Vantage 8-Crystal Reports-syntaxto select the most recent PartT
Place the part information in your part group footer.
Create a running total or formula for the maximum(Parttran.Trandate) and
place it in the group t give you your last transaction.
The suppress or group filter on maximum(Parttran.Trandate) <
maximum(Partwhse.CountedDate)
Depends on whether you are formatting from a part (Part Group) or
warehouse basis (Warehouse group) as counts are completed on a warehouse
by warehouse basis.
The reason why your filter will not work, is that you need to show the
records post 01.01.2007 in order to show no transactions on the relevant
parts
Gary Parfrey
Dot Net IT Limited, Reg No 4412519
Of RSN
Sent: 28 August 2007 19:54
Subject: [Vantage] Vantage 8-Crystal Reports-syntaxto select the most
recent PartTran record
I'm creating a Crystal report to select those parts out of the PartTran
table that haven't had any activity since Jan 1, 2007 (or since the last
full physical count was posted-which was Jan 8, 2007).
I've selected the PartTran and PartBin tables to show qty on hand and
I've grouped by PartTran.Partnum and in my Record Selection claus, I've
tried both clauses below:
not ({PartTran.TranDate} in YearToDate) or {PartTran.TranDate} < CDate
(2007, 01, 01)
However, I'm still getting parts that have transactions as recent as
March 2007.
I can't figure out how to select the most recent PartTran.TranDate on a
part- any help would be appreciated.
Can any of the Crystal reports experts on the forum provide suggestions
as to what I'm doing wrong and how to correct my select clause so that I
select all parts from the parttran table that have no transactions since
Jan 8, 2007?
Thank you in advance.
RSN
__________________________________________________________
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
I'm creating a Crystal report to select those parts out of the PartTran table that haven't had any activity since Jan 1, 2007 (or since the last full physical count was posted-which was Jan 8, 2007).
I've selected the PartTran and PartBin tables to show qty on hand and I've grouped by PartTran.Partnum and in my Record Selection claus, I've tried both clauses below:
not ({PartTran.TranDate} in YearToDate) or {PartTran.TranDate} < CDate (2007, 01, 01)
However, I'm still getting parts that have transactions as recent as March 2007.
I can't figure out how to select the most recent PartTran.TranDate on a part- any help would be appreciated.
Can any of the Crystal reports experts on the forum provide suggestions as to what I'm doing wrong and how to correct my select clause so that I select all parts from the parttran table that have no transactions since Jan 8, 2007?
RSN
____________________________________________________________________________________
I've had problems with this in the past as well....there is a function
in crystal called onlastrecord(), but it doesn't quite work the way you
may think, but at least you can play with it and see if there is a way
to manipulate it around.
I am still looking for a better way to do it.
HTH,
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of RSN
Sent: Tuesday, August 28, 2007 1:54 PM
(2007, 01, 01)
March 2007.
Jan 8, 2007?
RSN
<http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC>
Forgot to mention that you would have to use it as a subreport....
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of RSN
(2007, 01, 01)
March 2007.
Jan 8, 2007?
RSN
I would do the following to get this information:
1. Change your part group to use PartBin.PartNumber
2. Create a maximum TranDate calculation per part within the part group
footer
3. Create a prompt for the cutoff date that you wish to use
4. Remove the existing record selection formulas
5. Add a group selection formula to MAX(TranDate) <= Cutoff Date.
That should give you the information that you are looking for. Let me know
if you have any questions.
Katharine Barry
Aspacia Systems Inc
866-566-9600
www.aspacia.com
This email, and any attachments thereto, is intended only for use by the
addressee(s) named herein and may contain legally privileged and/or
confidential information. If you are not the intended recipient of this
email, you are hereby notified that any dissemination, distribution or
copying of this email, and any attachments thereto, is strictly prohibited.
If you have received this email in error, please immediately notify me by
telephone and permanently delete the original and any copy of any email and
any printout thereof.
RSN
Sent: Tuesday, August 28, 2007 11:54 AM
Subject: [Vantage] Vantage 8-Crystal Reports-syntaxto select the most recent
PartTran record
both clauses below:
(2007, 01, 01)
2007.
2007?
RSN
That just proves I over complicate things!
I thank you for the info....helped with some of my reports!
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Katharine Barry
Sent: Tuesday, August 28, 2007 2:46 PM
Subject: RE: [Vantage] Vantage 8-Crystal Reports-syntaxto select the
most recent PartTran record
footer
know
Katharine Barry
Aspacia Systems Inc
866-566-9600
www.aspacia.com
prohibited.
by
and
Behalf Of
RSN
recent
PartTran record
I've
both clauses below:
(2007, 01, 01)
March
2007.
as
select
2007?
RSN
