, MsgBoxStyle.OKOnly, "Invalid Part Number") End If
> Return sPartRev End Function
> End Module
> > the
> thread.
> > owned by the Form?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Dan
I am having a problem. I need to update the grids with the data that was processed on that extra thread. The purpose was that because the data processing potentially covers 5 minutes of time, which during that whole time Vantage would be useless, and the users need to be able to continue with other things IN Vantage during that time.
With knowing the purpose of the threading, is there any other way to accomplish this?
Is it possible to kick-off a timer to monitor a variable (Boolean) change that would update the UI. I then could set the timer when I start the thread and then set a boolean change variable inside the data processing function when it is complete. That would then kick-off the timer function to update the UI.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dan Godfrey
Sent: Wednesday, August 15, 2012 8:56 AM
Subject: RE: [Vantage] Vantage 8.03.409C: System.Threading and BO
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Dan
> Imports System
> Imports System.Data
> IMPORTS System.IO
> Module Script
> Level Variables **
> Intialization
> End If
> End If
> dim obj as Object =
> End Sub
> Case "ClearTool"
> ClearData(False)
> End Select
> End Sub
> 'dynQryAD.Dispose()
> End Sub
> Case Else
> End Select
> grpFilters.Show()
> btnShowSize.Show()
> Else
> btnShowSize.Hide()
> End If
> 7a6"),
> 74b"),
> bFormLoaded = True
> End Sub
> chr(13) & chr(10)
> End Sub
> 'ShowSize()
> End Sub
> AS
> Integer)
> Case "Lvl"
> column.Width = 30
> column.Width = 50
> column.Width = 150
> column.Width = 250
> Case "Type"
> column.Width = 50
> Case "RequiredQty"
> column.Width = 75
> column.Width = 50
> column.Width = 125
> End Select
> Next Column
> Case "Due"
> 'column.Ordinal = 0
> Case "Receipts"
> 'column.Ordinal = 1
> Case "Job"
> 'column.Ordinal = 2
> Case "Order"
> 'column.Ordinal = 3
> Case "RequiredQty"
> 'column.Ordinal = 4
> Case "PO"
> 'column.Ordinal = 5
> Case "Lead"
> 'column.Ordinal = 6
> Case "Balance"
> 'column.Ordinal = 7
> Case "Exception"
> 'column.Ordinal = 8
> Case "Order By"
> 'column.Ordinal = 9
> Case "Source"
> Case "JobStatus"
> 'nOrdinal = 11
> Case Else
> End Select
> Next Column
> End IF
> AS
> Integer)
> DataRow)
> Next i
> DataRow)
> End If
> Case "CHARACTER"
> Case "INTEGER"
> Case "DECIMAL"
> Case "LOGICAL"
> Case "DATE"
> Case Else
> End Select
> Next
> dynQryAD.Dispose()
> End If
> GridIdentifier)
> Chr(10)
> Chr(10)
> Return sRet
> sRet = String.Empty
> Table
> Return sRet
> String
> sRet = String.Empty
> & chr(10)
> Return sRet
> AS String
> ''' <summary>
> specified table.
> ''' </summary>
> ''' </param>
> ''' </param>
> or not.
> ''' </param>
> ''' <returns>
> ''' </returns>
> of rows.
> Else
> End If
> Next rowIndex
> Return topTable
> End Function
> deleted.
> Boolean
> Object) As Integer
> obj = Nothing
> obj = Nothing
> Finally
> GC.Collect()
> End Try
> As
> 'ClearData(True)
> End If
> End Sub
> ValidateGridSize()
> End Sub
> ValidateGridSize()
> End If
> End Sub
> Decimal) AS Boolean
> = True
> If
> Next
> End If
> Return blTimePhas
> End Function
> Part")),
> quiredQty")),
> terial
> rtDescription"))
> dynQryAD.Update
> Next
> End If
> records.",
> True)
> ClearData(True)
> Exit For
> End If
> AddToGrid = True
> > 0) then bNegAvail =
> ClearData(True)
> Exit For
> End If
> AddToGrid = False
> Case "CTTI"
> AddToGrid = False
> Case "CAVN"
> AddToGrid = False
> Case Else
> End Select
> End If
> ClearData(True)
> Exit For
> End If
> If(AddToGrid) then
> RecCnt = RecCnt + 1
> Else
> IF(RecCnt > 0) Then
> ugdBOMGrid.Text =
> Else
> End If
> End If
> dynQryAD.Dispose()
> End Try
> As
> sPart + "'"
> End If
> End If
> End Sub
> ShowSize()
> End Sub
> End Sub
> End If
> End Sub
> End If
> End Sub
> Else
> End Module
> > the
> thread.
