Vantage 8.03 - turning off PO Suggestions
Vantage 8.03.408
I will first assume you are running the Generate PO Suggestions on a schedule. If so, you can stop that scheduled run. As for parts that should/should not be generating suggestions you will need to manage this on the Part Plant screen in Part Maintenance. This is where you will check/uncheck the box to Generate Suggestions. The Requisition process will push only those items "Sent to Purchasing" onto the New PO Suggestion board.
Jeff
--- In vantage@yahoogroups.com, Mike Abell <mabell@...> wrote:
> Is there any way to stop Vantage from making PO suggestions from everything? We would like it to ONLY make PO suggestions for items that are requisitioned. Is there any simple way to accomplish this?
> Mike Abell
> Information Technology Manager
> Flexial - BOA Group - Cookeville, Tennessee
> Office: 931.432.1853 ext 302
> Mobile: 615.418.3055
> email: MAbell@...
Mike Abell
email: MAbell@...
