Vantage 8: Cannot Clock Out Employee
That worked wonderfully. Thank you so much.
--- On Fri, 4/3/09, Late, Travis <tlate@...> wrote:
Subject: RE: [Vantage] Vantage 8: Cannot Clock Out Employee
Date: Friday, April 3, 2009, 4:27 PM
He is having the exact same problem that we had. This will fix his
issue.
Travis
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Ari Footlik
Sent: Friday, April 03, 2009 3:24 PM
To: vantage@yahoogroups .com
Conversions 8920 and 8930 pertain to clocking employees out of MES. One
is for ending a labor-detail record, the other is for the date record.
--Ari
____________ _________ _________ __
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Late, Travis
Sent: Friday, April 03, 2009 3:08 PM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
I just had to do this last week for an employee in the shop. If you go
into the Admin Tools on the Server select Run Database Conversion then
select number 8920. You will need your company ID and the employee
number. Hope this helps.
Travis
Behalf
Of Troy Christensen
Sent: Friday, April 03, 2009 2:45 PM
Subject: [Vantage] Vantage 8: Cannot Clock Out Employee
Hello,
I am in a bit of a quandry and hope someone here may be able to help. I
have a third shift employee that was working on a couple of assemblies,
then went home for the night without clocking out of MES. Now he cannot
pounch out of his activity Clock.
When he is trying to End Activity he gets the following error: "Employee
is already active on this sequence."
As an administrator, shouldn't I have the ability to end activity of any
employee and clock them out?
Need help. Thanks
Troy Christensen
Spartan Graphics
Hello,
Â
I am in a bit of a quandry and hope someone here may be able to help. I have a third shift employee that was working on a couple of assemblies, then went home for the night without clocking out of MES. Now he cannot pounch out of his activity Clock.
Â
When he is trying to End Activity he gets the following error: "Employee is already active on this sequence."
Â
As an administrator, shouldn't I have the ability to end activity of any employee and clock them out?
Â
Need help. Thanks
Â
Troy Christensen
Spartan Graphics
Travis
Of Troy Christensen
Hello,
Need help. Thanks
Troy Christensen
Spartan Graphics
--Ari
Of Late, Travis
Travis
Behalf
Of Troy Christensen
Hello,
Need help. Thanks
Troy Christensen
Spartan Graphics
issue.
Travis
Of Ari Footlik
--Ari
Behalf
Of Late, Travis
Travis
Behalf
Of Troy Christensen
Hello,
Need help. Thanks
Troy Christensen
Spartan Graphics
