Amy,
What are the specs on your terminal servers?
Bob
Bob
--- In vantage@yahoogroups.com, "cpsadp" <cpsadp@...> wrote:
> Hi Gary,
> I'm not sure that I saw anyone directly address your question which
> had to do with using RDP to access the server. This means that all
> processing is done on between the main Vantage server and the
> terminal server. The only thing the local machine does is to
> receive the images sent by the terminal server. This reduces the
> bandwith needed to the desktop from approximately 125K to 12K.
> Additionally, the performance of screens is faster since processing
> happens on the server rather than on the desktop.
> To answer your question: yes. We are going live on Vantage 8.0
> using terminal servers to access the main VAntage server from the
> desktop. We avoided several issues by doing this: upgrading the
> desktops, installing and maintaining software on client stations,
> performance to the desktop.
> Login Local: 25 seconds
> Login TS: 7 seconds
> Part tracker Local: 37 seconds
> Part tracker TS: 12 seconds
> We had several issues in the initial setup: permissions,
> consistancy between terminal servers (we put in 5, one for every 20
> users), etc. Mainly due to error on our part as I'm not a Terminal
> Server guru.
> Hope that helps.
> Amy
