Vantage 8 Ultra Combo Customization
I've added an UltraCombo (ucbMatlType) to my Part Maint. screen. Here's
where I've gotten with this so far...
Private Sub PartForm_Load(ByVal sender As Object, ByVal args As
EventArgs) Handles PartForm.Load
Dim tblMaterials As DataTable = New DataTable("Materials")
Dim MatlTypes As DataColumn = New DataColumn("MatlType")
MatlTypes.DataType = System.Type.GetType("System.String")
tblMaterials.Columns.Add(MatlTypes)
ucbMatlType.DataSource = tblMaterials
NewTableRow(tblMaterials, "MatlType", "")
NewTableRow(tblMaterials, "MatlType", "HR")
NewTableRow(tblMaterials, "MatlType", "SS")
NewTableRow(tblMaterials, "MatlType", "AL")
NewTableRow(tblMaterials, "MatlType", "SP")
End Sub
Private Sub NewTableRow(DestTable As DataTable, ColumnName As String,
NewItem As String)
Dim NewRow As DataRow
NewRow = DestTable.NewRow()
NewRow.Item(ColumnName) = NewItem
DestTable.Rows.Add(NewRow)
End Sub
My intent is to add more funtionality so that my UltraCombo's in Part
Maintenance change their content based on user inputs.
--- In vantage@yahoogroups.com, "Steven Pybus" <steven@...> wrote:
> Thanks Frederic. I found your code on the forum yesterday. I was
> looking for a more direct route but after playing with it, I may be
> able to make it work just the same. I'm now trying to create a
> subroutine that will add a itmes to an UltraCombo.
> One question: What do the .ValueMember & .DisplayMember properties
> do for you in this example?
> Thanks,
> Steve P.
> --- In vantage@yahoogroups.com, "Frederic Naslis" fnaslis@
> wrote:
> > Here i populate a combobox in the customer form :
> > Private Sub CustomerEntryForm_Load(ByVal sender As object, ByVal
> args As
> > EventArgs) Handles CustomerEntryForm.Load
> > '// Creating a table named Customers
> > Dim tblCards As DataTable
> > tblCards = New DataTable("Cards")
> > '// Declaring three rows for the table
> > Dim Row1, Row2, Row3 As DataRow
> > '// Declaring a column named Code
> > Dim CardID As DataColumn = New DataColumn("CardID")
> > '// Setting the datatype for the column
> > CardID.DataType = System.Type.GetType("System.String")
> > '// Adding the column to table
> > tblCards.Columns.Add(CardID)
> > '// Declaring a column named Name
> > Dim CardName As DataColumn = New DataColumn("CardName")
> > CardName.DataType = System.Type.GetType("System.String")
> > tblCards.Columns.Add(CardName)
> > '// Filling the row with values. Item property is used to
> set the
> > field value and add it .
> > Row1 = tblCards.NewRow()
> > Row1.Item("CardID") = "AMEX"
> > Row1.Item("CardName") = "American Express"
> > tblCards.Rows.Add(Row1)
> > Row2 = tblCards.NewRow()
> > Row2.Item("CardID") = "MC"
> > Row2.Item("CardName") = "MasterCard"
> > tblCards.Rows.Add(Row2)
> > Row3 = tblCards.NewRow()
> > Row3.Item("CardID") = "Visa"
> > Row3.Item("CardName") = "Visa"
> > tblCards.Rows.Add(Row3)
> > cmbCreditCard.ValueMember = "CardID"
> > cmbCreditCard.DisplayMember = "CardName"
> > cmbCreditCard.SetColumnFilter("CardName")
> > cmbCreditCard.DataSource = tblCards
> > End Sub
> > On 5/8/07, Steven Pybus steven@ wrote:
> > > Does anybody have access to documentation on the customization
> tools?
> > > I'm looking for a way to modify the contents of an ultra combo
> > > pulldown during runtime. All of the VBA, VB6 and .net that I've
> > > worked with in the past have provided .AddItem methods or some
> way to
> > > change the pulldown list contents based on runtime conditions.
> > > The only way I see of doing this is to...
> > > 1 create a table,
> > > 2 populate that with the data and
> > > 3 change the combo's datasource.
> > > Any way of doing this the easy way?
> > > Thanks,
> > > Steve P.
Does anybody have access to documentation on the customization tools?
worked with in the past have provided .AddItem methods or some way to
1 create a table,
Steve P.
Private Sub CustomerEntryForm_Load(ByVal sender As object, ByVal args As
'// Filling the row with values. Item property is used to set the
End Sub
> 1 create a table,
> Thanks,
> Steve P.
Steve P.
--- In vantage@yahoogroups.com, "Frederic Naslis" <fnaslis@...>
args As
set the
> End Sub
tools?
way to
> > 1 create a table,
> > Thanks,
> > Steve P.
Hi steven,
In .NET ValueMember = "DataValueField" and DisplayMember = "DataTextField"
In fact you tell to the object that you work with the "ValueMember" but you
display the "DisplayMember"
If you bind the combo with the table customers and fied shortchar01 the
"ValueMember" is stored but it display the "DisplayMember"
Hope this help.
> Thanks,
> Steve P.
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, "Frederic
> args As
> set the
> > End Sub
> tools?
> way to
> > > 1 create a table,
> > > Thanks,
> > > Steve P.
