Vantage 8.03 - login
Well, nothing was helping and everything seemed okay. So I reinstalled
Vantage and the client and I was able to log into Vantage 8.03.
Thanks everyone for your help.
I just wish I was more help to you all.
Nancy
Sent: Friday, February 02, 2007 9:15 AM
Subject: RE: [Vantage] Re: Vantage 8.03 - login
Does the path in your Vantage test shortcut read the following
C:\epicor\mfgsys803\client\MfgSys.exe /CONFIG=test.mfgsys
What error do you get?
Gary
Behalf Of Dunn, Nancy
Sent: 02 February 2007 13:41
Yes
<mailto:garyp%40dotnetit.co.uk> <mailto:garyp%40dotnetit.co.uk> ]
Sent: Friday, February 02, 2007 4:28 AM
Nancy
Can you log into the admin tools with your username and password?
Gary
Sent: 01 February 2007 21:53
I have converted my 6.1 database to 8.0 and it works fine. I then
converted to 8.3 and I can't login to the 8.3 using the same login that
works for the other 2.
Nancy
<mailto:bluewine%40san.rr.com> <mailto:bluewine%40san.rr.com>
<mailto:bluewine%40san.rr.com> <mailto:bluewine%40san.rr.com> ]
Sent: Thursday, February 01, 2007 4:41 PM
Subject: [Vantage] Re: Vantage 8.03 - login
If it's a new installation, there is no name/password yet. Just press OK
and manager/manager will be created.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"Dunn, Nancy" <ndunn@...> wrote:
> I am having problems logging into my test 8.03 database.
> I have ran all the conversions. The Admin Tools logs in fine.
There
> are not schema changes to make.
> The database is running and the 2 app servers are running, but when
I
> try to login to Vantage it says a valid user id is requiered - or
> something like that. I am using the same one I use to log into the
Admin
> Tools.
> I have even tried manager - manager.
> Does anyone have any suggestions before I uninstall everything and
start
> over?
> Thanks
> Nancy
I have ran all the conversions. The Admin Tools logs in fine. There
The database is running and the 2 app servers are running, but when I
something like that. I am using the same one I use to log into the Admin
Tools.
Does anyone have any suggestions before I uninstall everything and start
over?
Nancy
OK and manager/manager will be created.
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
Nancy
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
On one of our installs, the Test Database Icon was actually pointing to
the training database.
Check the properties of the Icon and make sure it is
/CONFIG=test.mfgsys
Dale E. Schuerman
Of Dunn, Nancy
Sent: Thursday, February 01, 2007 3:53 PM
Nancy
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
I notice you said 2 app servers? If memory serves, there should be
three.
Also in my experience I've found if you can't log on to the client, its
because you have missed something that needs to be done in the admin
tools first.
Hope that helps.
Brian
There
I
Admin Tools.
Your right, the 3 app servers.
I checked everything in the admin tools. Selected the serial# for the
companies.
In version 8.0 there were a couple of conversion required from the admin
tools.
Is there some for version 8.3?
Nancy
Sent: Thursday, February 01, 2007 5:02 PM
Subject: [Vantage] RE: Vantage 8.03 - login
three.
tools first.
Hope that helps.
Brian
There
I
Admin Tools.
You need to do a schema change from 8.00 to 8.03
the
> companies.
admin
> tools.
> Nancy
> From: Brian Boyes [mailto:Brian.Boyes@...]
> three.
its
> tools first.
> Hope that helps.
> Brian
> There
when
> I
> Admin Tools.
Nancy
Gary
Of Dunn, Nancy
Nancy
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
How did you get your copy of your live data set into the Test803/DB
folder?
Of Dunn, Nancy
Sent: Thursday, February 01, 2007 4:53 PM
Nancy
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
Yes
Nancy
Gary
Nancy
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
Nancy,
I have seen this problem testing if the server has to much memory set
up in the blocks for db buffer.
Steve Erboe
> Yes
> From: Gary Parfrey [mailto:garyp@...]
> Nancy
> Gary
that
> Nancy
> From: Chris Robisch [mailto:bluewine@...
press OK
> There
when
> I
> Admin
> > Tools.
> start
> > over?
> > Thanks
> > Nancy
Gary
Of Dunn, Nancy
Yes
Nancy
Gary
Nancy
There
I
Admin
> Tools.
start
> over?
> Thanks
> Nancy