> > owned by the Form?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Dan
// CD 7/11/2012
pbProgress.Value=0;
pbProgress.Step=1;
*Jose C Gomez*
*Software Engineer*
E: jose@...
> accomplish this?
> to update the UI.
> Of Dan Godfrey
> Of Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> this.
> > Dan
> > Imports System
> > Imports System.Data
> > IMPORTS System.IO
> > Module Script
> > Level Variables **
> > Intialization
> > End If
> > End If
> > dim obj as Object =
> > End Sub
> > Case "ClearTool"
> > ClearData(False)
> > End Select
> > End Sub
> > 'dynQryAD.Dispose()
> > End Sub
> > Case Else
> > End Select
> > grpFilters.Show()
> > btnShowSize.Show()
> > Else
> > btnShowSize.Hide()
> > End If
> > 7a6"),
> > 74b"),
> > bFormLoaded = True
> > End Sub
> > chr(13) & chr(10)
> > End Sub
> > 'ShowSize()
> > End Sub
> > AS
> > Integer)
> > Case "Lvl"
> > column.Width = 30
> > column.Width = 50
> > column.Width = 150
> > column.Width = 250
> > Case "Type"
> > column.Width = 50
> > Case "RequiredQty"
> > column.Width = 75
> > column.Width = 50
> > column.Width = 125
> > End Select
> > Next Column
> > Case "Due"
> > 'column.Ordinal = 0
> > Case "Receipts"
> > 'column.Ordinal = 1
> > Case "Job"
> > 'column.Ordinal = 2
> > Case "Order"
> > 'column.Ordinal = 3
> > Case "RequiredQty"
> > 'column.Ordinal = 4
> > Case "PO"
> > 'column.Ordinal = 5
> > Case "Lead"
> > 'column.Ordinal = 6
> > Case "Balance"
> > 'column.Ordinal = 7
> > Case "Exception"
> > 'column.Ordinal = 8
> > Case "Order By"
> > 'column.Ordinal = 9
> > Case "Source"
> > Case "JobStatus"
> > 'nOrdinal = 11
> > Case Else
> > End Select
> > Next Column
> > End IF
> > AS
> > Integer)
> > DataRow)
> > Next i
> > DataRow)
> > End If
> ColumnName:
> > Case "CHARACTER"
> > Case "INTEGER"
> > Case "DECIMAL"
> > Case "LOGICAL"
> > Case "DATE"
> > Case Else
> > End Select
> > Next
> > dynQryAD.Dispose()
> > End If
> > GridIdentifier)
> > Chr(10)
> > Chr(10)
> > Return sRet
> > sRet = String.Empty
> > Table
> > Return sRet
> > String
> > sRet = String.Empty
> > & chr(10)
> > Return sRet
> > AS String
> > ''' <summary>
> > specified table.
> > ''' </summary>
> > ''' </param>
> > ''' </param>
> > or not.
> > ''' </param>
> > ''' <returns>
> > ''' </returns>
> > of rows.
> > Else
> > End If
> > Next rowIndex
> > Return topTable
> > End Function
> > deleted.
> > Boolean
> > Object) As Integer
> > obj = Nothing
> > obj = Nothing
> > Finally
> > GC.Collect()
> > End Try
> > As
> > 'ClearData(True)
> > End If
> > End Sub
> > ValidateGridSize()
> > End Sub
> > ValidateGridSize()
> > End If
> > End Sub
> > Decimal) AS Boolean
> > = True
> > If
> > Next
> > End If
> > Return blTimePhas
> > End Function
> > Part")),
> > quiredQty")),
> > terial
> > rtDescription"))
> > dynQryAD.Update
> > Next
> > End If
> > records.",
> > True)
> > ClearData(True)
> > Exit For
> > End If
> > AddToGrid = True
> > > 0) then bNegAvail =
> > ClearData(True)
> > Exit For
> > End If
> > AddToGrid = False
> > Case "CTTI"
> > AddToGrid = False
> > Case "CAVN"
> > AddToGrid = False
> > Case Else
> > End Select
> > End If
> > ClearData(True)
> > Exit For
> > End If
> > If(AddToGrid) then
> > RecCnt = RecCnt + 1
> > Else
> > IF(RecCnt > 0) Then
> > ugdBOMGrid.Text =
> > Else
> > End If
> > End If
> > dynQryAD.Dispose()
> > End Try
> > As
> > sPart + "'"
> > End If
> > End If
> > End Sub
> > ShowSize()
> > End Sub
> > End Sub
> > End If
> > End Sub
> > End If
> > End Sub
> > Else
> > End Module
> > > the
> > thread.
