Vantage 8.03 / Switch Recommendation
Ours are set to
normal 30000
priority 3000
duration 30000
Does this mean that ours should be faster or slower than your settings?
Sent: Wed, 8 September, 2010 1:57:27
Subject: [Vantage] Re: Vantage 8.03 / Switch Recommendation
Â
Check your system monitor setting and make sure they are set to:
Normal = 120000
Priority = 3000
Duration 60000
We found this cut by half the time to view reports
--- In vantage@yahoogroups.com, "Abe Klassen" <ak@...> wrote:
> Good afternoon all,
> I'm having some performance issues with Vantage 8.03. It takes over 30 seconds
>to load an A/R invoice etc. It seems to be an issue between the server and the
>workstation. I have a Netgear FS750T2 Smart Switch. Can someone recommend a good
>managed switch? I have 6 Vantage users and the server is also a file server.
> Thank you,
> Abe
Good afternoon all,
I'm having some performance issues with Vantage 8.03. It takes over 30 seconds to load an A/R invoice etc. It seems to be an issue between the server and the workstation. I have a Netgear FS750T2 Smart Switch. Can someone recommend a good managed switch? I have 6 Vantage users and the server is also a file server.
Thank you,
Abe
Normal = 120000
Priority = 3000
Duration 60000
> Good afternoon all,
> Thank you,
> Abe
