Vantage 8.03 BPM
Sure no problem. Also with your mapping to jobs, that is something
we are doing too. I am working on a way to push them during the
orderJobWizard, but as of now when a user checks the Released
checkbox on a job it copies all the VB fields from the OrderHed &
OrderDtl to the JobHead.
--- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
> Hi Michael,
> If the field mapping can't be done with BPM would you be willing to
> share your script?
> Linda Lowney
> Pride Signs Ltd
> 280 Holiday Inn Drive
> Cambridge, ON N3C 1Z4
> Ph: 519-220-0505 x258
> Fx: 519-220-0606
Hello Group,
We have customized quote entry to use some of the extra fields such as
Character01. What I need to do is to move these fields to Order Entry
when the order is created from the quote.
It is my understanding that this can be accomplished by BPM, but I
can't figure it out. Would someone point me in the right direction,
please.
Linda
I don't know how BPM would do this but it will work if you go to the
report data definition for the report.
Find the report you want to modify in the report data definition. When
the tables show up, click on one of the tables (you may have to
highlight one, highlight another one, then go back to the original, at
least in 8.0 you have to do this). Then click on the excluded fields
tab. In here move all fields you need over the the left hand side.
At this point you can create a new style for the report...that way you
can leave the original intact. Make sure you make the new style the
default.
Print preview the report.
Open up Crystal and modify in here by adding the fields needed. You
have to set the database location and verify the report before adding
the fields.
If you need more help you can call me if you want.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of lindalowney
Sent: Wednesday, January 30, 2008 7:43 AM
Subject: [Vantage] Vantage 8.03 BPM
Hello Group,
please.
Linda
Do you push or pull quotes? Or do you do both?
the
When
original, at
fields
you
the
> default.
You
adding
> the fields.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of lindalowney
> Hello Group,
such as
Entry
direction,
> please.
> Linda
Mike,
Can you add fields to a report through BPM whether you push or pull
quotes?
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Michael McWilliams
Sent: Wednesday, January 30, 2008 10:31 AM
Subject: [Vantage] Re: Vantage 8.03 BPM
the
When
original, at
fields
you
the
> default.
You
adding
> the fields.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of lindalowney
> Hello Group,
such as
Entry
direction,
> please.
> Linda
If it is for reporting only you do not need BPM just link the order
to the quote.
If you want to map the field you will have to use either BPM or the
script editor. Currently we map our fields through script, but I am
looking at doing it all through BPM once I learn to use it. It
looks like you can map the field PostProcess from the
GetOrderFromQuote Method, I just need to find the time to work with
it.
> Mike,
> quotes?
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> the
definition.
> When
> original, at
> fields
side.
way
> you
> the
> > default.
> You
> adding
> > the fields.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> Behalf
> > Of lindalowney
> > Hello Group,
> such as
> Entry
I
> direction,
> > please.
> > Linda
Which Table to you want to map either Quotehead /Quotedtl to OrderHead /OrderDtl.
Please let me know.
Muhammad Sarfaraz
IT Project Manager
(Vista 8.03.305i - Progress )
Advance Grinding Service, Inc.
Tel: (708) 442 7100 x 313
----- Original Message ----
Sent: Wednesday, January 30, 2008 7:43:23 AM
Hello Group,
please.
Linda
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Ah, something to look forward to!
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Sent: Wednesday, January 30, 2008 10:55 AM
to the quote.
it.
> Mike,
> quotes?
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> the
definition.
> When
> original, at
> fields
side.
way
> you
> the
> > default.
> You
> adding
> > the fields.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
<mailto:vantage%
> Behalf
> > Of lindalowney
> > Hello Group,
> such as
> Entry
I
> direction,
> > please.
> > Linda
Please let me know.
Muhammad Sarfaraz
IT Project Manager
Hello Group,
please.
Linda
Hi Group,
It is not just for reports. I want to copy the quote header and detail
fields to the order header and details and some fields also to the job
table. This way I can display the information on the screen in order
entry and job entry and the data can be updated as things change. Oh,
and we sometimes push and sometimes pull so I will have to make it work
both ways.
Linda Lowney
Pride Signs Ltd
Fx: 519-220-0606
to the quote.
it.
> Mike,
> quotes?
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> the
definition.
> When
> original, at
> fields
side.
way
> you
> the
> > default.
> You
> adding
> > the fields.
> > M. Manasa Reddy
> > manasa@
> > P: 630-806-2000
> > F: 630-806-2001
> Behalf
> > Of lindalowney
> > Hello Group,
> such as
> Entry
I
> direction,
> > please.
> > Linda
Hi Michael,
share your script?
Linda Lowney
Pride Signs Ltd
Fx: 519-220-0606