> > > owned by the Form?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Dan
> access.
How would that look in VB?
// CD 7/11/2012
pbProgress.Value=0;
pbProgress.Step=1;
*Jose C Gomez*
*Software Engineer*
E: jose@...
> accomplish this?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > on
> this.
> > Dan
> > Imports System
> > Imports System.Data
> > IMPORTS System.IO
> > Imports Infragistics.Win.UltraWinGrid Imports System.Reflection
> > Module Script
> > Added Module Level Variables' Comments! ** '// Begin Wizard Added
> > AS Integer = 0 Private nTimePhaseDataColumns AS Integer = 0 Private
> > AS Boolean = False Private Const nGridID_ComponentAvailability AS
> > Integer = 1 Private Const nGridID_TimePhase AS Integer = 2 Private
> > bFormLoaded AS Boolean = False Private baseToolbarsManager As
> > Added Variable Intialization' lines ** '// Begin Wizard Added
> > End If
> > New
> > End If
> > dim obj as Object =
> > ba rsManager", BindingFlags.Instance Or BindingFlags.GetField Or
> > End Sub
> > Case "ClearTool"
> > ClearData(False)
> > End Select
> > End Sub
> > Added Object Disposal' lines ** '// Begin Wizard Added Object
> > Disposal
> > '// End Wizard Added Object Disposal '// Begin Custom Code Disposal
> > 'dynQryAD.Dispose()
> > End Sub
> > Case Else
> > End Select
> > grpFilters.Show()
> > btnShowSize.Show()
> > Else
> > btnShowSize.Hide()
> > End If
> > fb
> > 7a6"),
> > e2
> > 74b"),
> > bFormLoaded = True
> > ** / Private Sub ClearData(ByVal bGridOnly AS Boolean) IF(bGridOnly
> > txtPartDescription.Text = String.Empty txtBOMRevisionNum.text =
> > String.Empty txtProductionQty.Text = String.Empty End If
> > End Sub
> > chr(13) & chr(10)
> > End Sub
> > AS Integer = 250 Dim nSpaceBtwnGrids AS Integer = 5
> > 'ShowSize()
> > End Sub
> > GridIdentifier AS
> > Integer)
> > Case "Lvl"
> > column.Width = 30
> > column.Width = 50
> > column.Width = 150
> > column.Width = 250
> > Case "Type"
> > column.Width = 50
> > Case "RequiredQty"
> > column.Width = 75
> > column.Width = 50
> > column.Width = 125
> > End Select
> > Next Column
> > Case "Due"
> > 'column.Ordinal = 0
> > Case "Receipts"
> > 'column.Ordinal = 1
> > Case "Job"
> > 'column.Ordinal = 2
> > Case "Order"
> > 'column.Ordinal = 3
> > Case "RequiredQty"
> > 'column.Ordinal = 4
> > Case "PO"
> > 'column.Ordinal = 5
> > Case "Lead"
> > 'column.Ordinal = 6
> > Case "Balance"
> > 'column.Ordinal = 7
> > Case "Exception"
> > 'column.Ordinal = 8
> > Case "Order By"
> > 'column.Ordinal = 9
> > Case "Source"
> > Case "JobStatus"
> > 'nOrdinal = 11
> > Case Else
> > End Select
> > Next Column
> > End IF
> > GridIdentifier AS
> > Integer)
> > DataRow)
> > Next i
> > DataRow)
> > Integer)
> > End If
> > DynamicQueryAdapter(UD01Form) Dim sBaqID AS String =
> ColumnName:
> > Case "CHARACTER"
> > Case "INTEGER"
> > Case "DECIMAL"
> > Case "LOGICAL"
> > Case "DATE"
> > Case Else
> > End Select
> > Next
> > dynQryAD.Dispose()
> > End If
> > GridIdentifier)
> > Chr(10)
> > Chr(13) &
> > Chr(10)
> > Return sRet
> > sRet = String.Empty
> > IF(DC.ColumnName = "RowIdent") Then Exit For End If sRet = sRet &
> > chr(13) & chr(10) Next'For Each DR AS DataRow in Table.Rows Next'For
> > each Table
> > Return sRet
> > String
> > sRet = String.Empty
> > chr(13) & chr(10)
> > Return sRet
> > ''' <summary>
> > specified table.
