Vantage 8.03 not closing
I experienced this problem now and then
right click on the system monitor and pick exit
then close go and close vantage or vista
it does work
Gary Wojtowicz
AJR Industries, Inc.
Has anyone experienced the Vantage client refusing to close? It's almost like the client connection to the server is dropped but no error messages are displayed. The weird part is the user can continue working with no problem but Vantage will not close, the user can not change plants nor can a different user log in to the client. The only way to close the Vantage client is to use Task Manager and End Task. It's starting to be occur more often for users and there is no common pattern to the issue, all the users are in different departments and using different modules.
Is there any pattern to the OS?
I’ve seen this occur when using custom Crystal Reports that use ODBC and CR parameters; the client will exhibit the same symptoms you describe after printing that custom report.
Vic Drecchio
Director of Information Technology
Swepco Tube
(704) 530-3092
vic.drecchio@...
One Clifton Blvd., Clifton, NJ 07011
Sent: Wednesday, September 21, 2011 10:11 AM
Subject: [Vantage] Vantage 8.03 not closing
I think someone posted on here and I have used it…You can exit out of System Monitor and then for some reason the file/exit works in Vantage too afterward.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Wednesday, September 21, 2011 9:16 AM
Subject: Re: [Vantage] Vantage 8.03 not closing
Vic Drecchio
Swepco Tube
(704) 530-3092
vic.drecchio@...<mailto:vic.drecchio%40swepcotube.com>
This works for me too.
Sometimes just opening the system monitor and then minimizing does it.
Both V8 and E9
> Vic Drecchio
> Swepco Tube
> (704) 530-3092
> From: timlester67
I will try the System Monitor trick next time it occurs.
Vic - All the machines have been WinXP SP3. At least those are the only ones to report the problem.
Thanks.
Tim
> Both V8 and E9
> > Vic Drecchio
> > Swepco Tube
> > (704) 530-3092
> > vic.drecchio@<mailto:vic.drecchio%40swepcotube.com>
> > From: timlester67