> > ''' </summary>
> > ''' </param>
> > ''' </param>
> > DefaultView or not.
> > ''' </param>
> > ''' <returns>
> > ''' </returns>
> > rowCount As Integer, _ ByVal useDefaultView As Boolean) As DataTable
> > = Math.Min(rowCount, table.Rows.Count) End If 'Copy the table schema.
> > of rows.
> > Else
> > End If
> > Next rowIndex
> > Return topTable
> > End Function
> > Boolean Dim bResults AS Boolean = False
> > not deleted.
> > return bResults End Function 'WriteToLogFile(ByVal TextString AS
> > String) as Boolean
> > results As MsgBoxResult If(FYI = True) Then If Not
> > String.IsNullOrEmpty(Title) Then results = MsgBox(Msg, Button,
> > Object) As Integer
> > obj = Nothing
> > obj = Nothing
> > Finally
> > GC.Collect()
> > End Try
> > Args As
> > 'ClearData(True)
> > End If
> > End Sub
> > ValidateGridSize()
> > End Sub
> > ValidateGridSize()
> > End If
> > End Sub
> > AS
> > Decimal) AS Boolean
> > blTimePhas = True
> > End If
> > Next
> > End If
> > Return blTimePhas
> > End Function
> > ti
> > Part")),
> > Re
> > quiredQty")),
> > Ma
> > terial
> > Pa
> > rtDescription"))
> > = String.Empty Dim pcToField As String = String.Empty Dim
> > True)
> > dynQryAD.Update
> > datasets
> > Next
> > End If
> > records.",
> > True)
> > ClearData(True)
> > Exit For
> > End If
> > AddToGrid = True
> > IF(nAvailableQty
> > > 0) then bNegAvail =
> > ClearData(True)
> > Exit For
> > End If
> > If
> > AddToGrid = False
> > Case "CTTI"
> > AddToGrid = False
> > Case "CAVN"
> > AddToGrid = False
> > Case Else
> > End Select
> > End If
> > ClearData(True)
> > Exit For
> > End If
> > If(AddToGrid) then
> > RecCnt = RecCnt + 1
> > End If Next'For Each ORow as DataRow in
> > Else
> > IF(RecCnt > 0) Then
> > ugdBOMGrid.Text =
> > Else
> > End If
> > End If
> > dynQryAD.Dispose()
> > End Try
> > Args As
> > sPart + "'"
> > End If
> > End If
> > End Sub
> > ShowSize()
> > End Sub
> > End Sub
> > End If
> > End Sub
> > As
> > sCurrentPartNum = txtBOMPartNum.Text End If
> > End Sub
> > string
> > Dim sPartRev As String = String.Empty Dim recSelected As Boolean =
> > False Dim swhereClause AS String = "PartNum = '" & sPartNum & "'"
> > "PartRevSearchAdapter", recSelected, False, swhereClause, True) If
> > Else
> > End Module
> > > delegate for the
> > thread.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Dan
> > > enable
> access.
One thing I can't figure out is why will it crash on the DynamicQueryAdapter.Execute but not the GetByID or BOConnect, or the Update.
Sent: Wednesday, August 15, 2012 12:35 PM
// CD 7/11/2012
pbProgress.Value=0;
pbProgress.Step=1;
*Jose C Gomez*
*Software Engineer*
E: jose@...
> accomplish this?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > on
> this.
> > Dan
> > Imports System
> > Imports System.Data
> > IMPORTS System.IO
> > Module Script
> > End If
> > New
> > End If
> > dim obj as Object =
> > End Sub
> > Case "ClearTool"
> > ClearData(False)
> > End Select
> > End Sub
> > Disposal
> > 'dynQryAD.Dispose()
> > End Sub
> > Case Else
> > End Select
> > grpFilters.Show()
> > btnShowSize.Show()
> > Else
> > btnShowSize.Hide()
> > End If
> > fb
> > 7a6"),
> > e2
> > 74b"),
> > bFormLoaded = True
> > End Sub
> > chr(13) & chr(10)
> > End Sub
> > 'ShowSize()
> > End Sub
> > GridIdentifier AS
> > Integer)
> > Case "Lvl"
> > column.Width = 30
> > column.Width = 50
> > column.Width = 150
> > column.Width = 250
> > Case "Type"
> > column.Width = 50
> > Case "RequiredQty"
> > column.Width = 75
> > column.Width = 50
> > column.Width = 125
> > End Select
> > Next Column
> > Case "Due"
> > 'column.Ordinal = 0
> > Case "Receipts"
> > 'column.Ordinal = 1
> > Case "Job"
> > 'column.Ordinal = 2
> > Case "Order"
> > 'column.Ordinal = 3
> > Case "RequiredQty"
> > 'column.Ordinal = 4
> > Case "PO"
> > 'column.Ordinal = 5
> > Case "Lead"
> > 'column.Ordinal = 6
> > Case "Balance"
> > 'column.Ordinal = 7
> > Case "Exception"
> > 'column.Ordinal = 8
> > Case "Order By"
> > 'column.Ordinal = 9
> > Case "Source"
> > Case "JobStatus"
> > 'nOrdinal = 11
> > Case Else
> > End Select
> > Next Column
> > End IF
> > GridIdentifier AS
> > Integer)
> > DataRow)
> > Next i
> > DataRow)
> > Integer)
> > End If
> ColumnName:
> > Case "CHARACTER"
> > Case "INTEGER"
> > Case "DECIMAL"
> > Case "LOGICAL"
> > Case "DATE"
> > Case Else
> > End Select
> > Next
> > dynQryAD.Dispose()
> > End If
> > GridIdentifier)
> > Chr(10)
> > Chr(13) &
> > Chr(10)
> > Return sRet
> > sRet = String.Empty
> > each Table
> > Return sRet
> > String
> > sRet = String.Empty
> > chr(13) & chr(10)
> > Return sRet
> > ''' <summary>
> > specified table.
> > ''' </summary>
> > ''' </param>
> > ''' </param>
> > DefaultView or not.
> > ''' </param>
> > ''' <returns>
> > ''' </returns>
> > of rows.
> > Else
> > End If
> > Next rowIndex
> > Return topTable
> > End Function
> > not deleted.
> > String) as Boolean
> > Object) As Integer
> > obj = Nothing
> > obj = Nothing
> > Finally
> > GC.Collect()
> > End Try
> > Args As
> > 'ClearData(True)
> > End If
> > End Sub
> > ValidateGridSize()
> > End Sub
> > ValidateGridSize()
> > End If
> > End Sub
> > AS
> > Decimal) AS Boolean
> > blTimePhas = True
> > End If
> > Next
> > End If
> > Return blTimePhas
> > End Function
> > ti
> > Part")),
> > Re
> > quiredQty")),
> > Ma
> > terial
> > Pa
> > rtDescription"))
> > True)
> > dynQryAD.Update
> > datasets
> > Next
> > End If
> > records.",
> > True)
> > ClearData(True)
> > Exit For
> > End If
> > AddToGrid = True
> > IF(nAvailableQty
> > > 0) then bNegAvail =
> > ClearData(True)
> > Exit For
> > End If
> > If
> > AddToGrid = False
> > Case "CTTI"
> > AddToGrid = False
> > Case "CAVN"
> > AddToGrid = False
> > Case Else
> > End Select
> > End If
> > ClearData(True)
> > Exit For
> > End If
> > If(AddToGrid) then
> > RecCnt = RecCnt + 1
> > Else
> > IF(RecCnt > 0) Then
> > ugdBOMGrid.Text =
> > Else
> > End If
> > End If
> > dynQryAD.Dispose()
> > End Try
> > Args As
> > sPart + "'"
> > End If
> > End If
> > End Sub
> > ShowSize()
> > End Sub
> > End Sub
> > End If
> > End Sub
> > As
> > End Sub
> > string
> > Else
> > End Module
> > > delegate for the
> > thread.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Dan
> > > enable
> access.
